Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Chipped the porcelain or enamel off
I have a kenmore electric range. I dropped a plate on the edge and chipped off the paint. Do you have an almond repair kit that will match that I can buy?
    Problem Solver:
  • 8 Answers
Yes they have almond , white, black repair paint used to get from walmart maybe not anymore i dont repair anymore but they do have it . it smells really bad an takes a long time to dry careful of over spray also getting on other parts of stove top
Posted on Oct 11, 2008
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
How to get scratches out of almond enamel stove top
Not much you can do for scratches. You can a smooth top cleaner to help buff out the appearance as much as you can, but you cannot fill the cracks or scratches at all.
Aug 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
The enamel on the bottom of my oven has started to flake can i buy paint to repair it before it goes rusty
You can buy enamel paint , depends where the rust is, you can buy heat proof paint if it is inside the oven.
If it is outside then treat it with a rust inhibitng paint first.
Nov 09, 2010 | Ovens
Kenmore oven cleaning cycle has scorched paint on top panel
I would expect a standard appliance paint to scorch at the exhaust of the machine and would expect enamel paint at that point.
Jun 07, 2017 | Kenmore 40494 / 40495 / 40499 Electric...
Enamelware repair
I have used appliance touch up paint to repair scratches and chips on ovens on enemel with out any problems.
I do not think you will have a problem
I do believe that there is a specific touch up for white enamel, but I don't know about other colours
Please leave feedback.
Thanks.
Nov 13, 2009 | Ovens
How can I re-enamel an old wood burning stove?
For my outdoor burner i use Krylon high temp flat black which works great for me, Sherwin-Williams has a large variety of high temp paint for your application.
Oct 10, 2009 | Ovens
I need to repair the enamel in the base of my oven. It has been removed in somne areas.
they make special appliance enamel touch up paint, which is good for a knick and a chip here and there. If its a bigger job than that, you may want to use a higher heat enamel. Ive used high heat engine enamel purchased at an auto parts store, which they formulate to work with the heat of car engines. It comes in a spray can, so it depends on the scope of the project/repair.
Aug 31, 2009 | Philips Ovens
Melted aluminum foil on oven floor
I'm not up on my science, but..it's like welding, or more like soldering, chances are it's a high temp metallic enamel paint, and the two fused creating a mechanical bond. Your stove is cooked. You may be able to scuff the bottom and repaint it with a new coat of high temp enamel.
Just remove the racks, undo the clips that retain the heating element,(so you can lift it some, DO NOT try to remove it) tape off the bottom to create nice clean edges, using a piece of 80 grit sandpaper scuff the paint really good, lay down a coat of primer if the directions call for it, and follow the directions on the can. Don't worry about the clips, close the door and turn the stove on to the temperature specified on the can, and leave it on for the time stated. It will bake to a smooth glossy finish.
Most of the products I've used go up to 1000 degrees, and bake at 400 for 4 hours.
Good Luck!!
Thanks
Aug 23, 2009 | Kenmore Ovens
Self-cleaning heat stains on the front facing panel
Use DeBruce polish. We Use Debruce Polish on all our cooktops and ENAMELED SURFACES. Debruce also works on stainless steel polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Nov 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
398 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
