Question about Cameras
I bought a used Canon EOS Rebel and was told there was a problem with it. I purchased a new battery and charger. I have installed a fully charged battery and I get nothing at all on the lcd screen, also nothing works.
    Genius:
  • 2,985 Answers
What you have told is right then - why did you buy it?
There is nothing for you to do- but to find a repairer
I dont think there is much hope -as wth all small electronics they are not made to be repaired.
Posted on Aug 12, 2008
I have a Canon Rebel XTI and it was working fine until one day it just decided not to turn back on. Tried charging both batteries multiple times and upon putting them in, it still will not turn on. Am I...
Sorry to hear about this. I have a similar camera and have been racking my brain about this...
My only thought...are you using the same battery charger? Perhaps the battery charger is to blame. You may be out of battery on both batteries. When you install the battery, does ANYTHING happen? Does it say, LOW Battery or CHANGE the battery? Or is it totally black? If nothing happens at all, you should probably contact Canon directly. Or purchase a new charger and see if that fixes the problem.
Canon Customer Support Center Phone: 1-800-OK-CANON
1-800-652-2666 Hope this helps!
Jul 26, 2011 | Canon EOS 400D / Rebel XTi Digital Camera...
Camera shows battery dead. battery is fully charged. opened battery dor and battery ok. added lens and battery shown as needing charge.
You probably have a faulty battery or charger. If you know someone with the same camera try swapping batteries. If not a new battery sounds like your next move.
Good Luck
Jun 16, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Haven't used my Canon rebel xt for awhile but tried today and it will not turn on. Purchased new CR2016 battery and fully charged the other battery. Has not been dropped or misused. Please help
Aposta,
It is possible if you haven't used the camera for a while that the contacts inside the battery compartment need to be cleaned. This can be done with a q-tip and some alcohol.
Thank you.
Mar 21, 2011 | Canon Rebel XT / EOS 350D Digital Camera
I have a Canon Rebel EOS that I am having trouble power wise with. I can have a fully charged battery in, the power off option off but it still turns off sometimes before I even take a picture. I rarely...
Sometimes it happens that the ends of the battery get torn off while we place the battery into and out of the charger for charging. the battery heads get popped off which most of us dont notice.
i suggest you to get a new alkaline battery and check the same with your camera. If problem resolves go ahead and buy new rechargeable batteries.
Jan 07, 2011 | Canon Rebel XT / EOS 350D Digital Camera
No power - fully charged battery
How about cleaning the battery contacts in the camera first with a pencil eraser and then, with a cotton swab lightly dampened with rubbing alcohol.
Aug 02, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon 400d new batteries installed but will still not turn on.
Might seem obvious but check that the green light on the charging unit showed that the battery was fully charged before you put it in the camera. Make sure that the memory card is fully seated in the slot. If ok then either the charger is not charging or the on/off switch is faulty.
Jul 14, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Camera drains charged batteries
Most likely your batteries are just not holding a charge. However, before you spend good money on new batteries, try charging them on another charger (friend or sympathetic photo shop?). Could be the charger also. Usually it's the batteries, though.
Mar 16, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Rechargable batteries drain as soon as they are put in the camera
Your circuit board has developed a short. There is only one way to fix it, replace the main circuit board. Buy an A530 camera with a cracked LCD online from someone, to fix it.
Nov 17, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon eos rebel t2 battery indicator
guido462:
new batteries - brand new? fully charged per spec?
Jan 21, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
