Question about Refrigerators
I have a hotpoint frost free fridge freezer,the fridge has stopped working,ive tried cleaning behind the front panel but its still the same.
  • 29 Answers
Sounds like a defrost problem try turning it off and leave it off to allow time for ice to melt (about 2-3 hours)then restart if it gets cold again in the fridge its definately a timer or heater problem
Posted on Aug 13, 2008
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
How to fix a hotpoint frost free fridge freezer
I would call a repairman . possibly the fan has worked loose on the motor shaft
Oct 08, 2015 | Total Micro HDP80CF72-PAN 80Gb Notebook...
I have a hotpoint fridge freezer FUFL 1810, there is a puddle of water appearing on the kitchen floor coming from underneath the unit any help please ?
its the evaporator try its mounted above the compressor
perhaps the freezer has quick defrosted and the try is too full
use a towel and soak all the water off
check the freezer balast fan is running ok and fast enough {good speed}
or the freezer can reach a state where it just melts a little of the ice monster
so
my adivce is the run your food in it down
then completely defrost it
and you need to clean all the pipes that go too the evaporator tray
and then dress them with salt
they are usually at the bottom of the V shaped channels both at the back of the fridge
and also behind the freezer rear wall
it usualy has a panel with a few screws or pop plastic pins
that allows you too get too the blast fan and the evapoator V shaped channel
that guides the water to the evaporator pipe
so it prob needs something done with the frost free unit
i think its just got too the point its gummed up
with ice and the fan isnt working efficently anymore
Jan 10, 2015 | Hotpoint Refrigerators
Quadrio hotpoint fridge freezer, gas recharged six months ago by BG homecare 400 engineer. It is now 30 months old and last week the freezer packed in again. A bg engineer came back today and said th
defrost it fully
and clean the pipes that leed too the 'evaporator' and dress the V shaped guides for frosting liquid with salt
and clean it with bleach
you may need to replace the blasting fan its located behind the back panel in the freezer
so leave it off a few days
clean it with 5% bleach water solution
then remove the back panel of the freezer compartment
then check out the fan
and any issues with this will leed too just the very bottom of the freezer working
so replace the fan and clean out the pipes
if you dont then it will just ice monster inside the back again
esp if the fan is no good
and the jobs a goan
these guys just want to visit and go away...
deal with getting the parts and get a local guy to fit it in
a universal type is available on ebay ive used many times
for like a 5er....
Dec 23, 2014 | Refrigerators
My hotpoint fridge freezer doesn't work properly, the freezer stays cold but frosts up behind the back panel and the fridge doesn't stay cold. can you help?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Refrigerators
I have a 10 year old hotpoint mistral plus frost free fridge freezer whic keeps coming up with EA as an error message in the display screen. We have turned the appliance on and off which sometimes solves...
thanks for the question yes it very well could i would pull fridge away from the wall and clean the condenser if dirty makes all the difference especially in that heat thanks the appliance doc
Sep 24, 2008 | Hotpoint Refrigerators
Fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Jun 23, 2008 | Electrolux ERN2820 Bottom Freezer...
Freezer ok fridge warm (15 degrees)
You have a hotpoint mistral f/f i take it in silver..
Check to see if the fan is running at the bottom on the back of the fridge its next to the compressor behind the panel ...
if the compressor is running and the fan is not then your fault is the fan..
IF the fan is running then its the sensors...
These are located in the freezer section, pull out the draws and remove the panel behind it.... six screws.......... you will c threes plugs at the top ledt hand side.. the yellow one is for the fridge the green one for the freezer.... replace both if your freezer is not working...
Also just below the freezer door there is a panel remove the panel and use a vaccumm to clean the fluff that has built up on the coils..
hope this helps if you need anymore help dont hesitate to ask...
by the way the sensors are called evap thermistors...
Jan 10, 2008 | Refrigerators
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
