Question about Brother Office Equipment & Supplies
I am unable to send a fax on new 1460 - Brother Office Equipment & Supplies
    Genius:
  • 2,120 Answers
Verify that you have a dial tone with another phone plugged into wall jack.
Posted on Aug 31, 2008
SOURCE:
Brother 1460 Fax Machine. Will receive faxes and 'print' independant douments, but copies from both are COMPLETELY blank. I have auto-cleaned the heads several times and the cartridge has plenty...
Hello, Davetwydell -
Since you posted your question on Fixya.com, am I safe to assume you do not have the user manual for your Brother Fax-1460? If you do not have it, you can find it to download (free) here: http://support.brother.com/g/b/manuallist.aspx?c=eu_ot&lang=en&prod=fax1460_eu&flang=English&type3=121&type2=5 .
Instructions on how to make a copy or copies start on page 64 of the manual. The first step listed is to make sure you have the machine set to COPY mode.
If, after following the directions in the manual, copies still do not print, I recommend you contact the Brother Solutions Center for help: https://secure6.brother.co.jp/g/b/contactform.aspx?c=eu_ot&lang=en&cid=45&pcatid=4 .
Best wishes.
Dec 17, 2017 | Brother Inkjet Fax Machine Fax1460 Plain...
What does COM-E mean when we try to send fax's and the transmissions has this written on it instead of OK.
It means "Communication Error".
The result might be twofold:
- the fax didn't reach it's destination because of communications error (any kind)
- the fax did reach it's destination, but part of it may be unreadable or distorted, or some pages of a multi-page fax did not go through.
In many cases, what the device perceives as an erroneous transmission, is perfectly readable by a human. Therefore it's good to call the recipient and ask if the fax is readable and if all the pages were received.
Nov 13, 2009 | Sharp FO 1460 Plain Paper Thermal transfer...
Error messaage "unable to clean" on a MFC210c
There should be a number with the error, if it's 46, you need a new ink flushing box. You won't be able to fax until you clear the error.
Jul 01, 2009 | Brother MFC 210C All-In-One InkJet Printer
Need operation manual for Sharp FO-1460. Can
Turn your fax off then back on. If the problem persist try a memory clear. Press function 9 * 8 # 7 then press start , then keep pressing your # key until you see memory clear then press start. You will lose #'s that are stored. If the problem still persist try another phone line(analog line). This problem will not be in your owners manual, but if you still need one I would do a google search.
May 17, 2009 | Sharp FO 1460 Plain Paper Thermal transfer...
Sharp fax
i dont know how to send a message using fax machine
Jul 07, 2008 | Sharp FO 1460 Plain Paper Thermal transfer...
Problem with Sharp FO-1460
What happens when you make a copy?
If that is blank, you have a bad scanner.
Jan 09, 2008 | Sharp FO 1460 Plain Paper Thermal transfer...
Sharp F0-1460
"DOCUMENT JAM" refers to your original document that you are trying to send. Lift the top of the Automatic Document Feeder (ADF) and look for a tiny peice of torn paper. If not, look for a stuck sensor flag (might look like a small plastic finger). If still no go, clean the roller that feeds the original, it may be worn out and slick. Hope it helps Ed
Jul 13, 2007 | Pitney Bowes 9920 Plain Paper Fax
Open Questions:
James Cagle
James Cagle
Jim Keysor
ctnozil
