Question about Apple iPhone 3G
IPhone MobileMe The iPhone mobile me isn't working again, is it a problem with my iPhone 3g or did the servers fall once again?
    Problem Solver:
  • 12 Answers
Check ur online mobileme settings, make sure the phone is set up properly
Posted on Jun 09, 2009
I can't sign up using the iPhone it says the servers are busy for two days
If you had Mobile Me, you need to go into the iCal preferences and turn off the Caldav or switch it to manual. The system is trying to access the Mobile Me site which no longer exists.
Or you should open the MobileMe Pref Pane & remove your login & Password.
Jun 16, 2014 | Cell Phones
I have iphone 3g version 4.1 i wont to unlock it
You can try to use "tinyUmbrella" to see if cydia has you ssh on file..
tinyumbrella website
once you start the software you click the button save my ssh..
once it's done processing you can click on start tss server
This tss server will allow you to bypass itunes server which restricts downgrading firmware...
Once Tss server is running you can start itunes
once itunes detects your iphone shift + click on restore
Select the iphone 3g 4.0.1 firmware (goto to download this)
Once it restores fully at the end it will give itunes error '1015'
dont worry..
Install Libusb if you dont have it..(Click here)
after installing libusb just use this program.. ih8snow
Click on "Fix recovery mode loop"
Click on yes to "do you have libusb installed??"
Select iphone 3g from the list
your iphone will reboot..
now you can first activate it ..
then you can use safari to goto
slide the slider at the bottom...
it will download cydia
when cydia is installed you have to add "" as a source
Its a zero "0" in the sn0w not "o"...
Search google how to add new sources.. to cydia..
Once you are done installing the application inside the source your phone will be finally unlocked..
Of course easier way out would be to pay someone who knows how to do this..
Oct 21, 2010 | Apple iPhone 3G Black Smartphone
I cant sinc my i phone as it says unable to connect to i tunes store.
Please follow the steps below to resolve your sync issues which applies to iPhone, iPad, or iPod touch. If you make changes during any of the steps below, try syncing again with MobileMe on your iPhone, iPad, or iPod touch.
  1. If you are syncing calendars or contacts, view the data on MobileMe Calendar or MobileMe Contacts. If the data does not appear to be correct there, the issue is not with your device. If you are syncing using a Mac, see this article for more information. If you are syncing using a PC, see this article for more information.
  2. Make sure your device is up to date with the latest software. To make sure your device is up to date, connect it to your computer, open iTunes, and click "Check for Update."
  3. On your device, make sure you are able to connect to the Internet. For example, open Safari on your device, then browse to . MobileMe requires an Internet connection to sync. (A 3G or WiFi connection is recommended during setup or when following many of the steps below; they may require several minutes via an EDGE connection.)
  4. Confirm that a sync is not already occurring. If a sync is occurring, the activity spinner (in the status bar) will display while looking at Safari Bookmarks (if Bookmarks are currently syncing), Calendar (if calendars are currently syncing), or Contacts (if contacts are currently syncing). If a sync is occurring, wait for the sync to complete, and then see if your data is up-to-date.
  5. Make sure you are looking at your full set of contacts or calendars. When configuring your MobileMe account in iOS 3.1 and later, you will have a choice to Merge or Don’t Merge your data. If you choose Don’t Merge, your MobileMe data is kept separate from the data that was already on your device. In Contacts/Calendars, tap the button in the upper left corner until you are able to see all Groups or Calendars, and verify that you are looking at your MobileMe data.
  6. Confirm that you are able to get your MobileMe Mail on your device. If you receive an alert message when attempting to get your MobileMe Mail, your account may not be configured correctly, or you may not have a reliable internet connection. If the alert message is about your username or password being incorrect, go to the next step.
  7. Verify your MobileMe account is configured correctly on your device:
    1. On the home screen, tap Settings > Mail, Contacts, Calendars.
    2. Tap Fetch New Data, and make sure Push is turned On. Tap Mail... to go back one screen.
    3. Tap your MobileMe account.
    4. Tap Account Info and check the Address field.
    5. Verify that your address appears correct (it should appear as your MobileMe email address, such as or If your account does not appear as expected, see the “Delete and re-add your MobileMe account” under the Advanced Troubleshooting section below.
    6. If you received an alert about your username or password during step 6, delete and re-enter your MobileMe password, and then check your Mail again. If your still receive the same message, try logging into If you are unable to log in, see this article.
    7. If your account does appear to be entered correctly, go back one screen and confirm the sliders for the data that you want to sync are set to On.
  8. Verify that your device is connected to the MobileMe service. To confirm this, visit from a computer. Because Find my iPhone relies on the same connection as MobileMe Sync, your device should be listed as "Online" for as long as it has an active Internet connection. If the device does not appear as expected, please see this article about troubleshooting Find My iPhone.
  9. Restart your device: Hold the power button until "slide to power off" appears. Slide to power off. After it is off, press the power button to turn it back on.
  10. Wait an hour and try again. Apple may temporarily disable an account from syncing with MobileMe if it is determined that an account may be taking longer than normal to sync. By waiting an hour and trying again, this allows for the previous sync to complete. If you find your account encounters the issue again, go to the Advance troubleshooting section.
If the above steps do not resolve your issue on your iPhone, iPad, or iPod touch, you can try these advanced troubleshooting steps:
Turn all syncing off and then back on
From the home screen, tap Settings > Mail, Contacts, Calendars, and then tap your MobileMe account. Tap the sliders off for each account that your are syncing. If prompted to do so, tap "Keep on My iPhone" (or iPad/iPod touch). Turn your device off and back on, then re-enable syncing. If prompted to do so, choose Merge with MobileMe. Wait a few minutes, and try syncing again.
Isolate the issue to a specific data type
If the above did not resolve the issue, once again turn off all syncing, and then test each data type one at a time. For example, if Contacts syncs successfully, but Calendars does not, focus your troubleshooting on Calendars.
If you have isolated the issue to either Contacts or Calendars that are not syncing successfully (one works, the other does not), see this article recommendations about how to clean up that data on your Mac or PC, as it is likely causing the issue.
If none of the above steps resolve the issue, make sure you have a copy of all Contact, Calendar, and Bookmark data on your device saved on your Mac/PC. From the home screen, tap Settings > Mail, Contacts, Calendars, and then tap your MobileMe account. Tap Delete Account. (If prompted to do so, choose "Delete from My iPhone" (or iPad/iPod touch). Restart your device. After it restarts, on the Mail, Contacts, and Calendars screen, tap Add Account > MobileMe, and set up your account again.
Aug 15, 2010 | Apple iTunes
I bought a apple iphone 3g 8gb from a car boot everything works but it has been blocked
Sounds like it might be stolen and locked by the original owner's MobileMe account. Try restoring with iTunes is that doesn't work, call your carrier.
Oct 03, 2009 | Apple iPhone 3G
IPhone screen completely black.
Take your phone to an apple store and get a replacement.
Jul 13, 2009 | Apple iPhone 3G
Lost contacts & calendar
You will need to reformat and go again...sorry
May 31, 2009 | Apple iPhone 3G Black Smartphone
Push Erased Calendars / Calendar colors
Well you  have to set up Mobileme for the iPhone 3G.
Thank You, Apple Care Service And Support
Jul 17, 2008 | Apple iPhone 3G
IPhone 3G server problem
Apple had a problem with their servers during the iPhone 3G launch, they under estimated the number of people that will try to log into the iTunes server at once, as a result the server fall down.
If this is the error you get, when connecting to the iPhone 3G to iTunes server you can relax, your iPhone 3G is 100% OK.
It looks like this -
The barber pole spins for a minute then throws a -9838 error
Jul 13, 2008 | Apple iPhone 3G
Apple iPhone 3G Logo
195 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
