Question about Dell 5100cn Laser Printer
5100cn error 016-310
Where do I locate the controller card
  • 1 more comment
  • Anonymous Nov 07, 2008
    Dell said I have to replace it. $291+!
    Dell said mine has to be replaced. $291+!
  • mavellan Feb 26, 2009
    I was able to get past the "016-310 Restart Printer"message by holding down the menu key upon booting the DELL 5100cn printer. I was then prompted to insert a toner for each color despite having all the toners in place. All the toner cartridges were DELL except for a BLACK Media Sciences toner. I swapped out the toner cartridges with Media Sciences toner cartridges and was able to print to the printer. I still get the error message with the old toner in the printer when power cycling the printer.
The only way is to replace it. This costs around $290+.
Posted on Nov 07, 2008
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 188 Answers
The controller card on the 5100CN is located at the rear of the printer.
Rotate open the paper tray cover, remove the 3 screws securing the controller card assembly to the chassis. ( one at the bottom middle, one at each of the top two corners ), and slide the assembly towards you to remove.
NOTE: If you have a replacement Controller card that you are going to replace, you must migrate the existing NVRAM Chip from the old card to the new card. Even if the replacement card contains an NVRAM Chip, the old chip must be used in order to prevent an NVAM error.
Also ensure use of proper ESD Handling proceedures to prevent damage to the board and NVRAM Chip.
Posted on Sep 28, 2008
SOURCE:
Dell 5100cn Error cod 010-397 Restart Printer
ahmad, does the printer show as default? if not make it. Try test print and make sure all printer compartment are securely closed.
Jan 11, 2014 | Dell 5100cn Laser Printer
Where is the ADC located on the dell 5100cn?
you can check this website link for the location of the ADC http://workingprinter.com/z/327003000000429
Hope this helps
Thank you
Dennis
Oct 18, 2011 | Dell 5100cn Laser Printer
I've getting the "Replace transfer roller" message
  1. reset count in printer menu
  2. clean the optical sensor
Mar 15, 2011 | Dell 5100cn Laser Printer
Where is the manual paper feeder tray?
The manual feeder is located at 4 on this webpage. I would say its in the front. but a picture is a lot better. then how I would describe it.
http://support.dell.com/support/edocs/systems/5100cn/en/UG/index.html
Jun 17, 2010 | Dell 5100cn Laser Printer
Dell 5100cn has error message: Clean CTS Sensor -
I've included a link below to the manual for your printer. Please follow the instructions listed under "Cleaning the Automatic Density Control (CTD) Sensor".
http://support.dell.com/support/edocs/systems/5100cn/en/UG/section21.html#1097283
Jan 19, 2010 | Dell Office Equipment & Supplies
Xerox fuser for Phaser 6300 installed in Dell 5100CN- Fuser ID er
I would only use the part designated by the manufacturer.
Feb 24, 2009 | Dell 5100cn Laser Printer
Dell 5110cn printer error code 016-317
The 016-317 on this printer refers to the printer not being able to communicate with the MCU board. This is what you should do. This was pulled from support.dell.com. Which is the same troubleshooting trees as the phone/internet agents use. If this doesn't solve your issue, you will more than likely need to update the firmware of the printer, or replace the board. STEP: Reseat the controller card on the 5100cn-series printer.
Additional Information image001.gif CAUTION: Before you perform any of the following steps, read the Precautionary Measures warning (located in the Resources/Additional Resources section) for your personal safety and to prevent damage to the computer system from electrostatic discharge.
To reseat the controller card, perform the following steps:
  1. Make sure that the printer is turned off and unplug all cables including the power cord from the rear of the printer.
  2. Pull the tray rear cover so that the top edge tilts out, then lift the tray rear cover off its hinges. (Figure 1)
    Figure 1 - Remove the Tray Rear Cover
  3. Remove the three screws on the control board from the back side of the printer. (Figure 2)
    Figure 2 - Remove the Three Screws
  4. Remove and reinsert the controller card from the printer by the handles. (Figure 3)
    Figure 3 - Reseat the Controller Card
  5. Tighten the three screws on the control board on the back side of the printer.
  6. Reattach the tray rear cover to the back of the printer.
Feb 18, 2009 | Dell 5100cn Laser Printer
Dell 5110 004-310 reset printer error
This may not solve your problem but it did mine when I got the "reseat cartridge" error. I had inadvertently ordered the cartridge for the 5100cn, which looks exactly the same as the 5110cn and actually fits if you order the generic version (the Dell 5100cn cartridge looks like the 5110cn but doesn't quite fit).
So, first make sure that you ordered the 5110cn cartridge. (And if you need two opened 5100cn cartridges, I've got them up on ebay :( !!!!)
Jan 23, 2009 | Dell 5110cn Laser Printer
Dell 5100CN Not printing magenta
Dell 5100cn won't print yellow. No error messages except "replace imaging drum soon". Replaced yellow cartridge, cleaned yellow, etc. Still not working
May 13, 2008 | Office Equipment & Supplies
Dell 5100cn Laser Printer Logo
2,277 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
