Question about Motorola Mobility MD700 Cordless Expansion Handset
Battery replacement I am in need of a replacement battery for my MD700 phone. It is a 3.6v, how do I know which mAh it needs...700, 800, 1500??? Does it matter which one I use? Why?
Can i use a rechargable battery which is rated 750 mAh(1.2v) if the one in the phone is 850 mAh (1.2 v)?
No it would not be advised to go for a lower mAh as your phone would not perform as eficiently and also too I would recommend to replace it with same as qriginal 1.2 v -Ni-MH battery . And you can get any battery from Amazon .Com at avery good price, that is my go to place if I want something specific.
Jun 17, 2014 | Siemens Gigaset S675 1-Line Cordless Phone
Tip
Extend the life of your phone - Motorola 5.8Ghz - MD700 series
** Extend the life of your phone - Motorola 5.8Ghz - MD700 series **
PROBLEM:
We got tired of buying so many of the replacement/rechargable batteries for our Motorola 5.8Ghz phone. So I started labeling the replacement batteries by taking a permanent ink pen (aka. 'sharpie pen') and writing the date of install directly onto the battery. I noticed that I was buying replacement batteries after just a few months.
SOLUTION & EXPECTED OUTCOME:
After some searching online, I discovered that you can purchase stronger batteries. We did this and have extended the from months to years. Currently we're still running on batteries that were installed in January, 2008. That's almost two years on the same battery.
We purchased our replacement 3.6V2000mAh batteries from "SmartBatts" - if you need more info, or encounter any difficulty locating the replacement batteries, then reply back to this post and I'll help!
thanks,
Chris I.
on Dec 08, 2009 | Lands Phones
Philips SE 455 twin set cordless: The charge lasts less than an hour when using speaker phone, so I am looking for replacement batteries. Phones only 2-3 years old and absolutely fine in all other...
A higher capacity battery should work even better because a fully charged 900 mAh battery allows the phone to operate 50% longer than a 600 mAh battery between charges. I have had good results with Rayovac Recharge Plus 900 mAh in my Philips SE450. This phone will latch and not operate upon ringing if it doesn't like its batteries (probably high internal resistance), even though the batteries test good on a battery tester.
Jun 28, 2011 | Philips 2252 Twin Cordless Phone
Can i replace my 800 mah cell phone battery with 1000 or 1300 mah battery
You can replace current battery 800 mAH with higher mAH, but make sure the voltages are really same so that, you still can use your charger and the new battery will not damage your phone.
Regards,
Jan 16, 2011 | Cell Phones
I NEED THE BATTERY
you can get the battery from the below website,,,,please click the link below to get a new one....
http://www.amazon.com/Energizer-ER-P240-Nickel-metal-Hydride-Cordless/dp/B00006JM6J/ref=dp_cp_ob_e_title_0
thank you
Sep 24, 2010 | Motorola Mobility MD700 Cordless Expansion...
Need to replace battery back-up pack. Have any
Oh wow. You have an old timer there. I think they used a rechargeable 3.6Volt pack so you should be able to use any old rechargeable nickel cadmium or nickel metal hydride 3,6V battery such as out of a cordless phone. try a local electronics shop.
Mar 27, 2010 | Casio Parts Cash Register PC Desktop
I need good rechargeble batteries for Sci I9 phone
The standard golden batteries you get with the phone are terrible and only last up to 6 hours! You should get the WHITE batteries which say "Sciphone" on them. I have just ordered the 2800 mAh batteries on eBay; hope they will perform significantly better :-)
Mar 11, 2010 | Dual Electronics CECT P168 Cellular Phone
Motorola MD700 Cordless Phone
i need to know how register this phone
Jul 13, 2008 | Lands Phones
Sony DSC-P93 battery replacement question
NiMH batteries. You can use the larger mAh AA. It has more capacity and should give you longer service before needing recharge. The battery manufacturers recommend that you do not mix the batteries. i.e. don't use mAh 2100 and mAh 2500 as one set, use all 2100 or all 2500 as one set.
Sep 08, 2005 | Sony Cyber-Shot DSC-P93 Digital Camera
Motorola Mobility MD700 Cordless Expansion Handset Logo
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Clyde Hanson
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
