Question about GE Dryers
Front felt keeps comming out i keep pushin it back in on my electric dryer ge what to do
  • 706 Answers
You can use Gasket cement that can be purchased at most home improvement stores to reattach the felt to the steel face of the dryer.. Hope that helps.
Posted on Aug 12, 2008
How do I get the front panel off a ge mod djsr473et6ww cloths dryer.
GE Dryer Repair - How to Take Apart, Open, or Disassemble ...
? 6:21
https://www.youtube.com/watch?v=AgsOwIwoygc
Feb 22, 2013 - Uploaded by canyonman1963
Tags: GE, General Electric, Frigidaire, Electrolux, electric, dryer, open, remove, take apart ...
Dryer Repair - Replacing the Lower Front Drum Felt Seal ...
? 9:42
https://www.youtube.com/watch?v=XoYP_YsGP68
Jun 7, 2011 - Uploaded by PartSelect
Dryer Repair - Replacing the Lower Front Drum Felt Seal (GE Part .... on this dryer....how do you remove the ...
Nov 03, 2015 | GE Dryers
My clothes keep getting caught at the top of my front load dryer and some type of felt material came out
I recently worked on a dryer that was doing the same thing. I repaired it and took some PHOTOS
Aug 29, 2011 | GE DCSR483EA Electric Dryer
A piece of felt like material is hanging from the inside (top) front of the dryer. What is this? Can I fix it myself?
The felt is the seal that keeps the clothes from falling inside the dryer. The front of the dryer needs to be removed and the seal replaced (you can glue it back, but this usually means the seal is worn out)
Apr 21, 2010 | GE DBXR463GB Gas Dryer
GE DPSR483EA Electric Dryer was making a scraping sound when operating, now a felt like belt has come out on the inside of the dryer. what do i do? Kris Long
The problem is something got between the drum and the felt seal between the drum and the front of the machine. You will have to pull the front off and find out what caused the felt to come out and then put the felt back in place and put the front back on.
Mar 18, 2010 | GE DPSR483EA Electric Dryer
Replace the felt on a ge dryer part #we9m30?
You need to buy new felt. There is an upper and a lower piece. The upper piece has 3 glides to support the drum. When you buy the parts, make sure you have the dryer part number and there are some pictures that will help.
Make sure you uplug the dryer. Flip up the top lid of the dryer by sliding a large flat nose screw driver under the front corners of the top. Remove the front panel by taking out two phillips screws. Also remove the power cable to the front controls so you can completely remove the front panel. Strip off the old felt and clean the surface as good as you can. Glue on the felt (you should get a tube of glue with the new felt). Let is dry a bit before you put everything back together. It is a pretty easy job.
Mar 13, 2009 | GE DBSR453EBWW Electric Dryer
Maytag Dryer Mosel #MDE6700AZW
you will need to remove the front panel and the front bulk head. after that you will see that there are clips that need to be pushed down to hold the fabric (felt) down. You need to make sure that the felt isn't torn. If it isn't torn then all you need to do is take a flat head screw driver pry the clips up and put the felt back on and push the clips back down
Dec 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Black marks on clothes
Your going to have to get service for this one. Chances are the rollers are gone and the black is coming from the rubber onto the felt and then transfering to your clothes.
Sgt 48
May 11, 2008 | LG DLE2514 Electric Dryer
Ge select electric dryer
it may be clogged on the inside of the machine not just the exhust tube.
Jan 10, 2008 | GE DCSR483EA Electric Dryer
Dryers Logo
60 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
