You have option for blocking particular number! just call to your network service provider and ask for black list and white list. if you start this service you can block any number.
if you have android or any smartphone type mobile so just download apps whom block number.
for example click here
You can bar the calls that can be made
or received with the device (network
Make calls 35
© 2010 Nokia. All rights reserved.
service). To modify the settings, you
need the barring password from your
service provider. Call barring affects all
call types.
Select from the following voice call
barring settings:
Outgoing calls - Prevent making
voice calls with your device.
Incoming calls - Prevent incoming
calls.
International calls - Prevent calling
to foreign countries or regions.
Incoming calls when roaming
- Prevent incoming calls when outside
your home country.
International calls except to home
country - Prevent calls to foreign
countries or regions, but allow calls to
your home country.
To check the status of voice call barrings,
select the barring option and
Options > Check status.
To deactivate all voice call barrings,
select a barring option and Options >
Deactivate all barrings.
To change the password used for
barring voice, fax, and data calls, select
Options > Edit barring password.
Enter the current code, then the new
code twice. The barring password must
be four digits long. For details, contact
your service provider.
hope this helps
John
