Question about Garmin StreetPilot C330 GPS Receiver
No voice heard
When im driving , i dont here a voice command
There is a volume control on the right side of the gps. You may have just accidentally turned the volume down too low to hear.
Posted on Aug 13, 2008
SOURCE:
Stupid nintendogs
im not too sure but try ither talking closer ti the mic or furth also say it like its a dog in a commanding tone
Aug 10, 2009 | Nintendogs: Labrador & Friends for DS
Keep hearing "command not recognized"
well. the problem is that you're probably hitting the command button where you sumbit voice commands like: call "mom".
its a stupid thing to put on a phone, and I've never seen anyone use it. but whatever, verizon's stupid.
again, the voice command key on the enV is the clear button. so if you hold it down, you'll hear the "command not recongnized, after you hear "please say a command".
your hearing it over and over again because you accidently hit it, and since you dont say anything after the beep it gives, it goes "command not recongnized". i dont think it says "please say a command" when its on vibrate, but i couldnt be sure.
hope i helped :)
Jul 20, 2009 | Verizon Communications enV2 Cellular Phone
How to make a voice call
Are you sure the phone is voice command capable? To set up on the phone you must follow commands to repeat several letters, numbers & words. If you have done that then push the button on the headset & you should hear "say a command".
Jan 25, 2009 | Motorola Mobility H680 - Headset -...
Voice Activation
I have a 2006 A8 and if you need help with the command say "help mmi" or when you are in one of the following modes: radio, CD, or Navigation. you can say "help ." This should provide you with all the commands the voice command can understand.
Dec 27, 2008 | 2006 Audi A8
How do I use the voice command?
HI Con613,
Voice command is one of the feature of the mobile. It is important and if u understand it, it is very easy and useful to us.
Voice command is used to perform some sort of function (such as to open apps, camera, voice recorder, etc. and to call peoples) by giving voice command.
For it u need to go to voice command in tools in menu, then a list of apps appears. In it, u choose 1 apps, then it gives command to record voice. Record any voice of urs as command for it. When in standby mode or desktop, hold right soft key until voice command appears. Then give the same voice as recorded before to open the choosen apps.
Same process is to be applied for the apps.
For dialling people from voice command, u need to go to the person's contact. Go to options of it and add a voice as command for it. And same process is to be applied as to open the apps.
thank you
It is for mobile users.
If it is helpful for u, u can feedback me.
And i will help u later in other problems.
SAJAN
May 04, 2008 | GPS
I have heard that there is an upgrade to the Magellan Maestro 4040, where you can actually speak to the device and get things like directions to the closest resturant. How do I get this upgrade if...
Upgrade your Magellan Maestro with hands-free Voice Command & Control for the easiest, most satisfying navigation experience.
Your Maestro 4040 will respond to your voice commands to give you quick information and an instant route to nearby points of interest. Activate Voice Command & Control and find the nearest coffee, food, gas and ATM simply by speaking. Ask for your current location and distance to destination and hear the details as you keep your hands on the wheel and your eyes on the road. Just say the word and get instant information about the nearest roadside assistance.
Purchase the upgrade and you will be given a unique unlock code. Enter the code* into your Magellan Maestro 4040 and let your voice put you in command
Apr 16, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
No voice can be heard
the dry cell has nothing to do with it..the problem is your earpiece,it is located above the lcd..i think it is attached to the cellphone front casing..or you may have mistook it as a dry cell..check your phone if the earpiece is still there..should be round and has two feet sticking out..
Jan 18, 2008 | Nokia 8850 Cellular Phone
Voice System Error.....
If you made a backup before try restoring one back.
If not;
  1. Do this regularly as this is an easy way to stay away from problems.
  2. Make a backup right now and format your phone by keeping pressed *,3,call key (green one) while turning it on.
  3. See if the problem is solved OR ELSE RESTORE THE BACKUP BACK.
BACKUP AND RESTORE:
It can be done from memory right there in Extras or Tools folder.
Rate if Satisfied!
Dec 17, 2007 | Nokia 6600
Voice call/mp3/general sound issues
I have the EXACT same problem...driving me nuts. Someone please HELP.
Nov 23, 2006 | Motorola Mobility RAZR V3
Garmin StreetPilot C330 GPS Receiver Logo
70 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
