Question about NEC 10GB NOTEBOOK HARD DRIVE KIT FOR VERSA 6000 SERIES (10V6000NEC)
Bios for Intel Celeron 566 MHz
I am in need of BIOS for Intel Celeron 566 Mhz used as Fiery for Colorpass Z400e
2 Suggested Answers
SOURCE:
Geekman
  • 32281 Answers
SOURCE: i have NEC versa pro laptop intel celeron with 500
Laptops do not have IDE cables, the 21/2"hard drive is connected directly to the motherboard via a 44 pin socket.
What do you need an IDE cable for?
This cable would be difficult to connect into the laptop's motherboard hard drive connector.
Do you want to connect and test a laptop hard drives?
It is easier to use an USB hard drive adapter, all you need to do is connect the hard drive to the adapter and plug this adapter into a computer's USB port and the computer will detect it as an external drive (provided the hard drive is OK).
Posted on Feb 27, 2009
Intel Core 2 Quad 8200 with a 945GCT-M3? Will it work?
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=719&DetailName=Feature&MenuID=1&LanID=0
Here you can see the supported cpu list.
The quad core cpu will not run on this mainboard.
Here is info about the quad cpu:
http://ark.intel.com/products/36547/Intel-Core2-Quad-Processor-Q8200-4M-Cache-2_33-GHz-1333-MHz-FSB
But you can add a Intel Core 2 Extreme LGA775
This should give a noteable difference compares to the old single core cpu.
Remember also to buy a bigger cpu cooling element.
Here is no upgrade for the bios.
Good luck
Nov 18, 2012 | Computers & Internet
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
I have a mainboard of model D845GVAD2------------------------AAC18931-104. It has already intall the Intel celeron processor of 1.8GHz. Now I want to upgrade my processor. So what high frequency processor...
The Intel® Desktop Board D845GVAD2 supports a single Pentium® 4 processor with a system bus frequency of 400 MHz or 533 MHz, or a single Celeron® processor with a system bus frequency of 400 MHz.
So you can install upto 3.06 GHz 533 MHz(cache memory) processor and also update the ram 2 GB 400 mhz.
Dont install Prescott processor.
Hope it will help you.
Dec 31, 2010 | Intel Desktop Board D845GVAD2 Motherboard
I have just builed the PC with Supermicro P4SCA and when turn it on I get only the wlecone screen sying "SUPERMICRO" and that itm it never go beyond that. Cltr_Alt_Del does not work and I can not access...
Maximum processor supported: Intel Pentium® 4 processors or Intel Celeron processors up to 3.06 GHz (with Hyper Threading) at a system bus speed of 800/533/400 MHz.
Yours is too fast for the motherboard, replace it with an older weaker one.
Feb 03, 2010 | SuperMicro P4SCA 875P Mainboard...
Best/Fastest CPU for DFI PE21-EL mobo
Your motherboard supports 2 different fsb's.
look these up @ cpu-world
you can use:
Intel Pentium 4 processor (478-pin)
- 533MHz system data bus - supports up to 2.8 GHz
- 400MHz system data bus - supports up to 2.4 GHz
- 400MHz system data bus - supports up to 2.0 GHz CPU speed
and here are the suppoted cpus:
Intel Celeron RK80531RC029128 BX80531P170G128 1.7 GHz 17 x 400 MHz, Willamette Any A RK80531RC033128 BX80531P180G128 1.8 GHz 18 x 400 MHz, Willamette Any A RK80531RC037128 BX80531P190G128 1.9 GHz 19 x 400 MHz, Willamette Any A RK80532RC041128 BX80532RC2000B 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported RK80532RC045128 BX80532RC2100B 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported Intel Pentium 4 RK80532PC021512 1.5 GHz 15 x 400 MHz, Northwood Any A RK80532PC025512 BX80532PC1600D 1.6 GHz 16 x 400 MHz, Northwood Any A RK80532PC029512 1.7 GHz 17 x 400 MHz, Northwood Any A RK80532PC033512 BX80532PC1800D 1.8 GHz 18 x 400 MHz, Northwood Any A RK80532PC037512 1.9 GHz 19 x 400 MHz, Northwood Any A RK80532PC041512 BX80532PC2000D 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported RK80532PC049512 BX80532PC2200D 2.2 GHz 22 x 400 MHz, Northwood A 1.525V not supported RK80532PE051512 BX80532PE2266D 2.26 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PE056512 BX80532PE2400D 2.4 GHz 18 x 533 MHz, Northwood A 1.525V not supported RK80532PC056512 BX80532PC2400D 2.4 GHz 24 x 400 MHz, Northwood A 1.525V not supported RK80532PC060512 BX80532PC2500D 2.5 GHz 25 x 400 MHz, Northwood A 1.525V not supported RK80532PE061512 BX80532PE2533D 2.53 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PC064512 BX80532PC2600D 2.6 GHz 26 x 400 MHz, Northwood A 1.525V not supported RK80532PE067512 BX80532PE2667D 2.66 GHz 20 x 533 MHz, Northwood A 1.525V not supported RK80532PE072512 BX80532PE2800D 2.8 GHz 21 x 533 MHz, Northwood A 1.525V not supported
Dec 26, 2008 | DFI PE21-EL Motherboard
How do I overclock a Celeron 733mHz PGA370?
You can only overclock your computer if it has ATAPI BIOS. So get into BIOS upon bootup and if you have ATAPI then it will say it across the top. It will also have a section for the CPU with the current speed and an option to change it.
Dec 22, 2008 | Intel Celeron, 600 MHz (SL46U) Processor
Armada E500 BIOS reports wrong processor speed
Check Compaq's support site for any driver or utilities download for the chip set.
Aug 09, 2008 | Compaq Armada E500 Notebook
Motherboard processor support
Processor Family Processor Speed System Bus Frequency Cache Size BIOS Version Notes Pentium® III processor 850 MHz 100 MHz 256 KB P14 or greater The following board revisions (AA numbers) support these processors: 754552-200 or later
754558-200 or later
A01450-200 or later.
See the board revision note, below, for an explanation.
800 MHz 100 MHz 256 KB P14 or greater 750 MHz 100 MHz 256 KB P14 or greater 700 MHz 100 MHz 256 KB P14 or greater 650 MHz 100 MHz 256 KB P14 or greater 600E MHz 100 MHz 256 KB P14 or greater 550E MHz 100 MHz 256 KB P14 or greater 600 MHz 100 MHz 512 KB P12 or greater All board revisions support these processors 550 MHz 100 MHz 512 KB P07 or greater 500 MHz 100 MHz 512 KB P07 or greater 450 MHz 100 MHz 512 KB P07 or greater Pentium® II processor 450 MHz 100 MHz 512 KB P01 or greater 400 MHz 100 MHz 512 KB P01 or greater 350 MHz 100 MHz 512 KB P01 or greater 333 MHz 66 MHz 512 KB P01 or greater 300 MHz 66 MHz 512 KB P01 or greater 266 MHz 66 MHz 512 KB P01 or greater 233 MHz 66 MHz 512 KB P01 or greater Intel® Celeron® processor 433 MHz 66 MHz 128 KB P01 or greater 400 MHz 66 MHz 128 KB P01 or greater 366 MHz 66 MHz 128 KB P01 or greater 333 MHz 66 MHz 128 KB P01 or greater 300A MHz 66 MHz 128 KB P01 or greater 300 MHz 66 MHz 0 KB P01 or greater 266 MHz 66 MHz 0 KB P01 or greateri hope that this solved your request.
Sergio
Mar 13, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Computers & Internet Logo
47 people viewed this question
Top NEC Computers & Internet Experts
Ekse
Steven Wander
Steven Wander
Thomas F. Schneider
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
