Question about Samsung SyncMaster 920NW Monitor
Entire display area shifts down and the bottom toolbar is not accessable at 1024 x 768 resolution. Black strip appears across top of screen. No problems at any other resolution.
  • beth67 Aug 14, 2008
    Reloading drivers fromt he supplied disk didn't solve the problem, but have since loaded updated drivers from the internet and the issue has been resolved.
  • peegeecee Dec 17, 2008
    I am using Samsung Syncaster 920NW for my MAC G4 power pc. I have problem in display. I am not able to set 1440x900, due to this problem my screen is not proportioned correctly. Can you help me?
    Sergeant:
    Champion:
  • 225 Answers
Good morning! kindly review the operations manual included when you bought the unit, takeing note on the best set-up settings of the display properties. Otherwise, you may opt to set it to other resolutions that will support the best display. best regards.
Posted on May 02, 2009
Samsung syncmaster 920nw black color has no definition. color looks muddy or bleeding.
In the first instance I would check all connections. It could possibly be a wire not making proper contact. If that doesn't help, then look for the degauss or restore option on the monitor!
Nov 20, 2017 | Samsung SyncMaster 920NW Monitor
Hi I Got a Samsung SyncMaster 920NW the display
If you are saying that it powers off in a few seconds you most probably have a bad (internal) power supply.
Jul 12, 2010 | Samsung SyncMaster 920NW Monitor
Samsung SyncMaster 920nw suddenly went black now squeaks/flickers
The 920nw did have a 3 year warranty on the unit but they will be out of warranty now. The flickering power light is an indication of a failure in the power supply board. When the board fails it can't start up correctly and the power shuts down over and over so you get the blinking light and no display. This is a very common failure point on all LCD monitors after a few years of use. There are parts called capacitors on the power supply board and they filter the output power. When they fail the power is not properly regulated and the power supply shuts down and tried to restart so you get the flashing. Here is a link to a repair guide that will show you how to dis-assemble the unit and then what to look for and replace to get it back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
The repair guide has pictures and videos to guide you through the repair.
I hope this helps, if so please rate my solution.
BuddyMc
Nov 14, 2009 | Samsung SyncMaster 920NW Monitor
Water in LCD display
Once you get a dead pixel (black dots), there is no way to repair that part of the screen
Sep 20, 2009 | Computers & Internet
Samsung 920nw display stay only one min and off but power on
This is due to backlite problem of LCD panel.
You may approach authorised service center for this issue they will solve your problem. Do not try to do yourself unless you have sufficient experience on LCDS.
Aug 05, 2009 | Samsung SyncMaster 920NW Monitor
Samsung SyncMaster 920nw - Resolution problem
please try to check / use the display adapter device (like nvidia if this is installed in your PC) settings control panel instead of the System->Preference->Screen Resolution option then you can obtain the desired graphics display. best regards
May 16, 2009 | Samsung SyncMaster 920NW Monitor
Oblong pictures
The issue here is that you have a low resolution picture and a high resolution display. Windows is "stretching" the smaller, low resolution picture so that it will fit across the larger area, thus distorting it. Right click on the desktop and select properties. Go to the Desktop tab. There should be an item there for position. Is it set to Stretch? If it is, then this is causing the problem. Set it to center, and it should appear fine. If you want to keep this from happening: 1) User higher resolution pictures. 2) Turn down the resolution on your screen (this can be done from the Settings tab of display properties).
Oct 01, 2006 | Samsung SyncMaster 940BE 19" LCD Monitor
Samsung SyncMaster 920NW Monitor Logo
486 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
