Question about Sharp Microwave Ovens
For Model no. R-209KK-W The touch pad does respond, the light does not come on and the clear pad does not work.
  • Sharp Master
  • 9,098 Answers
We repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 18, 2008
My GE Advantium microwave is beeping about 5 times every 2 minutes or so. The display says, "Keypanel Shorted. May need service. Press CLEAR to continue." Ironically, I need a working keypanel to press...
check the touch pad or control unit any short circuit in the control unit, other wise any moisture at control unit chec the circuit other wise replace the touch pad.
Jan 28, 2014 | GE Advantium SCA2000B Microwave Oven
Sharp Carousel Model R-209KK-W is flashing all 8's and keypad not working
The first thing to try is to do a hard reset.
Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still doesn't work, it may need repair, which can be done for $39.95 in most cases.
Jun 10, 2012 | Microwave Ovens
Touch pad is loose at the top. The upper choices don't respond to touch. The bottom choices will respond. How do you reattach the pad?
I would think that the touch pad will need replacing.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 09, 2010 | KitchenAid KHHS179LSS Convection /...
GE model JVM5503 (1980): light and exhaust fan work, but touch pad does not respond to pressing buttons and therefore no functions can be initiated.
That would be a problem with your "touch control" but it is no longer available.
The oven will have to be replaced.
Sounds like it had a good run.
Jan 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Touch pad not responding
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Nov 23, 2009 | Whirlpool GH6177XPS Microwave Oven
How do I get it out of lock mode
If the model number you have listed is correct, you turn the Child Lock feature on/off by pressing and holding the "Clear/Off" button for three seconds. The instructions are on page 28 of the Owner/Operator Manual.
If your model number is different from the one you have this question posted under, please post back with your correct information so that I may be able to provide you with better assistance.
I hope this helps you.
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Touch pad doesn't work
ut the tech sheet did mention that intermittent F7 problems are usually caused by poor connections. So I pulled the ribbon connector off the control board and cleaned the copper connectors using a pink pencil eraser. That whupped that puppy! But then I went out on another service call, same oven, different house. The pink pencil eraser trick didn't work on this one so I had to apply some of that famous Samurai gray matter. To identify the problem on this one, I cut power to the range and disconnected the ribbon connector that connected the touch pad to the electronic range control (ERC) board. Then I re-applied power and let it sit that way for 24 hours after which the customer was instructed to call me and report on the error code status of the oven. If no error code was reported, I knew the touch pad was the problem. If, on the other hand, the F7 error code came back, then I knew the (ERC) was the culprit. In this case, the error code did not come back during the test period and, using my keen, Vulcan-like powers of deduction, concluded that the touch pad was defective. I replaced the touch pad and problem solved!
Mar 15, 2009 | GE Profile Spacemaker Over-the-Range...
No Manual for My Sharp Microwave Model #R-209KK
Go to http://www.retrevo.com/. Enter your make and model number. You'll have to register but, it all free. Good luck.
Jan 02, 2009 | Microwave Ovens
Microwave Ovens Logo
239 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
