I have an LG 32LT75 the one with a built in PVR (DVR) I have good signal strenght through my digital ariel, however the freeview keeps freezing and locking up/blanking etc. To reslove this I have had to restore factory settings. This is okay once in a while but I've had to do this 17 times in 1 day (not good as a football fan!) it was purchased from Curry's and they have had serveral techs visit my property and I have had the main board replaced twice now to no avail. Is this issue something you have seen before and is there any known fix that can be done or should I just take my TV back and get a different type?
  • Anonymous Oct 01, 2008
    asdfasdfsadfasdf
  • Anonymous Dec 03, 2008
    Every time I change the channel on this tv the picture will freeze. Sometimes for about 30 seconds, sometimes it doesn't come back. It doesn't sound too bad but it makes flicking through the channels impossible.
Just had our tv taken away for a firmware upgrade - seems to have solved the problem. We have relatives with same model, different batch & same problem - they are currently trying to get LG to sort. If still in guarantee, give LG a call. (Don't bother emailing for help - they replied to the email the day the tv was returned - technology not their strong point! ;-)
HTH
Posted on Mar 08, 2009
How to Get Freeview?
First check you have the right ariel on roof or you have a good indoor digital type.
Check you can get a good signal in your area, ask a neighbour perhaps.
Make sure your TV has Freeview receiver built in or capable of accepting HD Top box Freeview.
Tune your device...auto tune or whatever and save the channels to TV memory.
(If you have a Satelite dish you can get Freeview that way but you will need a FreeSat box)...Aim for the Astra 28 degree Sat, you will get stacks of channels and all the Plus+1s and even more stuff from the rest of the world which is good if you're learning Hindi, French, Russian, Chinese etc etc...English even
It's all very easy to get going...
Oct 19, 2016 | Televison & Video
Why does my pvr keep freezing
Sorry can't help on this. Presumably you've switched off/on at mains and checked all connections secure. Would a factory reset help, see tips how to do on fixya, although not sure if you would lose library data.
Aug 19, 2014 | Bush BTU500DTR 500GB Twin Tuner Freeview...
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
My mother in law has a 3 mth old panasonic tv with built in freeview that keeps going off saying no signal check ariel. ariel has been checked, any ideas anyone please
access the signal strength in the menus and see how it looks. Too strong a signal can also produce the same problems as a weak signal. If it shows full strength but poor quality then it may be too strong a signal.
Mar 23, 2013 | Televison & Video
Teac 32 inch LCD dvd combo, dvd is coming up with message "no signal" any ideas?
Usually means just that.
The input source you have switched to has no signal.
Does it have built in freeview? just plugging an ariel off the roof no longer works without a digital receiver.
Jul 11, 2010 | Teac (DW-224E) DVD Drive
Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Feb 05, 2009 | Toshiba Regza 42C3030DB 42 in. LCD TV
I HAVE A SAMSUNG LE40R7, I CANT GET DIGITAL CHANNELS ON IT ?
I TAKE IT YOUR WATCHING YOUR SKY BOX OR CABLE ETC THOUGH THIS TV..BUT YOU CANNOT NOT GET FREEVIEW..CHECK YOUR ARIEL PLUG GOING INTO THE BACK OF THE TV, THEN TUNE THE TV IN FOR DTV. NOT CABLE OR SKY ETC THEY WILL NOT NEED TUNED IN..THE MENU FOR DTV..IF THAT DOES NOT WORK..DO ALL THE OTHER TVS WORK OFF THE SAME ARIEL ON THE ROOF TO GET FREEVIEW ???
Nov 14, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Digital tuner
if the signal breaks up and the picture looks like small squares with audio coming in and out its 99% of the time signal / reception how old is your ariel it may not be suitable for digital.
http://www.freeview.co.uk/help/reception-viewing/q2
Nov 17, 2007 | LG 42PB4D 42 in. Plasma HDTV
LE32R74BDX
this is because most new lcd tv's have a poor tuner built in and require a stronger ariel, to pull in the analogue or digital signal. Check that your ariel is freeview capable whether using freview or not, as these ariels are better at pulling in the signal, or do what i have had to do and buy a mains plug in signal booster from Asda for about £6.00, this did the trick, especially if you don't want to replace an ariel costing about £30.00
Jun 13, 2007 | Samsung LN-R409D 40 in. LCD Television
Open Questions:
Televison & Video Logo
1,002 people viewed this question
Top Televison & Video Experts
