Question about Karcher 2500 PSI Pressure Washer
KARCHER HSD100DE operators manual
HI IVE GOT A KARCHER HSD1000 DE AND NEED A operators manual ?ALSO THE DETERGENT PIPES ARE MISSING CAN YOU PLEASE TELL ME WERE THEY GO TO AS I WANT TO PUT IT BACK AS IT SHOULD BE HAVE YOU ANY PHOTOS OR ADDVICE THANKS JIM
  • Anonymous Sep 03, 2008
    Hi, Im also after a user manual for the Karcher HDS1000 DE. Any pointers would be gratefully received.
3 Suggested Answers
SOURCE: KARCHER HDS 1000 de
hi jim i have the same unit diesel burner and diesel engine have you tryed a new accelorater cable?
Posted on Jan 08, 2009
SOURCE: my Karcher HD 1050 DE
could be allsorts. seals worn. ceramic pistons split, inlet manifold split( frost damage), unloader valve sticking, etc etc.
Put mains water pressure onto it and look for leaks, then run machine and see if it increases pressure, if not i would suspect unloader valve sticking.....
Not very familiar with the 1050 but i'm a service engineer for high press cleaning equipment...
Posted on Mar 09, 2009
My karcher isn't giving me hot water why? It's a hds 601c
Morning Chris Taylor,
You have an igniter/burner coil inside your system that has to be
functioning properly to have good combustion going inside the coils of your heater unit (very bottom).
I tried to pull the documents to see if yours was kerosene powered (like mine: not a Karcher)... but could NOT pull your HDS 601C up on the company site (Karcher.com, sorry... It's me & my new PC).
Poor water = de-lime water coil procedure
Cool water = No combustion, check kerosene, oil (burner fuel)... filter... (etc.) and check your spark!
If your air supply is insufficient to support great combustion your ignitor & fuel nozzles can get heavily built up in soot. My manual says to clean it with detergent & water... I have only ever used Berryman choke & throttle body cleaner.
All the precautions... don't hurt yourself!!
Hope this helps...
KARCHER HDS 601c ECO STEAM CLEANER BOILER HEATING COIL ELEMENT HEATER...
Operating manuals
http://www.ultimatewasher.com/download/hot-water-manual.pdf
May 01, 2016 | Karcher Garden
How can I get the detergent to draw into water stream. Maybe I am missing on its operation. Can you help.
to get detergent into the wash you have to have no pressure in the wand
it doesn't wash with detergent at pressure
Apr 08, 2015 | Karcher K4600T200
Water coming out of detergent pipe from top for karcher 3030 B jet wash.When i start using the jet wash there is not enough pressure and water starts coming out of detergent pipe.How can i stop water...
remove deterfent pipe,unscrew detergentnozzle carefully, inside is spring and ball bearing, clean and re-fit, replace if missing. spring on upstream (soap) side
Apr 03, 2014 | Karcher Garden
I have karcher k4.98. I can not get the detergent to come out. I have checked the trouble shoot in the manual and all items are ok. Any ideas ?
Just had the same problem, brand new machine, the detergent feed pipe was squashed under the bottle holder bracket!
Dec 30, 2012 | Karcher Garden
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
Karcher K2.19R unit will not dispense soap. Tried to blow out soap line with air compressor, but small clear hose just kept popping off! Unit sat for a couple of years, but rest of operation, water...
Sounds like it has been left with detergent in the pump and it has dried out and clogged. Always run fresh water through the detergent pump after use.
You will need to take the detergent pump apart or you may be lucky with water flushing through it.
Jan 19, 2018 | Karcher FactoryReconditioned K219R 1400...
LOST KARCHER INSTRUCTION BOOK, ARE INSTRUCTIONS ON LINE
Here is the offical link to manuals and warranty cards for the residential models of Karcher Pressure Washers
http://www.karcherresidential.com/us/Service/usermanuals.htm
Jan 22, 2009 | Karcher K2.26 Electric Power Washer
Karcher 2500 PSI Pressure Washer Logo
99 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
