I am a heating contractor out of Douglas, Mass. The boiler installed 3-5 years ago from Portland Group in Framingham, Ma.is a GT 210 A they do not sell your boiler anymore ( sorry to say )I do like your product. they are not helpful in to get me a out door sensor with a hot water feed sensor for controlling water temp. I think I would need a SV-matic ?? where can I get some answers and your product near me ?? thanks,, jim @ custom plumbing & heating 508-509-7227,[email protected]
    New Friend:
I'm not sure if this is the best option, but it helped me. You can try going to http://www.customcomfortinc.com/. I know you said you're a heating contractor already but I guess it can't hurt to ask.
Posted on May 30, 2013
2 Suggested Answers
SOURCE:
SOURCE: Compressor is showing ground fault
O.K. a breaker tripping.....it is hard to say cuz your facts are brief.does the breaker trip immediately when you try to reset the breaker? if so...the contractor's employee probably got the 2 "line" legs going to the same side of he disconnect. OR the high volt wire may have short to ground.if the existing wire is xtreamly old, the sheathing can crack and ground out tripping the breaker, quite possibly water may be in the conduit "finding" a crack and shorting out( the reason i bring this up is because a plumber was there.)
breakers often go bad over time....trip and reset the breaker at your panel. it should feel hard to move.there is a spring in there that has to be tight.if it doesn't make a good snap typr action.replace the breaker.they are cheaper than a new machine and they just go bad over time.
you'll have to get another qualified tech to check it out.i would try isolating the high volt circuit and go from there.
good luck.BEWARE OF THE SALESMAN IN TECH CLOTHING.make sure he is old, has dirty nails /uniform.that is a good indicator of a real tech.he may even be slobby too.
Posted on Jul 13, 2009
Tip
Gas Condensing Boiler High Efficiency Heating
Ultra high efficiency boilers have become one of the best buys in home heating. These high efficiency boilers have changed dramatically from the first pulse boilers that I had the privilege of installing twenty years ago. Today’s condensing boilers are much more reliable and will not shake and rattle the windows of your house like those old beasts did.
If you are looking to purchase or install a new boiler for your new or existing heating system then you need to look a condensing boiler to heat your home with. In the past twenty years the condensing gas boiler has evolved to be a reliable, very efficient way to heat your home.
Radiant heating systems with the right design feature can easily heat your home at temperatures that use just warm water. At these temperatures the water is pulling the exhaust temperature of the boiler to very low points. This gives you extremely efficient boiler operation.
The boilers of today are made to operate continually at temperatures of 100F or less. At these temperatures it is not uncommon to have the combustion analyzer give me readings of 98-99 % efficiency. To get these types of readings and still heat your home the heating system has to be designed to work at these temperatures.
The right condensing gas boiler coupled with the right heat transfer system to get the heat into your home the right way will give you the most efficient heating system possible with today’s technologies.
Do a bit of research and find a heating contractor that knows exactly how to install a condensing boiler with a radiant heating system properly. For your radiant heating system to perform well at these temperatures, your boiler will need to be installed in exactly the right way. There is not a lot of room for error when designing very high efficiency heating systems. To wring every BTU of heat out of the fuel that is being burnt means that you are also on the ragged edge of supplying just enough heat to the building to over come the heat loss of the building at any given time.
http://www.fixya.com/support/r3706364-gas_boiler_condensing_best_features
http://www.fixya.com/support/r3597748-the_extra_benefit_of_a_modulating_boiler
http://www.fixya.com/support/r3583943-condensing_gas_boilers__the_best_radiant
on Dec 24, 2009 | Heating & Cooling
Why does my water no come on in the morning when the programmer is asking it too and does in the evening.
Check the time clock is accurate.
If this is a condenser boiler [it has two water pipes to the outside] check that the pipe from the condenser is not blocked with ice, if so heat with a heat drier
Oct 17, 2014 | Water Heaters
Installed a year-and-a-half ago, problems so far: thermostat replaced on hot water tank within one month of installation, one pump replaced, leaking plug in the front of boiler with Dunkirk rep never
Its probably time for small claims court and a new company to install good equipment. Have a couple different companies/contractors give an estimate and possibly expert advice/witness you would then be able to use in court so you can get reimbursed from a bad company. Hope it all works out.
Apr 20, 2013 | Dunkirk Q90-75 Quantum High Efficiency...
Broken heat exchange in boiler leaking hot water onto pilot light
Maang, You are a year older than me, so lets see if I can point you in the right direction.(1) If you have access to the internet you should be able to find a manual for an "Ideal Classic Boiler".(I just did) but you'll need to print it out - 40 pages. (2) It is 12 years old and is past it's half life. You might consider a whole replacement boiler - installed by a professional contractor rather than replacing a cracked section of the heat exchanger. Any equipment is only as good as the installation and proper setup when it is new. (3) You should NOT be smelling any gas in the house, period - unless you have a leak. You may be smelling carbon dioxide which is from burning fossil fuels - escaping from the crack in the heat exchanger. (4) What happened to the "Warranty" ?. Before you blow yourself up, Don't try to light the pilot anymore. Call a legitimate contractor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dan_77d17b8918f54455
Mar 29, 2017 | Heating & Cooling
Baxi 3 Solo Boiler will not ignite
it could just be the presure switch try bridging it out and see if burner lights
Sep 10, 2009 | M20 X-Treme Radar Detector
Repressurizing my boiler
take your pick from video or text
How to Repressurise a Heating System with an Internal Filling Key ...
? 3:30
https://www.youtube.com/watch?v=zUsBw1ZpiKY
Oct 27, 2010 - Uploaded by Worcester, Bosch Group
This video shows you how to repressurise your heating system using your Greenstar gas boiler's internal ...
Repressurise Worcester boiler - YouTube
? 4:12
https://www.youtube.com/watch?v=K6fH4XfGgxo Nov 10, 2012 - Uploaded by Rory Macfarlane
This video demonstrates how to repressurise a Worcester combi boiler on the.
Product Troubleshooting Videos ' Worcester, Bosch Group
https://www.worcester-bosch.co.uk > Support > Troubleshooting > Videos How to repressurise a heating system with an internal filling key ... how to repressurise your heating system using your Greenstar gas boiler's internal filling key.
How to top your Worcester combi boiler up - Gas Care.
www.gascare-heating.co.uk/topping-pressure-worcester-bosch-combination-boiler/ Aug 4, 2014 - If the needle on the pressure gauge on your boiler has gone into the red or down to zero it means there is little or no pressure left in the heating system and it needs to be topped up ASAP. So here's Gas Care Swansea's guide to refilling your Worcester Bosch combination boiler through the internal filling link.
How do I re-pressurise my Worcester Bosch boiler? - My Plumber
www.my-plumber.co.uk/blog/how-do-i-re-pressurise-my-worcester-bosch-boiler/ Sep 1, 2015 - 6) Check the pressure on the pressure gauge. When it reaches between 1 and 1.5 bar, it is time to turn the white knob back to the right to close the valve. Be very careful not to over-tighten. 7) Turn the filling key to the left until the arrow lines up with the open padlock and remove the key.
May 12, 2017 | Heating & Cooling
Have an oil fired boiler for baseboard heat and it also has a tankless heater for domestic hot water. No heat being called for only getting hot water for use. Boiler goes to 210 degrees before it knocks...
These boilers usually have multiple controls. The control that would take it out of the circuit at 210 degrees is a safety.
You should definitely have a professional take a look at this unit before you continue using it.
Sep 18, 2008 | Heating & Cooling
Heating & Cooling Logo
129 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
