Follow-Up to Hard Drive Question. (Tony Budz)
Because I'm strictly a novice with computers, I need to ask a follow-up question. In your answer that you posted on August 12, you said to interface the infected drive to ide 0 or ide 1...The problem is I don't exactly know how to do that; Where do I start? Also, the fact that the drives are SATA, does this matter at all?
Thank You again,
RT
  • aa8r Mar 01, 2009
    Which set of pins are used to select Master and which are used for Slave?
    thanks..
If its sata ide 0 and ide 1 wont be there! just plug in the sata drive on the plug in the mob that says sata 2.. basically, plug the drive into the other available sata slot... make sure the pc you're plugging into has av and is updated, then scan the slave drive from the pc (i would do it twice), also, run antispyware (twice)... once done and the drive is clean, personally, i would copy all the files across you want to save (in case anything bad does happen); then unplug the drive and plug it back in - if the worse happens and windows wont boot (sometimes its so infected it takes systems files with it) and you've saved all your work - personally, i would just reformat and start again then copy the work across... it could probably be saved, but a lot of the time its quicker just to save the work and format
Posted on Jan 02, 2009
  • 162 Answers
I'm not sure what he's asking you to do, but if you have a drive that's infected with a virus you can slave it to functional drive that's not infected as long as the functional drive is protected with software. Then you simply plug it into the ide chain and make sure the little jumper settings next to the ribbon are set to slave and the good drive is set to master. This is what he means by ide 0 and 1
Posted on Nov 14, 2008
6ya staff
SOURCE:
I NEED HELP RELOADING MY COMPUTER WITH WINDOWS XP
Ok if you are a complete novice like you say it may be a little hard to explain everything on here. Your heading say you need help loading windows xp. While the body says you need help cleaning it out and reloading it. It has been a while since I loaded windows xp on my computer but it came after losing a hard drive. I seems like I just put in the new hard drive and put the windows installation cd and when I started it, it just went through the steps of installation. However if you have a working computer and you want to clean it up, you may want to save some files off your computer before you just wipe it out. You should make a recovery cd, you can go through help menus to do this just type in "recovery cd". You can format your drive, go to programs, accessories, command prompt. If you open that up it looks like the old dos system, if you type in "format c:\" then enter it will wipe everything off of your hard drive. So my suggestion is this: find a friend/ neighbor that is a little computer savvy and ask for some help. It may be as simple as deleting your temporary internet files and cookies to get you running faster, which I think is what you are really after. Now that I've written a book I hope this helps. Please rate my answer so I get points for it.
Jan 22, 2012 | Computers & Internet
Im trying to put vista on my new hard drive and vista is asking for a driver for my hard drive?
ok insert the disk shut down the computer .
restart it may ask if you want to boot from cd push any button.
follow the on screen prompts.
job done takes about an hour.
Oct 06, 2010 | Samsung (SP0822N) 80 GB Hard Drive
My hard drive crashed and my laptop is only a year old and just went out of warranty what can I do? I have a xps studio 16
Your question is fairly open ended so I will answer in general. Feel free to follow up with me by responding to this answer if you need further advice.
If you have your personal data backed up you can simply take the laptop to a local PC shop and ask them to put a new hard drive in it. Laptop harddrives average about $100, then either pay them to re-install using your dell recovery disks or you can re-install the laptop yourself using the recovery disks dell provided.
If you need data off the old hard drive, ask the techs there to check the drive to see if it's working, if it is and only windows has crashed you can have them put the drive in an enclosure, making it an external drive and you will be able to sift through it and find your files once you XPS is running. If the drive is not accessible ask them for any information they can provide regarding the failure and reply back. I am a data recovery expert and can advise you on your options if this is necessary
Chris.
Sep 20, 2010 | Dell Computers & Internet
Hi there !!! problem with an external hard drive 500 gigs no software to mount it..it's not being recognized, shows problem input output conection... please advice, tx \ Dario R
If the hard drive is new, it needs to be formatted firts before you can use it.
You have to right click on My computer (Windows XP) or Computer or Pc (Vista and 7)
Select "Manage"
A new windows will open. From th elist on the left select "Disk Management"
The new hard drive will be visible with a red mark on the left.
Right click on the red mark and select Initialize the drive.
Follow the wizard.
Once the disk is initialized, the red mark will dissapear.
On the same drive, go to the right on the white area and right click it and select New partition.
Follow the wizard.
You're done.
Don't forget to rate this answer if it helps
Sep 17, 2010 | Toshiba Computers & Internet
My 500 GB WD external memory stopped being recognized by the computers. What can I do to retrieve the data?
If you get no joy using the Troubleshooting Guide then try this...don't worry if you are a novice like me, the thread is very easy to follow.
Check You Tube for dismatle of your type of External HardDrive 1st then follow step guide after,
My neighbour has the Seagate FreeAgent Desk 500GB (Externel HardDrive), and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t​=84 Thread can be found in 'Technical' under 'General Technical Issues' Dont worry if your a novice like me with computers, the guide is quite easy to follow...
Aug 21, 2010 | Western Digital My Book Essential Edition...
Format my computer
You can format the computer with the restore discs that came with the computer or with windows installation cd. you can format the hard drive / computer in the setup, it will format the hard drive as you go forward, it will ask if you want to format fast or slow etc.
let me know if you need anything else.
Ekse
May 05, 2009 | Acer Extensa 4620 Notebook
I cant install my creative live web cam
Hi
please follow me with following stepes so you can solve this problem.
since there is not enough informations on your question , so we start from begining.
plese click on start from popup list click on control panel .and open it,
chose add remove programs , make sure if your web cam is listed or not , if it is please click on remove and follow the screen.
after removing ,
duble click on my computer icon and chose Drive C ,if it is your main hard drive (mostley C is main hard drive with oporating system instaled, if not chose what ever letter shows your main hard drive)
doubl click omn it and click on progaram files , from next page find your webcam folder and delet it ,next emty your trash bin,
reboot your pc , and put your webcam CD in cd drive (do not conect your webcam) after instaling driver out of cd ,if it asked you to conect your webcam during driver instalation do so please,).
if it did not ask you , finish your instalation reboot (restart)your pc , now conect your webcam,
wait until windows find your hardware and follow the instructions.
i hope this solve your webcam problem .
if you need more assistanse please let us know.
thanks :Marco
Dec 13, 2008 | Creative Labs WebCam Live!
Have 'word' documents on MP3 player, now player wants to be formatted
I have recovery software on an on-line site...files anywhere...If it is not being read correctly, you can download this software by contacting me directly at [email protected] and I can send you a link, or you can down load a linux distribution called "Puppy" and burn this on a live cd, then boot computer from the cd follow prompts use vesa for vid display, single click on drives, "mount" the usb drive and access the flash drive that way. But easier to just download my recovery software and save all data from usb drive to your hard drive.
Linux can be problematic for the novice.
Mar 02, 2008 | Audio Players & Recorders
Open Questions:
TEXAS 1-************ Crypto phone Number Crypto is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Crypto email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Crypto support number When you are using the Crypto for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Crypto support number and ask for the help. Once you dial the Crypto customer support number, you come in contact with a team of experts at the Crypto customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Crypto support phone number will help you with that simply and quickly. This is Crypto's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Crypto agent. Features of Crypto support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Crypto customer support phone number. Here are some of the features of customer service: The Crypto customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Crypto customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Crypto provides you the facility of Crypto support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Crypto. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Crypto Customer support number team.
Oct 22, 2019 | HIS Computers & Internet
ALABAMA 1************ Crypto Number Crypto is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Crypto email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Crypto support number When you are using the Crypto for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Crypto support number and ask for the help. Once you dial the Crypto customer support number, you come in contact with a team of experts at the Crypto customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Crypto support phone number will help you with that simply and quickly. This is Crypto's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Crypto agent. Features of Crypto support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Crypto customer support phone number. Here are some of the features of customer service: The Crypto customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Crypto customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Crypto provides you the facility of Crypto support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Crypto. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Crypto Customer support number team.
Computers & Internet Logo
440 people viewed this question
Ekse
Marvin
Marvin
