Question about Lexmark P6250 All-In-One InkJet Photo Printer
Lexmark 6250 Hi, the paper feeds through normally and it sounds like its printing but the paper comes out completely blank
    Problem Solver:
  • 5 Answers
Sounds like an print cartridge problem. On your computer go to "start" "programs" "Lexmark all-in-one" and use the troubleshooting guide to make sure your cartridges are installed correctly, how to clean/refresh them, and how to clear the nozzles. Hope this helps.
Posted on Aug 15, 2009
I had a bad printer jam about a year ago and was able to pull the paper out and get it to feed through and everything. The ink levels appear to be fine, and it seems like the printer is working when I send...
Hi!
Normally when a printer tends to not be used for a while the print head or cartridges dry out!Try replacing the cartridges if you have not done it yet!
Good Luck!
Jan 13, 2011 | Lexmark X2670 All-In-One Printer
Hi, I'm having a paper feed problem. When I go to print it will feed the paper in mid way then stop and no longer take the paper to feed???
Remove all paper.
Check for any particals of old paper and dust in tracks.
Blow tiny dust away or use vacuum cleaner
Insert a little paper.
Go into maintenance mode to check all is working OK.
Try printing normally again.
Jan 03, 2011 | Lexmark Office Equipment & Supplies
Printer will not print!
You have a problem with the inner PMX motor inside your printer.
Call HP support
Nov 17, 2008 | HP DeskJet F380 All-In-One Printer
Will not Print
Try a hardware check of the printer first. To check the hardware of the printer, do the following:
  1. Switch off the printer.
  2. Load one sheet of paper into the paper feeder.
  3. Press the Power button and the Paper Feed button at the same time and hold them both down for three seconds. Then release the Power button only.
  4. When the printer begins to print, release the Paper Feed button. A page will be printed. The page should contain some text at the top and a series of horizontal color lines (cyan, magenta and yellow) below the text, with a thick black line below the colored lines. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not switch off the printer, it will continue to print.
Sep 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printer has suddenly stopped printing envelopes
Just fixed it thanks to Lloyd at Lexmark.com Go to Technical Support > LIVE CHAT. To print envelopes all I needed was to check the print in "Black" only button. Under Quality make sure the Print Color images in Black box is checked, select Apply and OK.
Jan 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X1185 printer will not print color......everything else works fine
the ink is clogged not the cartridge but were the ink feeds into the printer. there should be a cleaner tab in the printer preference tab if available
Jan 08, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
No ink coming from cartridges.
Sounds like maybe the nozzles are clogged up. Try using the printer maintenance utility to "Clean Nozzles". I think for most Lexmark printers it is call the "Lexmark Solution Center" in your Windows Start Menu. If that doesn't work, try maybe wiping the cartridge with a damp paper towel at the place where the ink comes out.
Apr 15, 2007 | Lexmark X2250 All-In-One InkJet Printer
Lexmark P6250 All-In-One InkJet Photo Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
