My Orbit portable dvd player model: PTDVD-768DVB will not work, the tv works fine but the dvd will not work, the disc does not spin at all.
    New Friend:
Obit portable DVD player doesn't power on and the battery is missing how can construct the battery using other battery cells from backup battery.
Posted on May 09, 2015
  • 1175 Answers
SOURCE: my portable dvd player shows no disc when i put my dvd in player
Very lightly clean the laser lens ( looks like a very small eyepiece)
with 91% or better alcohol on a swab. Then very lightly dry it off.
Also..have you tried another DVD or CD in it?
Check for dust or debris in where the laser pickup is
Posted on Feb 25, 2009
silly girl
  • 513 Answers
SOURCE: reading but DVD is not spinning in portable dvd player
Some suggestions assuming you know you're using good discs, and have this problem with more then 1 disc. In anything that requires you to open the player and play around in it, I also assume you're not too akward with electronics, and out of warranty: spindle motor problems - you could either fix that by changing the motor, or occasionaly by dropping a little bit of 3 in 1 oil on the shaft. Just dont start it as a hobby if you can still go complain at the store... Good luck
Posted on Jan 30, 2006
  • 752 Answers
SOURCE: insignia portable dvd player: disc not spinning
The laser has become damaged/worn-out. There is no fix for it as replacement parts are not made for it.
Posted on Sep 23, 2007
SOURCE: Portable DVD player not spinning says no disc
I have the same problem with a home dvd player. Why can't anyone get this fixed and why isn't support helping?
Posted on Jun 17, 2008
  • 563 Answers
SOURCE: No valid disc message displayed. Disc is spinning.
When a DVD player starts doing that, it either needs to be cleaned, or something is going wrong with the DVD mechanism inside of it. You can purchase DVD lens cleaner from any large retail store that has an electronics section. However, if you clean it and the problem persists, it will likely be cheaper to replace the unit rather than trying to have it repaired unless you're under warranty in which case any repair or exchange will be covered by said warranty. If you call the manufacturer they will give you your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 04, 2009
I have a digital labs model K715 dvd player. when i put a disc in, it spins, screen say its loading but will spin, stop, spin and stop again. Wont play the disc.
Try doing the following...
Making sure the "line select" has been switched from "in" instead of "out". Once you switch it back to "out", the player should work normally.
Mar 05, 2011 | Insignia NS-PDVD8 Portable DVD Player
I have a Durabrand dual screen 7" portable dvd player Model PDV-722. Has worked fine for over a year. Now it just spins and says loading. Then it will say disc error. I have tried several discs and have...
Looks like your optical sensor is gone. And considering the price of the PDV-722 replacing the optical unit is not an option. By the other hand I have a burned slave monitor and I would be happy to buy yours to complete my set, which is reading DVD's very well.
Sep 19, 2010 | Durabrand DUR7 Portable DVD Player
DvD Player will not play disc
The discs got warped due to heat.
Sep 05, 2017 | RCA DRC629N Portable DVD Player
Disc does not spin and shows on screen that there is no disc
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Portable dvd says bad disc
i have RC185 DVD/VCR COMBO when i open the power its showing hello only
i cannt operate ...........may be there is any code i purchase from lot...
Feb 27, 2009 | Yahoo Diamond Vision DVDC803-04 DVD Player
Won't load disc
Not sure exactly what happened, but the unit works beautifully now. Perhaps cleaning did the trick? spinning definitely got it to work manually. After sitting an hour or 2, I tried it and all worked fine, CD's and DVD's too.
Jun 12, 2008 | Coby TF-DVD7005 Portable DVD Player
Polaroid pdm-0732 wont read dvd
I just solved my issue. My 2 year old son set the AV switch on the side of the player to 'in'. I switched it to 'out' and now it works fine.
Nov 25, 2007 | Polaroid PDM-0732 Portable DVD Player
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
