Question about Cameras
I have got a new memory card for my finepix camera and it says i need to initialize it how do i do that please
  • 10,594 Answers
Initialize the card means format it by going in camera menu item, format option is there.
Posted on Aug 12, 2008
Benimur
  • 6966 Answers
SOURCE: Memory full
As you posted, both cameras have their memory full then you need to free up the internal memory either by deleting the contents or transferring them (the pictures) to your computer.
To transfer to your PC, you would need the installer/driver CD that came with the cam as well as a USB cable. You need to run/install FinePix Viewer prior to the USB connection. Follow on screen instructions. When asked to connect the cam do so. All others are explained with illustrations on the User's Manual. A copy od the A700 User's Manual is available here.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 14, 2007
SOURCE: card not initialized
Kyle850. I have a fujifilm finepix camera myself, and just recently had the same problem. The camera worked fine until one day I turned it on to take a picture and there was the "card not initialized" message. To fix the problem, just turn on your camera, push the menu button and use the right/left arrow buttons near the zoom button in the top left corner of the camera. Push the right arrow button until you come to the "option" window in the camera's view finder and use the "up" function of the zoom to highlight the "set-up" window. Press "ok", and use the right arrow button scoll over to the "2" tab and press the ok button again. Then use the "up/down" function of the zoom button to scroll down to the "format" tab. Press ok button again and use the "left" button near the zoom in and out button to highlight the "ok" option in the format window. By pressing the ok button here, it will reformat and reinitialize your picture card. If you do have pics already on your pic card, you may want to take your pic card to a photo center and see about recovering these pics before you go through the reformat process because there is a good chance that when you reformat your pic disk any pics on it will be gone. Good luck. SG
Posted on Mar 09, 2008
SOURCE: screen reading memory card not initialized
I bought a new memory card for my finepix A330 camera When I turned on the camera after putting in the new card, the screen read "card not initialized" and won't take photos.my son is going holidays 13/9/08 could you help me please Alex Richardson
Posted on Sep 11, 2008
The trouble with trying to format large cards of 1Mb or 2 Mb is that in order to do so you need your original card or a card that currently WORKS. I have one of 16 Mb. Go to Fujis web help page and download the firmware fix "FinePixA340" to your PC. Run and extract the data file "FPUPDATE".Now you have to put this file onto the old card. I pasted it so it was "beside" the DCIM folder ( NOT the next one down 100_Fuji folder or it won't work). To copy and paste you may have to connect the camera to the PC or use a XD card reader/writer via a USB port. Having done that, put the card back into the camera if you used a XD writer and switch off the camera. For the next bit make sure your batteries are good or connect to a power supply. Hold down Disp/Back button and THEN turn on camera. It should have detected the new firmware data file. Follow the simple instructions-say yes and let the data file load--takes a few minutes. The camera should say the new version !.22. Now that the firmware has been updated , you can now format your NEW LARGER cards 1 or 2 MG. So take your old card out ,put the new card in and format. It worked sweet as a nut for both 1 and 2 MG. The trick is to use a card that already works,load firmware file onto this , update file onto camera, then format a larger card. Its what they don't say exactly that causes frustation. Happy formating campers
Posted on Dec 04, 2008
Steve5
  • 423 Answers
SOURCE: How do I initialize a
Your A330 is not compatible with the XD cards that start with an "H" or a "M" before the XD designation, unless you perform a firmware upgrade. You can do it yourself using this link from Fuji Canada. http://www.fujifilm.ca/x13573.xml
Posted on May 01, 2009
I have not used my Fuji Finepix 6800Zoom for many months so I charged it up and now when I turn it on 'ERR CARD' is displayed in the round screen. If I press Menu and then Back !card not...
May be you inserted a memory card formatted with your PC. Format the memory card using the Format function in the camera menu. Format function can be found in the setup menu of the camera.
If this does not work, try replacing the memory card.
Sep 02, 2011 | Fuji FinePix 6800 Zoom Digital Camera
Camara says card not initialized can i solve this problem or do i need a new memory card finepix f480
You need to do this with all new cards. Go into the menu and find either "format" or "initialize" and follow the on-screen instructions. This erases the card and prepares it for the camera's operating system.
Aug 02, 2011 | Fuji FinePix F480 Digital Camera
Fuji FinePix A330 Digital Camera How do I initalize my new 2G memory card Help PLEASE
Go into the camera menu and find "format" (may be called "initialize") and follow the on-screen instructions.
Jan 17, 2011 | Fuji FinePix A330 Digital Camera
Fuji FinePix A510, DPC-256 memory, card not initialized msg
I had to re-format the card losing all the photos but I had saved them in iPhoto so that was ok. I think the problem was caused by me incorrectly closing down after downloading them to iPhoto, so my fault and lesson learned.
Jan 07, 2010 | Fuji FinePix A605 Digital Camera
What if a new memory card wont initialize?
Hi
The reason you are having this problem is that the maximum size memory card supported by this camera is 2GB. Any card with a larger capacity - like your 4 GB card - can not be initialised by the camera.
For reference see
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Fuji/Fuji+Finepix+S7000+Zoom_Memory_Cards
Hope this helps. Please do remember to rate my answer. Many Thanks.
Jul 25, 2009 | Fuji FinePix S7000 Digital Camera
F480 finepix "card not initialized"
Sounds like you need a new memory card, ive had this happen to me on a works camera. When i replaced the memory card it was sorted
Mar 24, 2009 | Fuji FinePix F480 Digital Camera
Screen reading memory card not initialized
help me i also have the same problem please email me how you fixed the problem? cdcdcmiura@hawaii.rr.com
mahalo's
Feb 17, 2009 | Fuji Finepix Z20fd Digital Camera
Card not Initialized
Can you get into your camera's menus? If you can, there should be an Option under your Setup menu to Reformat card that might fix the problem. This happens sometimes with the memory cards, they just need to be reset. Unfortunately you can lose your photos sometimes when it happens, so if it's happening a lot you should buy a new memory card.
Jun 06, 2008 | Fuji FinePix A400 Digital Camera
Fuji finepix A340
a340 needs a firmware update from fuji to work w/xd cards that have a h or m on card-should work ok w/older cards-check mem card and update camera from website to make compatible w/new type card
May 21, 2008 | Fuji FinePix S5000 Digital Camera
Memory card problem
go into settings of your digi cam and use the format option , thats should solve your problem
May 20, 2008 | Fuji FinePix A605 Digital Camera
Cameras Logo
112 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
