When i try to burn a video file onto a dvd disc it says at the end that theres not enough room on disk, i use nero ultra, and 4.7 gb 120 mins disks
    Scholar:
  • 94 Answers
The file must be bigger than 4.7gb!
Use Nero Vison to create a DVD video, it gives you the option to make it fit the discs you are using. It will do all the converting required to play the disc in a consumer DVD player.
Nero Vision provides step by step instructions on how to do it.
Posted on Aug 12, 2008
I can't burn 2Gb even though my DVD is 4,7 Gb
The size of the file in MB. does not equal what is burned onto the disk. 4 x 600 = 2400 MB. but what is burned to the disk is usually more than what the file size equals. Try using a dual-layer blank disk and see what happens.
Feb 10, 2014 | JVC Computers & Internet
Tip
Nero 7 Ultra Advance-to-Time Index Problem Work-around
Posted under Nero 6 Ultra because there is no Nero 7 Ultra listing here on Fixya...
OK, I am going to tell you how I managed to work around this problem. I am posting this in the hopes it will save someone else the aggravation I had in stumbling around trying to find a procedure that would fix the problem. I found a work-around I can live with, so here's the problem and the solution follows. If it applies to you, I hope it makes your DVD-burning life livable again! Oh yeah, looks like Nero 8 is ready to come out soon. Just when you though it was safe.... anyway, here goes:
The Problem:
Burning DVDs using Nero 6.2 on Win ME was successful, and it allowed for advancing via time index. For example, I would burn a DVD and be able to go to any time point in the scene. However using Vista and Nero 7 Ultra, while DVDs burn successfully, the advance-by-time index is no longer available in DVDs burned under Vista with Nero 7. Details:
DVD burner: Buslink DBW1647-U2
O/S: Vista Home Basic
S/w: Nero, Ver. 7 Ultra, registered
DVD media: 16X Starlogic DVD-R
DVD player: Goldstar VM681M
The scenario is this:
1. Begin playing a chapter on the DVD
2. Click the chapter menu button on the remote.
3. Use up-down arrow keys on remote to try to get to timed index setting (ie, the one where if you select it and type "10:00" it will jump the scene to the 10:00 mark).
4. Can't select that option.
The Work-around:
1. Open Nero Vision and choose to create a DVD.
2. Access the Options by clicking More>> and make sure Nero SmartEncode is set to 'Disabled'. I think since Nero wants to convert everything to MPEG-4 that that might be a factor. Also, you may need to get some codecs, too. I am using the K-lite full pack available here: http://www.digital-digest.com/software/k-lite_codec_pack.html (Note that K-lite doesn't like other codec packs being on the same PC as it-- it nagged me to uninstall the DivX and Vista Codec Packs, and I did. I have discovered no problems so far since.)
3. Add your video files and step through the rest of the process. Settings to look out for: Automatically create chapters: NOT checked, Enable Forward/Backward Jumping: checked.
4. On the last screen, choose to Write to Disk instead of burning to the CD drive-- select a place to save the DVD-compatible files. Click "Burn" and off you go.
5. After your DVD files are written to disk (they will be in a folder called TS_VIDEO in the place you chose to save them to), fire up a copy of ImgBurn (http://www.imgburn.com/). [Maybe Nero's image burner will work too, I just haven't tried it. In any case this is known to work so I am using it here.]
6. Switch Mode to Build -- you need to build an .iso image file in order to burn it to DVD -- and select the TS_VIDEO folder holding your Nero-ed files. Indicate a name for the output file and run it. This should not take nearly as long as Nero took in creating the raw DVD files. The .iso file you created will be close to the same size as the raw DVD files are in the TS_VIDEO folder Nero created.
7. Now switch mode to Write and indicate the .iso file you built as the input and select the target DVD drive you are using, then run it. The burn process should not take long, either, compared with the other steps.
8. Test it in your DVD player-- you should be able to jump to time indexes now.
I have no idea why this works as opposed to the transcode-then-burn process that worked for me under Nero 6.2. There may well be other ways to deal with this problem, I just don't know what they are. Downside to this approach of course is that you need about 33% more disk space as compared with that required for transcode-and-burn (t-and-b: need space for the original files and Nero temp files; the .iso approach: need space for the original files, the DVD-compatible files Nero creates, and the .iso file created from that). However this is an alternate procedure, not a fix, and the only approach so far I have found.
Plenty of good DVD discs gave their lives to discover this process. I hope I can save you some misery and trips to the store for more blank DVDs by posting it here.
on Feb 22, 2008 | Ahead Software Nero 6 Ultra Edition...
What does memorex dual layer dvd+r mean? How do you record a movie that is over 130 min. We purchased 240 min just for this reason and we can not get it to record over 120. How do you finish recording the...
Well all DVD+R mean that when you finish copying files to the disk, the disk will lock itself and not allow any more files to be burned onto that DVD. The reason why you can'f fit your movie onto the disk is because the movie file may be bigger than the amount the DVD disk can hold. Just because the time of the movie is less than what the DVD can hold, doesn't mean its going to fit. Take for example a Blue ray movie, it may only be 120 minutes long but the file of the movie can be over 2 GB of space.
May 12, 2011 | Memorex Products - Memorex - Dual-Layer...
Vob ifo bup files to burn as dvd trouble
Try this:
Get the Nero 9 application
Install it on your computer
Create a Video Disk
And browse the folder of the VOB files Add it to burn the disk
Select Burn to burn the DVD ....
You may also try to put in a blank dvd and copy all the files on the DVD drive
Select burn these files on the disk
This should work
Regards Soumajit
Mar 12, 2010 | Computers & Internet
Copying video clips from the internet onto DVD
hi, you can find free codecs, which are pretty much the descrambler codes to play audio and video, on cnet.com go to downloads section and search for them. look for the free codecs they work the same as any others.
next. your gonna want to convert your videos to Nero Digital (MP-4 format) this makes it less chances of some videos not playing back, and the dvd not playing at all.
then follow steps in nero to convert them,
burn to disk using make your own dvd. just add the converted videos and burn. be sure to remember where you saved the converted videos.
Apr 24, 2009 | AMD Athlon 64 X2 4600+, 2.4 GHz...
DVD-R
maybe your DVD writer is not a multi/dual format (dvd+ & dvd-), check your writer if the print in front is "DVD-RW"(minus format) or DVD+RW(plus format),
for burning home movies and create a DVD so that you can play it to regular dvd player, i suggest to use xilisoft DVD creator.here is the download link, if ask for password on extracting. pw:www.dl4all.com
DL: http://rapidshare.com/files/164261293/Xilisoft_DVD_Creator_3.0.39.1114.rar
Ultra Burning Pack 4 [AIO]
Includes:
AnyDVD & AnyDVD-HD 6.3.0.0
CloneCD 5.3.0.1
CloneDVD 2.9.1.2
CloneDVD Mobile 1.1.6.0
Virtual CloneDrive 5.2.0.2
GameJackal Pro 2.9.18.610
Enterprise EE Client 2.9.18.600
Enterprise Manager 2.9.18.600
Alcohol 120% 1.9.6.5429
Nero 8 Micro (En/Ru) 8.1.1.4b
UltraISO Premium 8.6.5.2160
Free a.k.a Lite 4.11
Pro Advanced 4.10.218.0
http://uploading.com/files/LRPOVSVH/Ultra%20Burning%20Pack%204%20(AIO)_www.dl4all.com.part1.rar.html
http://uploading.com/files/B3GJG4GZ/Ultra%20Burning%20Pack%204%20(AIO)_www.dl4all.com.part2.rar.html
Feb 26, 2009 | Roxio Easy CD & DVD Burning
Nero 8 Ultra Edition - when burning a file from my hard drive with size of 997 MB, and after an hour of transcribing, the disc kicks out and i get a message stating thay i need to add a larger capacity...
So you're burning a file from your hard drive to a cd or DVD? What kind of disk are you using? You will need a DVD-RW for large files. Is the file video?Disks can only store so many minutes depending on it's specs.
Sep 28, 2008 | Computers & Internet
By mistake I bought a dvd rw disc instead of dvd-rw disc and recorded a holiday video on my camcorder with it. I usually then upload the contents of the dvd onto my hard drive (Pioneer) and then download...
Try uploading to your PC then converting it to AVI this keeps quality of video. Then if you want to download to a disk use Nero to convert it to VOB (DVD format) and burn off. You can also use Nero to erase the disk. (Nero 7 or more recent preferably.) You must also be sure you PC DVD read write head can take the DVD +/- RW. CHeck compatability.
Aug 12, 2008 | Computers & Internet
Cannot copy files to DVD disks
when i try to copy and paste file to DVD, through windows, a message appear says"windows encountered a problem when trying to copy this file." i dont know why, could someone help?
i'm upset now. :(
Dec 21, 2007 | Gateway GT4022 PC Desktop
Computers & Internet Logo
59 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
