Question about Epson Aculaser C1100 Printer
To replace toner
I have no idea where the toner is in the machine, and how to set about replacing it. A good diagram of the machine's anatomy would be most helpful!
    Brigadier General:
  • 6,966 Answers
Perhaps a copy of the parts diagram and/or the multi part service manual might be of more help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 18, 2008
I have a Ricoh Aficio 1013F that has a about 65000 copy count. I replaced the drum/imaging unit a few months ago. recently, we stupidly let the machine run a week or so while it was calling for a toner...
I think you will have to reset it ..and the procedure to follow is this..
take it slow and be sure it is the correct one ..If it seam not to work try again ..
Press "clear mode" key then enter107 then press and hold down "clear/stop" key, touch on screen for "copy" then press 5992 hit enter, touch 0 to print out the standard setting list, turn off the copier when you finish.
Aug 13, 2011 | Ricoh Aficio 1013F Copier
We have a Sharp Model AL-1631 unit that keeps running but doesn?t make copies. Any idea what is wrong and how to fix it? Thanks.
When these Sharp AL series machine just run and run it means they are low or out of toner. This is especially true if you are hearing a light thump thump noise while it is running. Just let it run and after 5 minutes or so it should shut down and then replace toner light should come on. This is the small red light that looks like a stack of 6 dots.
Either replace the toner or have your existing toner refilled.
Good Luck and Thank You for using Fixya.
Sep 17, 2010 | Sharp AL 1631 Copier
MFC-7840w keeps saying "toner life end"
After I figured this out, it was quite easy to resolve. Remove the toner cartridge from the drum cartridge. Remove the black plastic cover on the left side of the toner cartridge (3 Phillips screws). There is a "flag", which is a small plastic tab on the outer side set to the right at about 2 o'clock. Turn the gears until you fully reset the tab going counterclockwise to the 10 o'clock position (fully to the left). Reinstall the small black cover and the three phillips screws. And the idea to install black electrical tape over the small clear plastic windows on both sides is also a good idea to prevent the early and false message that the cartridge is empty. Make sure you do not allow that tape to get into the gears.
Sep 25, 2009 | Brother MFC 7840W Printer
Message says to add toner after I replace toner
Plunger from the top of the previous bottle is probably still stuck in the machine. Remove the toner bottle and check/remove .
Jun 29, 2009 | Ricoh Aficio 1013F Copier
COF36 error on a Bizhub C350
C0F36 error means abnormally low toner density detected Black ATDC Sensor. Check for the black toner and try reinstalling the cartridge if replaced already. And if the toner crtridges are empty then replace the cartridge.
Please do rate this solution as FixYa and revert for further assistance.
Apr 21, 2009 | Konica Minolta Office Equipment & Supplies
Copier Minolts ep4050 error code C0072 +
C0072 is aerror code for the sub hopper unit. It is having a hard time adding toner or that the toner motor is ON for to long. It is having a hard time kepping up with the ATDC. The M2 is a counter, it can be reset in service mode, but major parts have to be replaced to clear it..
Mar 25, 2009 | Minolta EP4000/5000 CS/PRO Copier
Memory received .toner empty samsung sf 5100
Replace the toner cart. Toner save mode only uses a little less toner while printing.
Feb 02, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Replacing toner
Check the developer.
Jun 17, 2008 | Ricoh Aficio 250 Copier
Toner Replacement
The cyan and magenta go into the machine through the same aperture as the yellow toner cartridge. The machine will automaticaly rotate the toner turret to the correct position when toner replacement is necessary for that particular cartridge.
Nov 14, 2006 | Canon imageRUNNER C6800 Copier
Epson Aculaser C1100 Printer Logo
71 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
