1. Check if you correctly plug in to 220v outlet.
2. Check if the motherboard power is enough the 12v and the main power should have the connection to the power supply.
3. Clean your Memory stick and put it back again
the problem of power off after startup can be caused by:
a Faulty ATX power supply (the power good signal was not prperly generated to the motherboad)
Cpu fan problem, the CPU temperature is abnormal
faulty motherboard
to solve this problem, first change your ATX power supply unit with the same power rate.
then clean the radiator and the fan. if the problem still not solved change your motherboad.
first open your cpu cover carefully ,by opening the screws once your cpu cover is opened then carefully remove the wire of the fan connected to the motherboad then open the screws of the fan and clean it then do the same just connect your fan to the motherboad and screw it up and its over make sure that your fan is working and its over
