Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Does not work at all! will not even fill with water!
I had the problem before where it would spin only but would not fill with water! I replaced the small fuse in the upper left corner of the lower cover and it was fine for 3 months! this time nothing happens! wont fill with water and wont even spin!@ is this the cover switch??
  • 1,031 Answers
  • Test the water level switch
  • Check that the drain hose is positioned roughly as high as the top of the inner tub
  • Before testing the water level switch, unplug the washer or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard. The water level switch (aka pressure switch) senses the water level in the wash tub. It does this through a plastic tube which runs from the switch in the control console down to the side of the outer tub, near the bottom . The tube is filled with air. As water enters the tub it also enters the tube. As water climbs inside the tube, it pushes on the air trapped inside and increases the air pressure. When the air pressure reaches a certain level, it triggers the switch.
    A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub.
    The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.
    Inspect the air tube for kinks, breaks or damage. The tube should also be free of water. The tubing should be securely connected to the bottom of the outer tub and to the bottom of the water level switch.
    The water level switch has three connectors. Label and disconnect the wires from the switch. Test the switch for continuity using a multitester Set the multitester to the ohms setting X1. It will be necessary to test each of the three possible pairs. For example in the image below, test pairs 1 & 2, 1 & 3 and 2 & 3.
    terminals.gif Place a probe on two terminals and note the reading. Now move one of the probes to the other terminal and note the reading. Finally test the third pair and note the reading. The multitester should display a reading of infinity or continuity for each test. In this test two of the pairs should read infinity and one should read near zero resistance (continuity).
    Now blow gently into the air pressure connection and retest. It should click and you must maintain the air pressure while testing. For the two pairs that read infinity one should now show good continuity. The pair that previously gave of reading of continuity should now give a reading of infinity.
    If the switch fails either of these tests, it should be replaced.
Posted on Sep 05, 2008
  • Starnley Johnwells
    Starnley Johnwells Sep 05, 2008
    pressure switch and the test pairs
Keeps filling up with water even on spin
Close the water supply valve and allow the machine to completely drain the water from the tub. Turn off the machine and disconnect it from the power outlet. Open the water supply valve. Replace the water inlet valve if water drips into the tub when the machine is off.
Start a new cycle if the machine stops filling when it is off. The control board or the water level switch is malfunctioning if it keeps filling even during the spin cycle. Indicate the model number for proper troubleshooting and repair assistance.
Feb 05, 2010 | Washing Machines
The washer will not fill or even give a sign that it is starting but will operate in the spin cycle.
trying filling on cold water setting only,then try filling on hot water setting only,if one side of the water valve doen't work you should replace it-mike
Jan 30, 2010 | Kenmore 22422 Top Load Washer
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Maytag Neptune MAH-1 won't stop filling with water
A couple things may be going on here... you may not want to hear, but the Neptune has a had many "consumer related problems".
If your complaint is "will not stop filling with water" I would access your inlet water-valve (typically blue with 2 black battery looking solenoids; where your water-lines connect directly), test for continuity and replace as necessary. Sometimes inlet-water valves also go bad where the complaint is: "no water comes in at all".
Jan 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
115 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
