Question about Brother Office Equipment & Supplies
Despite constant cleaning, the red cartridge will not print. Do you have a service agent in the central belt of Scotland where I can take it for repair. The model is MFC410CN
  • 2 more comments
  • ronniejreid Aug 12, 2008
    I am based in Scotland. All you addresses appear to be in the States
    I live in the UK. so please only send relevant info
  • ronniejreid Aug 13, 2008
    before replying please read my comments. US addresses are no use to me US phone numbers are no use to me. If this is a US site only then its no use to me. Thanks
    Finally got Brother service agent. Looks like it will be cheaper to replace than service. Thanks anyway
  • 75 Answers
BC Print Engineering Bill Clubb
9 Creskeld Park
Bramhope
United Kingdom LS16 9EZ Phone:44 0113 2619217 Fax:44 0113 2619218
Specialist Heidelberg printing engineer with over 25 years experience, extensive knowledge of letter press and offset machines
Beck & Pollitzer Engineering Ltd. Burnham Road
United Kingdom DA10 0NF Phone:+44 (0)1322 223494 Fax:+44 (0)1322 291859 Beck & Pollitzer is a professional engineering services contractor working in partnership with manufacturers and equipment suppliers around the world
Posted on Aug 13, 2008
  • 1,183 Answers
Following is the link for the brother support UK
http://www.brother.co.uk/g3.cms/s_page/68510
As per the description , if the printer is not printing RED, it could be a problem with the cartridge head. Have you tired changing the RED cartridge.
Thanks
Proton
    Brigadier General:
  • 6,966 Answers
Based on your description, clogged red printhead and would need forced cleaning or a service center inhouse work. Pls contact:
Contact By Mail:
Brother UK Ltd,
Shepley Street,
Audenshaw,
Manchester
M34 5JD
United Kingdom.
Tel: 0870 830 4000Fax: 0870 830 4001
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Master:
  • 623 Answers
Try calling 411 or 1800-555-1212 directory assistance
Posted on Aug 12, 2008
    Genius:
  • 3,422 Answers
Can you please give the zip code so that i can locate a service person.
Hp 2600n left not showing anything and whole page not sharp despite new cartridge
if you do not print on one side of page nothing appears that is not no color laser would probably be dirty and should be cleaned (by a specialist) would be another cause cartridges are running (check the status page of suplius, "menu" ), fuser problems, clean with a soft non-abrasive belt image.is usually recommended to replace all cartridges at the same time is not quality problem
Mar 29, 2011 | HP Color LaserJet 2600n Printer
Have not used my Epson R1800 for almost 6 months. When I turn on the power the printer head, with the cartridges, stayed at the very right end, not moving. The paper and ink lights flash and the head just...
Your User's Guide is available here:
http://files.support.epson.com/pdf/r1800_/r1800_ug.pdf
After leaving the printer inactive for a extended period you should expect the ink cartridges to be dried up and the print head 'gummed' in place.
You will need to refer to page 82 of the pdf, Cleaning the Printer.
As part of cleaning remove the existing ink cartridges and while the cartridges are removed try and clean the print head of any ink residue. Note that if the red light is on or flashing above an ink cartridge the printer sees it as empty (dried up).
The print head will not move if ink cartridges need replacement; replace ink cartridges according to the red lights, likely all. Press the ink button to see if the printer will begin the charging cycle. If all is well the green power light will stay on and the red ink light will go out.
If you do not get this desired outcome try Cleaning the Print Head, page 73 of the User Guide. Hold down the ink button when the red light is off for 3 seconds. Run a nozzle check pattern; if nozzels are not printing a clean pattern, repeat this process up to 3 or 4 times.
Feb 03, 2011 | Epson Stylus Photo R1800 InkJet Printer
Red speckles in the background of printed items
Hello Minnowillo!
Theres a few things you need to do first to determine what its causing the problem
Here are somo steps you can follow:
1) Print a Supply status report (Main Menu > Reports > Supply status)
If you still see the red speckles on this page we can tell that the problem is not on the computer
Check toner level on this supply status, if its showing lower than 10 % i would recommend to replace the cartridge
2) Run 3 Calibrations in a row (Main Menu > System Setup > Print Quality > Calibrate Now)
3) Run 2 cleaning modes ( Main Menu >Services > Cleaning Mode)
4) Access the secondary service by hitting the checkmark and the cancel button at the same time, then hit the checkmark again
Under the secondary service look for "Clean Belt" anr run it twice
Try printing again
As a recommendation most of this print quality issues are related to a defective cartridge (scratches on the cartridge drum) so if you have a spare cartridge i would start replacing it
If you determine that the problem is not the cartridge, that means the problem is with a defective roller and it will need service
Heres a link where you can find an Authorized repair center near to your location :
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
Jun 29, 2010 | HP Color LaserJet 2600n Printer
I've just bought an s520 printer secondhand but the prints are very grainy despite high quality print setting. Can't get the right nozzle check pattern on red or yellow even after deep clean. are nozzles...
Try a new cartridge, how good is paper your using, glossy sometimes does not accept ink welll.
Use some alcohol to clean bottom of cartridge.Rubbing alcohol if u have it. use a Qtip to clean inside printer
Jul 31, 2009 | Office Equipment & Supplies
PIXMA ip3000 printer is printing yellow instead of red
Clean the ink cartridge contacts with a moist tissue or glass/LCD cleaner clothe. Do the same on the printer cartridge holders. Do this gently and carefully avoiding further damages to your printer and it's cartridges.
Declog print heads using denatured alcohol for an hour or two or head cleaning agents available at any ink refilling stations. You can use a suction device included in the refill kit.
Try using another cartridge of the same type by borrowing from a friend, relative or member of the family and see if the problem still occurs.
Try removing the printer driver, restart computer then reinstall driver so that the default settings will be restored. If it still exist, you can google for iptool software and try resetting it's EPROM.
If the problem still exists, you need to go to the nearest service center.
Dec 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Hp officejet 6110 all-in-one won't print despite new cartridges
make sure that the housing that holds the cartridges are clean at the contacts, this can be done with the machine turned off and unplugged, clean the contacts with warm water and a damp cotton bud not wet and then dry it with a paper towel.
make sure everything is dry before turning the printer back on, if this doesnt work then it needs a service.
Nov 28, 2008 | HP OfficeJet 6110 All-In-One InkJet...
When printing the test page
there is a problem with your cartridge and the head of your printer, because if the software is telling you that the cartridge is full therefore it could be an hardware issue, i suggest that you should try to removing and reinstalling the cartridge, if that step still dont work then bring it to a service technician and ask them to clean the head of your printer!
Hope this one works!
But i know it will work. Be Positive!
Your good rating will be very much appreciated.
Good luck and thank you!
- claudus_07™
romaragregado@gmail.com
www.romaragregado.tk
Jul 26, 2008 | Brother Office Equipment & Supplies
Not printing despite new cartridge
spoke to canon agents. they say head is stuffed and printer needs service. +/- r900
Jun 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
120 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
