Question about HP Compaq nc6320 Notebook
HP nc6320 BIOS Power on Password
My laptop has a power on password. (Blue box password in Bios).
Could you please help me on how to remove this?
Thanks,
Darrel
  • Anonymous Sep 10, 2008
    yes i have the same problem, and i dont know how to remove this password, if anyone can do that then write here please or email me to: [email protected]
  • Anonymous Mar 23, 2014
    blue box pops up for bios password never happened before and don't know what it is
You Have to Remove RTC battery ( Cmos ) battery.
Wait approximately 5 minutes
Replace the RTC battery and reassemble the computer
Connect Ac Power to the computer. Do not reinsert any batteries at this time
Turn On the computer
all the passwords and all the cmos setting have be cleared.
Posted on Sep 23, 2008
SOURCE:
How to remove bios password hp compaq nx9030 device
Hi Adel,
I am afraid there is no way still to retrieve BIOS password but you may want to contact HP Support to check if they have ways to check that for you. Usually for the case you have it is replace MOBO already. Please check the number on the link below base on your location.
Contact HP Phone Assist HP Official Site
Apr 26, 2014 | HP Compaq nc6320 Notebook
Power-on password forgotten! How can the computer be started?
The Power on Password is set from the BIOS configuration. Ask that person who borrowed your Compaq for the password. Once you have this password, you can enter the BIOS configuration and remove/disable this password.
Depending how old you Compaq is, removing the BIOS battery and main battery for 15+ mins may remove this password and restore the BIOS to the factory default (insert both batteries again) and configure the BIOS Date and Time etc.
BUT if the the password is stored on an EEPROM chip then removing will not fix this problem. There are no backdoor passwords available.
Nov 19, 2009 | HP Compaq nx6110 PC Laptop
Crack bios password on compaq nc6320 - please
You can crack dell bios password with Windows Password Recovery Tool 3.o . Here is a good post to help you:
http://www.windowspasswordsrecovery.com/crack-dell-laptop-password.htm
Oct 09, 2009 | HP Compaq nc6320 Notebook
Need help forgot password for HP Compaq NX7330
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user passsword
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Please rate me .
Thanks .
Jul 29, 2009 | HP Compaq nc6320 Notebook
Compaq NC6320 laptop pc with "stringent" security power on password set. How do I get around this? RTC does not control this password.
remove the laptop battery and the plug to your bios (small) battery on the motherboard wait about ten minutes then plug the bios battery back in power the computer back up using the power supply not the battery then: shutdown and, reboot again after you have reinserted your laptop (large) battery; you should have all passwords removed.
May 17, 2009 | Computers & Internet
HP Compaq nc6320 PC bios password
Ok, as long as the high security level has not been set in the bios then the following will work to reset / disable the bios password.
1. Remove the battery and mains adapter.
2. Remove the memory cover on the back of the laptop and remove the 2 keyboard screws.
3. Open the laptop and at the top of the keyboard you will see 4 sliding tabs. They are located between the 'Esc & F1 keys' 'F4 & F5 keys' 'F8 & F9 keys' and 'F12 & delete keys'. Slide these down and lift the keyboard up and pull forward slightly so as to disengauge the bottom lugs. Be carefull as there is a ribbon cable at the bottom that does not need to be tugged or removed.
4. You will now see at the bottom behind the keyboard a small battery connected to the motherboard. Gently pull the small white plug upwards untill it is removed from the board.
5. Wait 5 minutes and re-connect the small battery plug.
6. Re-install the keyboard and push back the clips. You do not need to replace the screws yet.
7. Apply the DC jack and power on - DO NOT INSTALL THE MAIN BATTERY.
8. Turn the laptop on while pressing f10 repeatedly but slowly - Do not hold it.
9. If high security is disabled you should now be in the setup screen, select 'Restore Defaults' and press F10 to save.
10. The password is now removed.
If this does not work then HP say that there is no other way to reset it. Im not sure about that, there probably is by some method of de-soldering the bios chip. However the above method worked for me so I hope it does for you. Please rate if you have any luck.
Sparkyuiop.
Sep 10, 2008 | HP Compaq nc6320 Notebook
Pl,ease help....
plz check the website for more information
http://www.tech-faq.com/reset-bios-password.shtml
Sep 03, 2008 | HP Compaq nc6320 Notebook
Don't know the Power on Password
Is the bios protected by the same password, usually it isnt. If you can get on the bios you can disable that HDD password. Other than that I dont know much about HP's and their set ups, sorry.
Jan 26, 2008 | HP Compaq nc6320 Notebook
HP Compaq nc6320 Notebook Logo
661 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
