Have not used printer for 2 months and when i print the print-out is unreadable, all scratchy and multi-coloured. I cannot find how to clean heads on this machine. If you guys can help me it will be most appreaciable.
  • davegealy Aug 12, 2008
    I dont seem to see any solution to my problem. Can you please send me it again. The heads of my epson stylus D88 printer are blocked or are very sticky. Can you give me a clue/ideas of how i can find some kind of button on this machine to rectify my problem.
Have a very good secondhand Canon Fax L300.Cant find a driver anywhere to set it up as a printer from internet.Please help.
Posted on Aug 12, 2008
Even though my black cartridge is full, my black and white documents are so light they are unreadable. My color cartridges are close to being empty. Can this be the cause?
printers use all cartridges to get the correct colour even black
best get a new colour cartridge then realign the printer with a test pattern
Apr 05, 2015 | Office Equipment & Supplies
It is most likely a blockage in the print-head. Run a nozzle check to see if all the jets are firing cleanly. If there are colours missing or "scratchy" run a deep cleaning cycle. If that doesn't improve the nozzle check, remove the cartridges and then the print-head. Run the underside of the print-head under hot water from the tap for a moment. dry it with a paper towel and re-install the print-head and cartridges. Give a standard clean and re-try. If it still doesn't work, the print-head is probably dying.
Mar 11, 2015 | Canon Office Equipment & Supplies
I have checked both cartridges have ink. When I try to print either from the computer or direct from the printer, the paper passes through but print comes out very pale black or not at all and often some...
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Nov 14, 2012 | Kodak Office Equipment & Supplies
When i print colour document it comes out blurr
Make sure you clean the cartridges head first and you use canon utilities to clean the head of the the printer, Reset the cartridges and then try, it should work out for you.
In case if it doesnt work, run canon diagnostic tools through canon printer utility tool.
Feb 13, 2012 | Canon Office Equipment & Supplies
Red is printing very light and streaking. The other colors print
1.clean the printer head using printer service utility
2.Buy a new catridge and fix it
note: if you are not use the printer the ink will be it cant able to print
Feb 12, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Hi My Epson Stylus R200 print is nearly unreadable. The status monitor says status is OK and the nozzle check is fine
Ensure the nozzle check has 6 colours if it doesn't you will need to try head cleaning. you may also need to align the print head. All this can be found in the same place as the option for nozzle check.
If that is ok try a different paper type, ensure you are using relativly fresh ink.
Feb 02, 2010 | Epson Stylus Photo R200 InkJet Printer
Will not print. Shows I -02
Hi, this is not a solution because I don't think there is one apart from buying new inks. You need to consider 2 things, firstly the official line: Epson (and all other inkjet manufacturers) do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. It is also why the "print in Black only" option (available on some printers) only works when the coloured inks are OK.
The 2nd unofficial line is that it is a win-win situation for manufacturers. Firstly they get to cut down on costly warranty call outs for blocked heads (replacement printers, technician manhours, etc) and secondly they get to sell lots more inks (Ka-ching!). If you really want to print black text only (and save cash on price per-print) then a mono-laser printer is the best way as they can now be bought at inkjet prices.
Apr 10, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Printin Problem
Call Kodak for a new printhead. The printheads go bad.
Dec 20, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
No, usually you will need to replace the printheads.
Nov 14, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Magenta ink ran out,continued to use printer,replaced ink tank twice,have done cleaning & deep cleaning several times no magenta coming through,all other colours ok. what to do next?? anybody have...
Think you may have killed your print head, but try this.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jul 01, 2008 | Canon Office Equipment & Supplies
78 people viewed this question
