Question about Packard Bell Computers & Internet
Computer won't start. When powered up there is two short beeps followed by a long continous beep.
    Champion:
  • 209 Answers
That shows that it has a hardware problem try to dismantle the video card, clean the contact points (bronze color) dismantle also the memory cards, clean it as you've done with the video card. (note: the power should be off when uninstalling) then return these to their respective slots then power on.
Posted on Aug 12, 2008
Compaq presario C700 continous beep when starting up
Potential Hard Drive failure, (Hard drive s.m.a.r.t. beep) or if MB beep it's chassis intrusion..
1. Remove battery + disconnect power
2. Hold down power button for 20 seconds
3. connect power only (no battery)
4. Turn computer on.
If the beeps stopped.. get a new battery, if the beeps continue..
ABANDON SHIP!
Apr 27, 2014 | Compaq Presario 1200,1600, Series CD...
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
May 12, 2012 | HP Pavilion ze2000 Notebook
When starting up the computer, I get 5 short beeps then continous
These beeps seem to show that your system did not detect any RAM (memory) modules connected to it. Please check.
  1. Open the CPU case (turn the PC off first)
  2. Remove the RAMs from the slot.
  3. Turn ON your computer without the RAMs installed. Then observe if it gives the same beeps. If it is the same, then the RAMs might fail to register.
  4. Try to plug in carefully the RAMs in place. If you have 2 RAM modules, try to test 1 RAM at a time to see if the combination of the 2 mess up your system.
Feb 13, 2010 | Computers & Internet
1 long beep 2 short beep continous beep
This POST beep code (power on self test) means you could have problems with :-
  • System board failure OR
  • Video adapter problem OR
  • LCD assembly failure
Try reseating the RAM module/s (the video uses shared RAM ie. part of the main RAM module/s).
Try reseating the video cable/connector (if the computer is a desktop then try reseating the video card and/or a different one).
Jan 04, 2010 | HP Pavilion ze4125 Notebook
PC will not start
This sounds like a memory error, can you define the beeps. There is a thing called a "beep code" on all motherboards, the website for the motherboard defines what the beeps mean. For example: one long beep followed by two short beeps of continous spaced beeps without a break. chris http://www.motherboardsrus.net
Jun 06, 2009 | Dell Precision Workstation 670 PC Desktop
CPU power problem
Check whether all connection are good and take out any CDs in the tray. I guess this must be a SMPS problem.
May 11, 2009 | E-Machines (T2958) PC Desktop
Unknown error
Re-seat Video card, replace memory.
Feb 17, 2009 | E-Machines eMachines Desktop PC
Wont Post get 9 beeps!
This problem is due to the mix of registered and unregistered DIMMs. 64Mb and 128 Mb DIMM's are unregistered memory technology 256MB is registered memory technology. A mix of registered and unregistered memory prevents the server from completing startup, and results in an error beep sequence and a blank screen
Oct 08, 2007 | IBM Netfinity 3500 M20 8657 Server
Computers & Internet Logo
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
