Question about MSI (X52) CD-RW/DVD-ROM (Combo) Burner
Cd drive drivers
Sir my system cd drive drivers are deleted how to reinstall that drivers in to my system
    Problem Solver:
  • 7 Answers
Step 1: Start Registry Editor loadTOCNode(3, 'resolution');Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor. Step 4: Restart the computer loadTOCNode(3, 'resolution');If a CD recording program no longer works after you restart the computer, you must reinstall the CD recording program.
Posted on Aug 12, 2008
DEAR SIR, I HAVE AN DVD ROM OF SONY MAKE, AND WHEN I USE ANY DVD THEN ITS NOT READ THESE PROBLEMS IS BECOME FROM TWO DAYS. PLS TELL ME THE SOLUTION FOR THIS.
is any dvd the program or just wont read any dvd?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 09, 2011 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Gateway NV53 win 7 64bit //the dvd-super multi dl driver stop read dvd/// cd
Click start control panel system and security system device manager, management, scroll down cd-dvd rom drives you might see a yellow question/exclamation mark ? or a red X right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
click start control panel system and security scroll to sytem tab you will see device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Aug 24, 2011 | Gateway (5500652) (  5500652)...
My ts-h652d driver wont read any dsks and my computer cant recognise the drive. when i go into computer managment the cd/dvdw drive has a yellow exclamation mark beside it, i tried uninstall and it trys to...
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs Click Start, Run, and type regedit and press Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jun 10, 2011 | Computers & Internet
My disk cd dvd drive have deleted
you might have to physically unplug the leads for this cd rom then plug them back in or
if your computer came with a motherboard disc the sound drivers could be on it
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
May 17, 2011 | Computers & Internet
Teac drivers only acknowledged in linux but dual boot ;to windows and cd dvd rom unseen to system.? system is Tosh satelite A-15 s129 with linux Ubuntu netbook 10.10 and windows xp sp3.
make sure that the cd/dvd rom is getting enough power test all leads that are attached to the dvd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps
Apr 21, 2011 | Toshiba Laptop CD-ROM drive (710348689149)
Sir i have samsung cd rw drive i play mp3 cd some time after i change a new disk the drive give no responce i check in my computer but there is no drive show . i install new operating system...
make sure that the cd rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd rw then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then restart your computer then reinstall your cd rom or uninstall the driver then reinstall for this device
also
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives right click you can you will have options to update driver roll back driver select properties general troubleshoot select driver click to reinstall drivers click update driver uninstall then reinstall
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Mar 27, 2011 | Samsung CD-RW SW-212 Burner
Dear sirs, I have been using an LG Portable Super Multi Drive GP08NU20 but suddenly my portable HP Mini 1000 (with OS Windows XP) is not recognizing it. When I go to "My PC" is not even...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 17, 2010 | LG GP08NU20 DVD±RW Burner
Dear Sirs, I have a Smart& Friendly "CD
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 13, 2010 | Smart and Friendly TurboWriter (SAF795)...
Dvd/cd ram not opening cd
You can try to delete upper and lower filters for your system. go to start>run>type in regedit click ok> start looking for this parth HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318},when click on the folder look on the right column and look for upper/lower filters and delete it. restart system. Try updating the firmware of the optical drive depending on the model. if you want to chekc the model of your drive go to device manager right click my computer>select manage>select device manager then lookf or cd /dvd .
caution:be careful with deleting registry for your system this might affect your operating system functionality.
Jun 25, 2010 | Dell (0F146) Internal DVD Drive
MSI (X52) CD-RW/DVD-ROM (Combo) Burner Logo
97 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
