Question about Panasonic TOUGHBOOK CF-18 Tablet PC
NUM Lock On boot NUM lock is on, but I can't find a setting to default it to OFF
  • 1 more comment
  • Anonymous Jan 06, 2009
    Unable to turn off num lock
  • Anonymous Mar 05, 2009
    NUM Lock comes on with the computer without the LED saying its on. Can not find a way to disable it.
  • Anonymous Mar 11, 2009
    CF-30 NUM lock is on everytime computer boots up. Messes up our passwords until we realize to turn it off.
I solved this on a toughbook. The numlock was activating while windows started even with the regkey set to have it off.
(http://support.microsoft.com/kb/154529/en-us)
All I had to do was restarting the PC waiting for windows to activate the numlock again during the shutdown process and then hitting the numlock once before windows was done.
Next time the Toughbook started the Numlock kept off!
Posted on Apr 22, 2009
I have a amazon fire hd 8 how can i chang the pic. on the lock screen please help
Select a lock screen scene or personal photo to display on the lock screen of your Fire phone.
  1. From Settings, tap Lock Screen, and then tap Select a lock screen scene.
  2. Swipe down through the available scenes, and then tap to preview the lock screen. Alternatively, tap Your Photo to select a personal photo to display.
  3. Tap the checkmark to set the lock screen or the X to cancel.
By default, your phone will rotate through all of the available lock screen scenes daily. To turn this feature off, tap Off next to Rotate Scene Daily at the top of the screen or select a specific scene.
Note: When the battery is low on your Fire phone, Dynamic Perspective lock screen scenes will stop reacting to your movements to conserve battery life. From time-to-time, we will add additional lock screen scenes to your Fire phone when they're available.
Dec 27, 2016 | Amazon Tablets & eReaders
Daily password changes to Amazon, Hotmail. What am I doing wrong???
I hope you have figured out your problem by now. I am assuming that you mean you have to reset your passwords daily, which is definitely not a good thing. If you are just changing your password every day for security purposes, that is a little excessive but there isn't anything necessarily wrong with it. For the first case (most likely) consider some of the following:
  • Always keep your antivirus software up to date. McCa
  • Check your caps lock and num lock on the keyboard. Num lock is especially tricky on keyboards that do not have the separate number pads, as some of the letter keys become numbers when num lock is on. Passwords are case sensitive, make sure your caps lock is off when you are creating your password and when entering it.
McAfee and Norton are very good antivirus options, AVG also has a free option.
I hope you find and resolve your problem quickly.
Mar 29, 2016 | Amazon Kindle Fire HD 7in, 32GB
My samsung netbook virtual keyboard not function what do i need to do?
Hi you perhaps have NUM LOCK on. Look on the first row of keys for anything that says Num Lk or Scr Lk and press it to turn it off and it should fix the problem
Feb 24, 2011 | Samsung Tablets & eReaders
My hp paviliOn tx2500 touchscreen laptop monitor will not turn on. The caps lock and numb lock lights flash on and off, and the blue lights around the screen work, and I can hear it turn on, however the...
cap lock & num lock flashes are an error codes
LEDs blink 1 timeCPUCPU not functionalLEDs blink 2 timesBIOSBIOS corruption failureLEDs blink 3 timesMemoryModule error not functionalLEDs blink 4 timesGraphicsGraphics controller not functionalLEDs blink 5 timesSystem boardGeneral system board failureLEDs blink 6 timesBIOSBIOS authentication failure
Jan 03, 2011 | HP Pavilion tx2500z Tablet PC
HP Pavilion tx2000 does not boot, CAPLOCK and NUMLOCK LEDs blink once a second. This happened after using the MagicJack on my laptop for the first time. It kind of worked OK then but next day my computer...
Actually 1 blink of Caps Lock and Num Lock refers that CPU is not functional.
However, to confirm the same. Please remove the battery and check whether it is getting power on only on ac adapter. If it is not then it is the motherboard which is gone bad and if it power on then you need to change the battery only.
Also, there was a recall from hp on some of the models which have same symptoms like you but your model is not covered in that. So its better to take the part no. of motherboard and replace it. If you could provide me the product no of the laptop then I can find the same for you.
Jun 02, 2010 | HP Tablets & eReaders
The keyboard format is changed from alphabetic to fn. how do i restore the original format?
Press the number lock button on top right side of keyboard ' number lock is engaged'
Sep 24, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
No keyboard instructions
You need to press the Function button, then the num lock button. The function button may be labeled FN or F in a different color, the same color as the num lock button.
If that doesn't work, go to start, all programs, accessories, accesibility, on screen keyboard....it will display a regular keyboard on your screen, then click on the num lock key on that keyboard.
May 24, 2009 | Compaq TC1100 (/) PENTIUM M 753 1.2GHZ...
Panasonic TOUGHBOOK CF-18 Tablet PC Logo
5,212 people viewed this question
Top Panasonic Tablets & eReaders Experts
Paul Wang
ddalecki
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
