If it is getting past the boot and the meter goes across the screen and then it goes black, then it could be a video card problem. I have seen the live cd do that but work fine after installing. Try hitting F4 and selecting "safe mode" at the boot time, right after you select the language.
Was this helpful?
Yes
No
Solution #2
posted on Sep 23, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
u can instal ubuntu on windows :) so u wil have dual boot system start ur win insert cd chose instal inside win the wen finishing just restart ur pc and u'll be able to choose from win either ubuntu :)
i gav encountered this prob while i was helping my frnds install UBUNTU......then i found out they had low RAM.....but if ur patient n wait for a lil longer it does work on som comps.....its better u upgrade ur RAM....
First, go into bios and make sure you select boot from cd derive first.
If that doesn't work, then try burning another cd. Burn with a lower speed, and try a different type of blank disc. Sometimes the disc brand can cause problems.
Music looks to be playing but no sound, Volume is up and is not on mute.?????OPS is Ubuntu on IBM...
(More)
Music looks to be playing but no sound, Volume is up and is not on mute.?????OPS is Ubuntu on IBM Thinkpad 600
hi am having same audio problem in CQ40-144TU. Please let me know the solution asap....
(More)
hi am having same audio problem in CQ40-144TU. Please let me know the solution asap. pratheep.pratheeps@wipro.com
hello i am looking to setup raid 0 with the alternative install cd for ubuntu 8.10 i have foudn...
(More)
hello i am looking to setup raid 0 with the alternative install cd for ubuntu 8.10 i have foudn steps for raid 1 but i want to do raid 0
Having a problem with Beryl on Ubuntu, I play a video no problems, but if I rotate the cube the...
(More)
Having a problem with Beryl on Ubuntu, I play a video no problems, but if I rotate the cube the video disappears or starts flickering. What can I do to fix this problem?
