Question about Kenmore 53509 Dehumidifier
Will not dehumidify
My Kenmore 53509 Dehumidifier has worked superbly for the last 4 years, but recently quite dehumidifying.  I live in a high humidity environment, the blower fan is operational, but whenever the compressor attempts to engage at any setting of humidity, the compressor quits within 1 seconds. Is it possible that the compressor needs to be recharged, is it possible to have the compressor recharged, or is there other troubleshooting I need to do?  Appreciate any suggestions. Up until now, this has been a great dehumidifier.
  • torella Aug 12, 2008
    I have a Kenmore 25357510790 with a similar problem. It has worked for many years. The fan always works, but when the compressor starts to kick in the basement lights dull and after a second or two the compressor turns off.
    Can I repair this, or do I need a pro?
    Thank you, Michael
techman
  • 3130 Answers
SOURCE: Dehumidifier Compressor is not working
this unit is very simular to an air conditioner except it has a humidistat instead of a thermistat.. if your handy with a continuity tester unplug the unit find the humidistat and check to see if its open or if its good then call the company at 1 800 322 3848 or contact the web site at customerservice@delonghiusa.info Good Luck
Posted on May 31, 2006
22yooper
  • 828 Answers
SOURCE: Dehumidifier Error?
Your bucket full switch may be defective. If you are capable, bypass it since you are draining to another place other than the bucket.
Posted on May 09, 2008
  • 225 Answers
SOURCE: Dehumidifier Does Not Collect Water
A dehumidifier is just a refrigerating machine with it's shirt hanging out and there is not much in the way of serviceable parts inside.
If the compressor runs - the throbbing sound - and it doesn't collect water then either the intake filter screen is totally clogged with fluff or the compressor has leaked it's gas away, in which case it might run continuously and get hot to no good effect.
If it doesn't run then it may be that the motor capacitor has failed, but that can soon lead to the compressor motor cooking itself; leaving you with an expensive doorstop.
The one thing you might get checked is the "bucket full" switch. There will be a floating part on the bucket which rises up when the bucket fills and eventually makes contact with another part which is connected to a small switch. If that switch has failed you might be lucky and get an inexpensive repair job done.
If these suggestions do help you solve the problem, please give my reply a suitable rating. If they do not, please add a comment with more details so I can try to help you further.
Cheers, D
Posted on Jul 01, 2008
SOURCE: Dehumidifier does not collect water.
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Posted on Mar 28, 2009
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
Posted on May 02, 2009
Keeps making my circut blow
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 21, 2011 | Kenmore 53509 Dehumidifier
Dehumidfier runs, collects little water, the coils freeze up and water leaks out
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Jun 23, 2011 | Kenmore 53509 Dehumidifier
My kenmore dehumidifier won't pull the moisture out of the air, the motor is runing when turned on but the bucket never fills up. What is the problem?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 10, 2009 | Kenmore 53509 Dehumidifier
Compressor doesn't turn on
sound as though you need a temp control.Is there frost buld up on coil?If so it may not be humid enough .Hope i helped
May 16, 2009 | Kenmore 53509 Dehumidifier
Help me fix my dehumidifier
What else is on the same circuit? Have you added any other appliances on that same circuit that were not on it before?
If no>>>you probably have a short in the unit, and it is grounding out>>>tripping the breaker before it starts a fire.
Also, check the breaker, they can go bad.
Jul 23, 2008 | Kenmore 53509 Dehumidifier
Circuit breaker
SOUNDS LIKE TO ME THAT YOUR DEHUMIDIFER HAS A SHORT. SOME TIMES ITS THE PLUG OR THE CORD BUT MOST TIMES IT GETS OXIDATION FROM MOISTURE INSIDE.
Jun 24, 2008 | Kenmore 53509 Dehumidifier
Compressor does not start
some of these units have a 5 year compressor warranty on them including labor worth calling sears and seeing if it does have the 5 year on the sealed system
Apr 09, 2008 | Kenmore 53509 Dehumidifier
Kenmore 53509 Dehumidifier Logo
114 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
