LG washing machine not working
The main circuit in the washing machine has an integrated fuse on it. When the washing machine stopped working I looked at the board and saw the blown fuse. This is the one I have replaced. It still keeps blowing when power supplied to it..?? Can anyone offer any help?? The circuit board is the one they fill with plastic/gel to seal the components.
Thanks
SOURCE: washing machine blown fuses
Hi - had a similar problem with about 3 different makes of washing machine - the RCD switch on the main household fuse box was continually tripping . Nobody could give me a right answer . Eventually ended up with a Hotpoint . Felt sorry for the delivery guys from the electrical retailers having to keep dragging machines in and out .
Posted on May 07, 2007
Washer_tech
  • 164 Answers
SOURCE: fuse keeps blowing out in my maytag washing machine
the power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
Posted on Nov 17, 2007
IB4G2008
  • 3587 Answers
SOURCE: Bosch Washing machine WFB 4001
well, seems to me that you are using too much juice for the circuit, which implies a SERIOUS issue with the machine. perhaps the motor is locked, or something in control panel is shorted out?
Posted on Feb 27, 2008
dutchman05
  • 487 Answers
SOURCE: LG WM3677HW Won't turn ON.
Ok try this .
You say you know your way around electric. Here is the service manual incl drawings.
LINK
Posted on May 07, 2008
barkencoa
  • 3463 Answers
SOURCE: No power running to SERVIS washing machine
Try disconnecting the heater element first and see what happens if still same unplug motor and try again, it is a process of elimination.
Plz rate solution.
Thanks.
Posted on Dec 14, 2008
LG frontloader keeps blowing fuse immediately
Short circuited component/s at its main power regulator circuit [SMPS]; inside. Contact any service technician. Electro help
Nov 22, 2014 | LG Washing Machines
Power button will not turn on dishwasher.
Make sure that power is reaching the control panel of your machine. Many people are offended when I tell them to check the fuse or circuit breaker to make 100% sure that the machine is receiving power.
If it is receiving power and not switching on, you will have to have the main control PC Board checked, out as this controls the entire machine. This is rather left to experienced persons.
Jul 27, 2014 | LG LDS5540BB Semi-Integrated Dishwasher...
My lg washer just stopped working last nite and has no power. anyone experirnec the same issue?
When this occurs it is a sign that you have a defective washer main control circuit board, this circuit board is the brains of the washer and it located behind the main control panel of the washer.
Feb 07, 2012 | LG Washing Machines
The washer shuts down in mid cycle
Hello. LG washing machines come in a widevariety of models, each with unique features, functions and design. Many of thebasic functions of each model are universal when it comes to running the washcycle. If the washing machine stops in the middle of a wash cycle, the firststep that should be taken is to perform troubleshooting steps to determine thecause of the problem. After the source of the trouble has been established, itcan be resolved in most cases by continuing the troubleshooting process. 1 Make sure the lid is completely closed. Certain partsof a wash cycle will not start if the lid is not closed.
2 Check the load to see whether it isunbalanced. If the washer gets off balance, it may stop in the middle of acycle. Redistribute the clothing so that it is evenly balanced around the drum.
3 Make sure the hot and cold water faucetsconnected to the washing machine are turned on fully. If the washing machine isnot getting enough water, it will not be able to complete the cycle.
4 Inspect the drain hose for clogs orobstructions. The washing machine may stop if it is unable to drain waterproperly. Check the drain pipe that the hose feeds into for clogs or debris.
5 Check the house's circuit breaker panel orfuse box. The circuit may have been tripped or a fuse may be blown. Replace anyblown fuses and reset any tripped circuits.
Thanks for visiting
Sep 07, 2011 | LG WM-2277HW Front Load Washer
Main circuit board faulty
SE is 'sensor error' This could be anything from a loose wire to a faulty Hall sensor or even a main board failure......You probably need an LG technician. Your machine sounds like it's worth repairing.. Get quotes.........Good luck...Nomess
May 30, 2010 | LG WD-16115FD Front Load Washer
My LG washing machine will not run through washing cycle
Locked motor error (LE)
* The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly
* The electrical contact between the connectores, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit).
* The hall sensor is out of order/defective.
***. If the hall sensor is defective, replace the entire motor.
Jul 13, 2009 | LG WM1814CW Front Load Washer
Washing Machine Problem
It sounds like the control board has failed.  You will need a qualified LG technician to check this out.
Jan 20, 2008 | LG WM-1485FHD Front Load Washer
Washing Machines Logo
115 people viewed this question
Top Washing Machines Experts
