I've got a Hotpoint WF541. It sounds like it's taking in water (certainly going into the drawer) but does nothing else except these flashing lights: on/off, mini load and rinse hold. The manual says if mini load, rinse hold & pre-wash are flashing it's a filter/pump blockage but I'm not getting a flashing 'pre-wash' light just the others. Tried cleaning the filter anyway (lot of water came out but no debris). Hotpoint wont tell me what the series of lights means (apparently they're error codes) and just want to sell me an extended warranty!
  • Anonymous Nov 23, 2008
    all lights flashing
  • Anonymous Jan 24, 2009
    mine keeps filling with water regarless of power on or off plus the lights dont work at all?
I have the same issue. I've been told it needs a new PCB
Posted on Oct 06, 2008
Hiya. Same thing here. Did anyone find out what they mean and how to fix it? Cheers.
Posted on Dec 09, 2009
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
My wf541 leaks from the soap dispenser drawer when water is being put into the machine
Reduce the water pressure, I assume its too high , also make sure no partial blockage at dispenser hose ..try pouring in a jug of water and see if it goes away Freely...Good luck
Feb 04, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Aquarius hotpoint wf541 wont pump the water out at the end of the cycle
You need to clean the filter.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean the filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well
Hope this helps with your problem
Dec 28, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Machine do not take detergent from the dispenser at all
that sounds to me like a water pressure problem. check the hoses aren't kinked and that water comes out at a reasonable rate.
the small filters where they attach to the machine may be limescaled up and want cleaning.
Feb 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Dec 28, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wf541 flashing lights
hiya m8 how old is this washer if its over 5years then youll be looking at the thermostat and heater element being at the front of the washer which its easier to take the complete front off to get to and see everything clearly do me a faviour and pull the kick strip off and tell me if theres screws behind it to take the front off
Sep 29, 2008 | Washing Machines
WF541 Hotpoint
Have the control board checked first
Apr 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
Feb 13, 2008 | Hotpoint WMA32 Front Load Washer
Washing Machines Logo
928 people viewed this question
Top Washing Machines Experts
