Question about Sony PlayStation Portable (PSP) Console
Same thing that happened to you.
I read your solution and Im 12 and I dont know how to do that.
Could you please break it down for me.
  • 164 Answers
Break what down?
If you need help, feel free to E-Mail me: Thomashedderwic@hotmail.com
Posted on Aug 21, 2008
Emergency break light comes on when break is off
dont break the brakes, please
you lost your operators guide, so soon,... LOL
ok, they all say same thing on most cars. even new,
so what does it say........
1: hand brake on, or switch stuck on..
2: Brake fluild low. ever check levels every week?
3: total brake failure, (either front or rear) (DIFF VALVE switch detected this)
4: on newer cars, more... (abs. etc)
you can read the FSM on this, it shows every test to do.
or alldata.com, login and read the brake section.
it breaks down in to subsections for the lamp.
Feb 11, 2014 | 1998 Toyota 4Runner
Astra fault codes 0480 and 0481. any help please? please read down there V V
It is your immobilizer system, program a new key and let me know what happens.
Nov 23, 2013 | Cars & Trucks
The car seems to be slowing down extreamly fast when im out of gear, its as though i have my handbreak on, and no there isnt a sign on the dashboard so i doubt its somthing to do with the handbreak. i dont...
As long as the gear shift calbe is routed correctly and adjusted correctly you can be sure you have a input spline problem the first sign is hard to engage first gear and hard to engage in reverse the S 40 have known problems for this your dealer should know TSB 43-47
Sep 08, 2011 | 2000 Volvo S40
I forgot my password now im trying to reset it and i dont know were the reset button is
http://hotfile.com/dl/94523441/9f351b8/Hirens_BootCD_13.0__9Down.COM.rar.html
BY USING THIS LINK YOUWILL GET PASSWORD BREAKING SOFT WARE DOWN LOAD IT AND BURN IT IN THE CD.INSERT IT IN YOUR PC OR LAPTOP .RESTART YOUR SYSTEM AND PRESS ANY KEY TO BOOT FROM CD .WHEN THE CD STARTS BOOTING FOLLOW THE INSTRUCTIONS TO BREAK  YOUR SYSTEM PASWORD.AFTER BREAKING YOUR PASSWORD WIIL BE BLANK.NO DATA LOSS WILL HAPPEN YOU CAN EASILY LOGIN TO YOUR SYSTEM AND YOU CAN SET NEW PASSWORD ALSO.
PLEASE GIVE THE VOTES TO IMPROVE MY SOLVING SKILLS
Feb 17, 2011 | Acer Aspire 5610-4648 Notebook
My jetta will start but when you give it gas it dies. ive replace the fuel filter maf sensor and as a result with messing with the throttle body, im replaceing it as well, i hooked it up to a computer and...
Its a computer controlled motor so yes if one thing gives it a bad reading the cpu will try to counter the issue and give to much gas or not the right amount of air to the intake... Just from what i have happen to me I would look for a leaking vaccume line or a clogged cataltic converter befor replaceing the sensors both can give a false o2 reading on the computer and seem to be more common on most cars..
Oct 20, 2010 | 1998 Volkswagen Jetta
Just want to KNOW IF I SHOULD CHANGE TIMING BELT YET IM AT 93000 MILES AND WILL HAPPEN IF I DONT
the belt should be changed at 75,000 miles regardless what the makers say,they dont pay the BIG bill when it breaks.if it does break you are looking at a new engine.......if it goes at speed.
Aug 24, 2010 | 2003 Ford Focus
Truck wont start. Only getting 5 volts instead of 12 to the coil and no spark. Auto shutdown relay is ok. What could be causing it to not turn on?
if you are uplugging coil and reading voltage on leads, u are reading in series withe the pcm, not voltage across coil. i have done this and read 4.9 volts. u must leave the coil connected and read the voltage across the coil by pinning the coil lead wires (green/orange and black/light gray) with the voltmeter leads or connect the meter leads at the asd relay in box on the left fender well (green/orange) and on the top row on the pcm connector on the right fender well (light gray). i did this too and read 0 volts, this means the circuit is not turned on thru the computer i think. otherwise it would read 12 volts. i havent found out why it isnt on. if someone knows, please tell us. i have had this intermittent problem for years. i have read that if the camshaft position sensor is bad, the asd relay wont be picked up. i dont know if the same thing happens if the crankshaft position sensor is bad but my guess is it does, which makes me wonder about the computer, which i replaced 2 years ago.
Oct 12, 2009 | 1993 Dodge Dakota
Where is the driver side power window cicuit breaker.
check the wireing to the window motor an at the conector as well where it comes thru the door =- i have seen them break there an its covered === also check the circuit breaker in the fuse pannel position number 16 in the breaker for the window motors ok
dennis
Nov 23, 2008 | 1996 Chevrolet Cavalier
Windows has shut down on my HP compaq 9005 ?????? HELP
the best solution for your problem is to reinstalling yuour operating system
if you know how to *** this then just go ahed and reinstall your windows
but if you dont then plz dont do anything and just find any technician and let him do all the stuffs required and
tell him to check your cmos bettery also
Mar 29, 2008 | HP Compaq Business Notebook NX9010
Sony PlayStation Portable (PSP) Console Logo
14 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
