SOURCE: Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
SOURCE: Waveguide cover for Kenmore microwave
Try replacing the screws with larger ones. Maybe you ordered the wrong piece, if your microwave comes with a mica cover (A fine, square piece of mica) and you received a plastic one, you will need to get the right piece or adapt the one you received.
You can get the mica cover on any microwave service.
SOURCE: inside the microwave the piece
Yes. This is the waveguide cover, and it needs to be there to protect the magnetron from damage.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet or held in a slotted opening.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
If your waveguide cover is burned or damaged, it will need to be replaced.
You can often find helpful exploded view diagrams and order parts by entering your full model number here or here.
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: installation instructions for goldstar mv
For
Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat
8-5 CT) and choose the appropriate prompt from the menu or visit here.
Goldstar manuals can be downloaded here.
We're happy to help you and we'd appreciate your
SOURCE: Metallic-like cardboard insert inside microwave is crumbling???
That piece is called the waveguide cover. Emerson calls it a spatter shield. Behind it is the hole where the microwaves enter the oven. Its job is to prevent food spatters from getting into the microwave source, and it's not a good idea to run the oven without it.
The cover is usually held in place by a plastic rivet that pulls out. I couldn't find the part number for the cover used in your model. But here is a link to a parts place that has several covers available:
http://www.a-1catalog.com/wavandstirco.html
If one of the covers shown looks like yours you can order it. Another possibility is to contact Emerson at 800-695-0098. This is the number they give to locate authorized servicers near you, and you might be able to order a replacement cover through them.
Hope this has helped. If so, please take a moment to rate the solution. Thanks for asking here!
