Turn tv on hear a click then another click. Nothing after that. Toshiba projection Television Model 46H84
  • Shakespeer_0 Aug 12, 2008
    Toshiba 46H84 Turn TV on and hear a click then another click. no picture no sound.
    Brigadier General:
  • 6,966 Answers
The initial click that you hear could very well be a relay engaging. For some reason, the built-in protection circuitry has detected a fault and has decided that to prevent further damage, the system would be shut down, this would be the second click, the relay disengaging.
Diagnosis and eventually repair would require a fair familiarity of electronic components and circuitry, definite use of a DVM and even a soldering iron. A service manual or at the very least a schematic diagram with voltage readings would make the checking relatively easy. Should you be uncomfortable going through this route, then perhaps you would be better off seeking the services of a qualified professional.
If you are considering a DIY (do-it-yourself), foremost to check would be for the presence of the correct voltages from the power supply board. Often defective components could be visually checked such as blistered/bulging capacitors, burnt resistors while others would need forward and reverse bias testing of regulator/transistors.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 12, 2008
  • Louie  Role
    Louie Role Aug 12, 2008
    Hi again,
    Other indicators would be flashing LED lights with a certain sequence to denote most probable area of fault. Along the same line, absence of any led when the unit auto shut down would indicate main power supply switching off (even the standby +5 is missing).
    Master:
  • 848 Answers
Variety of power supply or startup problems can result in this or similar behavior. Possibilities include:
  • Lack of startup horizontal drive -The main regulator is cycling on overvoltage due to lack of load.
  • Excessive load or faulty power supply cycling on its overcurrent protection circuit.
  • High voltage shutdown, or some other system detecting an out of regulation condition. However, in this case, there should be some indication that the deflection and HV is attempting to come up - momentary whine, static on the screen, etc.
  • A dried up main filter capacitor or other filter capacitor in the low voltage power supply that is producing an out-of-regulation condition until it warms up. A bad filter capacitor on the output of a series regulator may result in excessive voltage and subsequent shutdown.
  • A problem with the microcontroller, relay or its driver, or standby power supply.
One possible test would be to vary the line voltage and observe the set's behavior. It may work fine at one extreme (usually low) or the other. This might give clues as to what is wrong
    Genius:
  • 2,785 Answers
Plz send your tv for servicing
How to replace procector lamp in model 46h84 toshiba
Projection TV sets have three tubes - red - blue - green and they don't fail often...they are located inside the tv DLP TV sets use a single bulb and a clot wheel to make the three colors display...DLP bulbs do fail about every two years and will need o be replaced. Replacements can be found at www.TvRepairKits.com and its located behind a small door on the rear of the tv.
May 19, 2013 | Toshiba 46H84 46" Rear Projection...
When i turn my toshiba tv model #46h84 the green bulb lights up the screen but then shuts off and there is no picture! please help me out!!!
I have the same exact problem...for a few weeks the TV would turn off and the red power light would blink. Then the other day I started having exactly the problem you describe...green screen for a few seconds and then total shutdown.
Feb 08, 2011 | Toshiba 46H84 46" Rear Projection...
Why is my toshiba 46h84 picture getting darker than before? Its becoming harder to see darker scenes in movies
It sounds like your lamp is getting close to the end of its lifespan.The lamp is what gives your screen its brightness.With time they start losing this brightness.If you were to wait to replace it till it goes out completely you would have a black screen.You can purchase a quality lamp at discount-merchant.com
Apr 16, 2010 | Toshiba 46H84 46" Rear Projection...
Sirs: We were just changing channels and the
THE projection bulb is blown if no sound tv probably broken
Jul 31, 2009 | Toshiba 46H84 46" Rear Projection...
Toshiba 46h84 rear projection shutting down
I have a Toshiba 46h84 with similar problem that needs a new green crt. Mine does not have a cooling fan. I don't know if having a cooling fan would help the problem, but mine didn't come with one. There are rear projection TV's that have bulbs in them that require a fan. This particular model uses a red, a green, and a blue crt to generate the picture and probably doesn't need one.
May 19, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba 46H84 HDMI Card Replacement
The only thing I could recommend is to return the board and get the right board. open the set and get the part number on the board itself. You cannot modify a set to work things it was not designed for without reprogramming the microprocessor. Good Luck
Jun 26, 2007 | Toshiba 46H84 46" Rear Projection...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
