Question about Acer Aspire 5610-4648 Notebook
Recharging problems `my acer laptop is not right. i can charge it up and it sometimes stops charging even when the computer is off. if you unplug it and plug it back in again at the back of the computer it starts charging again, it takes a long time but will charge to 100 per cent. if you turn the computer on, even though the powerpack is on and connected it nearly always will not work from the powerpack alone. it runs from battery and then you cannot always complete your tasks unless youre quick and save them when the low battery warning comes up. i dont know whether the powerpack is faulty or the computer needs a patch or upgade or something. please help, your advice will be apreciated.
  • Jason Carver
    Jason Carver May 11, 2010
    How long have you had this laptop for? Have you tried running down the battery completely and then charging it back up to full capacity?
Acer 4830 battery suddenly dead
Your battery is still alive, the problem is in the laptop, it may have a blown resistor or charging ic. I can bypass these parts tru jumpering if ever these parts are not available in the electronics store. Now, take the laptop in the computer repair shop nearest you for this is a hardware related problem.
Feb 01, 2014 | Acer Aspire Timelinex 4830t6443 Core I3...
Acer Aspire One battery only charges to about 23%
Sadly, the only other thing you can do is buy a new battery in this instance; or continue with what you're doing.
One of the things you could do, is do not charge the computer until it dies. Batteries have a life span, and this as you may or may not know is reduced by charging, or even worse damaged more by just keeping it plugged in, charging it when it's half way charged and such on so fourth. You can increase life span by just letting it die, and then recharging it. It sounds like your battery has got to a weak point from all that charge, unplug, fall, charge. I apologize for your battery.
Feb 23, 2013 | Acer Aspire One Netbook
Black out after churger was unplugged
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 23, 2012 | Acer Aspire 5742 Notebook
When i charge my acer aspire the power button flashes
The DC jack in the laptop is showing early signs of intermittent issues, the jack is solded to the motherboard which sometimes breaks free over time, this is something that will eventually need to be addressed.
Mar 25, 2012 | Acer Aspire 5336-2283 Notebook
Is there any way to charge an ACER computer battery other than through the computer. The computer has a burned out recharging jack. Can you recharge it through a USB port.
No, not through a USB port.
Can you find a similar ACER computer for "cheap" on eBay?
It would not need to run -- it just has to accept the identical battery,
and connect to an AC adapter, and to charge the battery,
even when the laptop is powered-off.
Nov 25, 2009 | Acer Aspire 3680 Laptop
Acer 5315 Battery cHarging Problems
All rechargeable batteries have a limited life, and as they age their charge capacity reduces over time and you get shorter and shorter time between charges.
Recharage batteries have a finite number of charge and discharge cycles and batteries over 2 years old are considered nearly worn out. Worn out batteries won't charge up at all.
Jun 30, 2009 | Acer Aspire 5315 Notebook
Battery stopped charging
Yeah It Sounds like the battery is just had its last charge they only last for about 300 charges a piece i would get a new one go for at least a six cell they will last longer...Let me know if this works for you.
Apr 20, 2009 | Acer Aspire 3690 Notebook
Battery not keeping charge
Some Laptops will not charge unless the PC is started. The moment u shutdown, the main supply via the adapter also stops sending any power for charging the battery. It is similar to most of the compaq presario series too. Try this.....sodeep
Mar 27, 2009 | Computers & Internet
Battery won't charge right
CHECK WITH ASUS FOR A NEW BIOS UPDATE. I HAD PROBLEMS WITH BATTERY CHARGING AND THE BIOS UPDATE FIXED IT.
Jan 11, 2009 | Acer Aspire 7720-4428 Notebook PC
Acer Aspire 5610-4648 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
