Question about Lanier 5235 Printer
How to clean the printer ?
The copies are not clean. There is ink even on white pages. There was a green roll on the right side of the printer, it's black now. But I don't know how to clean it ? May I clean it ? Or is it another problem to solve before ?
Thank you to answer me
  • 162 Answers
If you changed of toner (example of original to one generic) this can be the problem, the copier gets out of order drastically increasing the amount of toner in the develop for that reason the cylinder is black. In this case it would have to change the revealer and to fit the TD and ID sensor.
Lamentably if you are not technician, she would have to call to one so that she makes the task then surely will be necessary to make a cleaning.
Posted on Oct 27, 2009
  • Lanier Expert
  • 398 Answers
The green roller is your drum,(not meant to be touched) a blade cleans it (like a windshield wiper does sot of ) sounds like you lost charge voltage, you need a service call, sorry
-Carl, please let me know if this helps.
Posted on Jun 25, 2009
Printer is not printing yellow, Light Cyan, Cyan, blue lines through Light Magenta & Magenta, What could be causing this and it is also leaking black ink out of the bottom of printer.
Is it under warranty, are you re-filling the cartridges? If yes to first and no to the other two, send it back under warranty. If you use copy cartridges or refill old ones the warranty is vod. This means you need to replace the printer. To be honest, you'd be better off buying an Epson all in one. Even the wireless model start @ sound 40gbp and you can buy good copy cartridges from choicestationery.com
Nov 17, 2014 | HP Photosmart C8180 All-in-one -...
Mutiple lines on right side of photo
try removing the ink cartrage and clean the heads in the printer with a quetip and rubbing alcohol. same with the cartrages.
Nov 12, 2007 | Canon PIXMA iP5000 InkJet Photo Printer
Even with new ink cartridge printer prints light
Double click Control Panel.
Double click Printers and Faxes.
Right click your printer and select properties. Now on General tab select "Printing Preferences".
Now select the basics tab and click "Advanced features" found on the right of the page.
Here you will be able to adjust the amount of ink that is used to print a page. Side the bar to the right to increase/darken the print.
Now click OK, followed by Apply.
Take care!
damnor01
Jun 07, 2012 | Office Equipment & Supplies
WHEN I MAKE COPY OR PRINT THE PRINTED PAGE IS NOT CLEAR, IT HAS SOME VERTICAL LINE ON LEFT SIDE AND SOME DOTTS ON RIGHTY SIDE, WHAT SHOULD I DO SOLVE THESE PROBLEM?
For copy jobs, clean the glass with a soft clean cloth, regularly, not just the 8.5 x 11 screen but the 11-inch x .5 inch strip that copies when using the document feeder. Print job: their is probably dirt or ink on the rolling parts. Q-tips are good for cleaning this up, careful, don't burn your fingers.
Mar 27, 2012 | Canon FAX-L400 All-In-One Laser Printer
Can't print and when i did got green color
Check the level of your black ink. Double click on your printer icon. This should bring up Dell solution center. Click maintenance and it show the level of your black and color ink. If it appears you have black ink you might try clicking on your menu file, print click on preferences, check print black and white only. If you don't get a printed page. You're for sure out of black ink.
If you get a black printed copy, Double click on your printer icon, click on the maintenance tool to clean and test nozzles.
Jul 01, 2009 | Dell A920 InkJet Printer
HP Officejet J5780 All-in-one Injet prints a grey line down the right side of the page when copying using the automatic document feeder. It does not show up when printing; and it does not show up when...
lift the feed area and look at the small glass plate where the auto feed paper is actually scanned. That needs a good cleaning. Since the paper runs across it even a tiny little obstruction such as paper left from a paper jam or a dot of ink from that pen you used to unstick that last paper jam (maybe its just me??). That one dot turns into a line when the paper rolls across it. Clean well and the line will dissappear.
Feb 27, 2009 | HP Officejet J5780 All-In-One InkJet...
Horizontal white lines
Go to the maintenance link for your printer (in properties) and clean your nozzles. It could be this, bad or low ink or needs alignment.
Dec 16, 2008 | Lexmark P6250 All-In-One InkJet Photo...
Ink smudges on printed page.
I had the same problem when i refilled my cartridge. All I did to solve it was this: I removed the cartridge from the printer and cleaned the green cylinder with a very soft cloth. There is a cogwheel on both sides of the cylinder, so you can move the cylinder by turning the cogwheel. On my cartridge there were a few, hard ink-spots, i had to rub a little to wipe them off. When I removed them, the problem was solved.
Nov 05, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Dripping color ink
you need to replace the color print head.it right under your color cartidg.
Mar 01, 2008 | HP PSC 1410 All-In-One InkJet Printer
Line shows up down right side of page that was copied or Faxed
your ink wel needs cleaning, do some deep cleaning and if that dont work take your ink well out and clean it manually
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
Nov 11, 2007 | Canon PIXMA MP780 All-In-One InkJet...
237 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
