Question about Canon FAX-JX200
Canon Fax Phone
Posted by beryl2 on Aug 11, 2008 Report abuse
just brought a Fax JX200 and am having great diffuclty working out a problem , problem being we also have a 2 phone dual handset and the problem is when the phone rings it goes straight to fax on all 3 phones even when its a phone call. We believe it is in the setting up of the fax phone as we had a fax before and that was fine, and every thing we have tried has not succeeded in changing this problem, with our new fax phone.
looking forward to hearing from you and hoping you can help me.
Thanking you
Christine McDermott
13 Cohen Street
Rosebery Tasmania 7470
Phone: 0364731659
E-Mail : [email protected]
Still need a solution for this problem?
  • mooseranger Nov 11, 2008
    Wehave the JX300 but same problem. Answer given to Beryl is just what is set out in the Manual. What we need is to know how many seconds to insert in those two places in order for the fax to have time to "know" it is either a fax call or a voice call. WE have two numbers on one line....supposed to be able to identify whether an incoming call is fax or voice, but does not seem to be able to.
    Keith Thompson [[email protected]] Canada
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
It sounds like Tel/Fax mode is not set, but that the machine is likely in Fax Only mode. The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which you have indicated is your desire, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls.
Set the mode by pressing [Receive Mode/Resolution]. Every time you press [Receive Mode/Resolution], the mode changes cyclically. If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings:
• Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting).
• Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting).
• Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting).
1. Press [Menu].
2. Use arrows to select <DATA REGISTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>.
3. Use arrows to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>.
4. Use arrows to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>.
5. Press [Start/Copy]. The LCD displays <8SEC.>
6. Use the numeric buttons, or arrows to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice. (This is the time the machine spends checking for a fax signal before ringing for the call to be answered as a telephone call.)
7. Use the numeric buttons, or arrows to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>.
8. Use arrows to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6.
9. Press [Stop].
Setting ends and the fax returns to standby mode. The machine will now handle calls as indicated in the settings you input.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Aug 16, 2008
  • Anonymous Sep 20, 2008
    Ms. McDermott:
    Did you try Tel/Fax mode and it didn't accomplish what you wanted? If you need further help, please let me know, as I will gladly help you to resolve your issue. Very often, problems of this nature may take more than one posting/communication in order to relay all of the facts relevant to the situation. Thank you for using FixYa.
    smartsolve
SOURCE:
Manual for Jx200 Canon fax
You can download the complete instruction manual in PDF format by clicking this link.
Click here to download the Easy Setup Instructions
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Apr 22, 2010 | Canon FAX-JX200
TX Report misses out Destination Number
The ID on the TX report only show the ID if the ID is programed on the fax machine you send it to.The only way is to ask the destinated party to program the Fax name.
Apr 30, 2009 | Canon FAX-JX200
Salut....nu stii ai instructiuni in limba romana pt fax canaon fax-jx200??
I do not speak your language, but it appears you need instructions for the JX200. Go to canon.com, choose the correct country, go to Support, Downloads & Drivers, and then the manual should be listed. Thank you for using and rating FixYa - and if you need more help, please post back in English. Thank you!
Aug 21, 2008 | Canon FAX-JX200
Fax Phone problem
did you set the duration of the fax to"listen " for a fax tone
do you have the manual?
look at page 41of 80 RX Settings
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=e038b5d4145a8a64a055b705acd590bf&q=Canon+JX200
Aug 12, 2008 | Office Equipment & Supplies
Just brought a Fax JX200 and am having great diffuclty working out a problem , problem being we also have a 2 phone dual handset and the problem is when the phone rings it goes straight to fax on all 3...
1. Press [Menu].
9. Press [Stop].
Aug 11, 2008 | Office Equipment & Supplies
VOICE MAIL AND FAX
The short answer is no. The JX200 will work with an answering machine because it "listens in" when the answering machine picks up a call. It can't "listen in" to voice mail, because the voice mail is handled by your phone service.
Mar 29, 2008 | Canon FAX-JX200
Canon Fax JX200 - fax interupts phone calls
Canon Support suggest changing the Remote RX code or turning off remote RX.
Goto fax settings -> RX settings-> remote RX
Nov 22, 2007 | Canon FAX-JX200
Canon FAX-JX200 Logo
455 people viewed this question
Clive
Clive
old marine
old marine
Ekse
