Hotpoint washer wf451 on off light and mini load light flashing
  • Anonymous Jan 07, 2009
    I have the same problem, I fiddled with the filter thing at the bottom and it drained, but then did it again. You can switch the machine off at the main switch for a few minutes, and then back on without pressing start, and the door should open, if drained sufficiently
I have this problem with mine as well. I've found if you leave it, it drains and then you can just power on/off and remove the clothes.
I did find howevet that the clothes hadn't rinsed properly so when ever this problem accours (which is most times) I always just Power off/on and then do a rinse and spin cycle.
Posted on Jan 27, 2010
Hotpoint aquarius WF541 won't finish a cycle
What is the model number? Look inside the door area.
Oct 18, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
Door will not open door light just flashing on and off
washer not spining mini load button flashing on/of buton flashing
Apr 27, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I've got a hotpoint wf220 wshing machine which is not spinning the pump is working and the on/off lights and mini load lights are flashing
i have a hotpoint wf321 water comes in and pumps out have flashing mini load light on and start light, but drum does not go round,
Jun 06, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My washing machine has just stopped working and the on/off light and the mini load light are flashing rapidly any ideas???? make ..hotpoint, model...WF560
TRY HOLDING IN THE SIGNAL LITE FOR 3 SECONDS AND THAT SHOULD TURN THE LITES OFF AND OR THE CONTROL LOCK LITE OFF ALSO!! GOOD LUCK
Jun 03, 2009 | Hotpoint WMA35 Front Load Washer
Water will not drain - rinse hold/mini load lights flashing
You might have to take the pump off and clean out the debris in the line theres probably lint, change and other things in the line. Take the lines off and run a piece of wire through the lines to make sure their clear.
May 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Machine freezing with three lights flashing.
HI JOHNNYHEFF,
JUST GOT A NEW HOTPOINT STARTED TEST WASH ALL THE LIGHTS FLASHED SO SWITCHED OFF TRIED AGAIN NO JOY. TECHNICIAN COME OUT SAID THE CIRCUIT BOARD WAS GONE, NOT GOOD NEWS FOR YOU BUT THOUGHT I'D LET YOU KNOW!
Oct 23, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
281 people viewed this question
Top Washing Machines Experts
