Question about Hotpoint TDC32 Electric Dryer
Dryer element not working
Replaced element,still not working,bypassed thermostats no heat,any more suggestions
  • 1 more comment
  • everton123 Aug 28, 2008
    My Tubble is the ctd40. the empty water light is on and there is no heat
  • Anonymous Sep 25, 2008
    Same here on TDC30P, thermostats and element replaced but still no heat.
  • Anonymous Nov 17, 2008
    I have a TDL62, which stopped heating we have replaced the heating element, and the machine appears to work fine, however there is still no heat.
    Are there breakers or a cut out switch on this model also which need resetting?
    Bernermad
If the water light is on and you have wasted money on a heater it's more likely to be a stuck float switch which cuts out the heater.Why don't you get the people who make it to repair it rather than DABBLE and get yourself in a mess??
Posted on Nov 18, 2008
  • 833 Answers
Reset both your breakers first and try again.  There are two breakers for the dryer.  The motor works on 110V and the element on 220 which is a third wire.  Go back to your service panel and trace forward.  If that doesn't fix it and you are not good around electricity, get an electrician in.
Posted on Nov 15, 2008
Crosley CDE4700LW0 FRONT LOAD DRYER
Shut power off to dryer at breaker. Pull the two wires to thermostat off terminals. Using electrical tape wrap around wires to join them. This will bypass your thermostat. Turn power back on. Start dryer. If it heats your thermostat is faulty. If it doesn't heat it is most likely your heating element.
Dec 10, 2012 | Crosley Dryers
LER4634EQO Whirlpool Heavy Duty Extra Large Capacity 4 cycle 3 temptures My dryer is not heating. I have checked the breaker(s). There is not much lint around the dryer in the back or the vent, what...
The problem is likely in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Disconnect power then remove the rear access panel to access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make.
The
thermal cut-off (cut-out) and high-limit thermostat are sold as a kit with part number 279816 and costs about $30.
In case the dryer still doesn't heat up with the
thermal cut-off (cut-out) and high-limit thermostat bypassed, bypass the cycling thermostat then replace it if the dryer heats up. Check the heating element for broken coils if the dryer still doesn't heat up with the three components mentioned above bypassed.
Feb 10, 2011 | Whirlpool LER4634J Electric Dryer
Where would the fuse be and how hard to get to, is it in the upper unit? From behind? or lower unit? Running but no heat.
The problem is obviously in the heating circuit which is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components.
Disconnect power then access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make. Indicate the exact model number of the dryer should you need further assistance.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Also bypass the cycling thermostat if the dryer still doesn't heat with the thermal cut-off and the high-limit thermostat bypassed. Check the heating element visually for obvious broken or damaged coil. An ohmmeter will be of great help in checking the resistance/continuity of the heating element. Replace the heating element if broken or damaged, NEVER attempt to repair it.
The problem is likely in the motor centrifugal switch if the dryer still doesn't heat with good heating element and the three components above bypassed. Indicate the exact model number of the dryer should you need further assistance.
Feb 01, 2011 | Dryers
Dryer quit heating no power to element what is wrong?
The problem is most likely the thermal cut-off and the high-limit thermostat. The thermal cut-off blows when the high-limit thermostat fails and since these parts are wired in series with the heating element, power to the heating element is therefore terminated. Check the continuity of the thermal cut-off and if it reads open, replace it along with the high-limit thermostat.
You can bypass the thermal cut-off and the high-limit thermostat for troubleshooting purposes. Join together the wires of each part and insulate it properly then reconnect power. The two components indeed need to be replaced if the dryer heats up. If not and still no power to the heating element, check the continuity of the heating circuit. Check the continuity/resistance of the heating element if there's power to its terminals but doesn't heat. Replace the heating element if it reads open.
Let us know if you need further advice. Just indicate the exact model number of the dryer for accurate troubleshooting tips.
Jan 23, 2011 | Kenmore 700 6972 Dryer
Model RES7745PQ0 works great but no heat... what is most likely the problem... also I checked my breaker so that's not it...? HELP\r\nBest Regards
The
Jan 19, 2011 | Roper Dryers
Model LEQ9508PW1. It has stopped getting hot. Just stopped putting out any heat. I assume that it is probably the heating element that has gone out. Is there anything else I should check first before...
Check first the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing by bypassing the said components. Disconnect power then remove the rear access panel to access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect the power then start the dryer. The problem is in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make.
Also bypass the cycling thermostat if the dryer still doesn't heat up with the thermal cut-off (cut-out) and the high-limit thermostat both bypassed. If the dryer still doesn't heat up, take the heating element out and inspect it for damage. Replace the heating element if damaged.
Jan 18, 2011 | Whirlpool Dryers
Our Whirlpool dryer model #LER7646AQ0 will not start. Door switch checks for power with a power tester. Put new start switch in and still doesn't work. Do I need to use Ohm tester or will power tester...
This problem is commonly caused by a blown thermal fuse located on the blower housing. The thermal fuse is wired in series with the motor and the motor activates a centrifugal switch for the heating element when it runs. These setup makes the dryer fail to start and the heating element not to turn on if the thermal fuse is blown. The dryer seems to no work at all. Verify the condition of the thermal fuse by bypassing it and starting the dryer.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the rear left bottom of the dryer cabinet. Remove the rear panel to access the blower housing and so the thermal fuse.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the cycling thermostat if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
The thermal fuse and cycling thermostat are part numbers 3392519 and 3387134, respectively.
Jan 11, 2011 | Dryers
Dryers tumbles but there is no heat
Dec 31, 2010 | Kenmore 600 6965 Electric Dryer
My kenmore dryer is blowing only cold air. What is wroge? We already checked the heating element and timer...???? This dryer is only 4 years old.
The heating circuit is composed not only by the heating element and the timer but also with a high-limit thermostat, a thermal cut-off, and a cycling thermostat. The high-limit thermostat and the thermal cut-off are both mounted on the heater housing to monitor and regulate the heater temperature while the cycling thermostat is mounted on the blower housing to monitor and regulate the temperature of the exhaust air.
All of these components are wired in series and a failure in any of them results in the dryer not heating. The proper troubleshooting is by checking the continuity of each of these components with a volt-ohmmeter and replacing the ones found without continuity (open).
A continuity check can also be done by bypassing each of the three components, never the heating element, and then starting the dryer. The dryer should heat, otherwise the problem is somewhere in the timer, the heating element, or the centrifugal switch within the motor. When the dryer heats up, unplug it then un-bypass one of the bypassed components and start the dryer. If the dryer stops heating then you have found the failed component; replace it. If the dryer does not stop heating, do the same to the remaining components until you find the failed one. Just make sure the dryer is unplugged before touching the components.
Replace both the high-limit thermostat and the thermal cut-off if any of them has failed. Indicate the exact model number of the dryer if you need further or more specific advice.
Jun 12, 2010 | Kenmore 63942 Dryer
Sounds like it could be a faulty heater relay.The relay is located at the top behind the console panel.
It is a clear plastic box with the contacts inside it.
If you have tried everything else, then this what I would go for.
Hope this helps.
Please leave feedback.
Dec 06, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
185 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
