Question about Samsung HT-P38 System
Home theater suddently turn off
When play a dvd/cd, suddently word "protection" appear and player will turn off by itself
  • agarneau Nov 02, 2008
    I have a very similar problem. When I turn the unit on (power on), it tries to boot then the word "PROTECTION" is displayed and the unit shuts off.
    Any suggestions ?
  • Anonymous Jan 04, 2009
    i have the same exact problem, any solutions??
  • Samsung Master
  • 19,396 Answers
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
The DVD player will stop playing and the message
It is possible that your system is gettting overloaded and makes the sfety cicuit switch off . This is the protecction circuit to prevent further damage and fire within the system particularity when the output or power is shorted. Check from the speakers for short remove and test . Also use a multimeter to test for short in the output drive. If so disconnect and see if the protect releases. Then you must replace the outputs. Check also the protect cicuit for a false alarrm due to wrong biasing. Hope this advice helps to figure out. Good day
Jul 20, 2010 | Sony DAV-C450 System
It turns of by itself, said something about fan then turns off.
It is going into PROTECTION mode because of a failing fan. Take the fan to Radio Shack and match it up.
Apr 18, 2010 | Samsung 1000W 5.1-Ch. Home Theater System...
Samsung dvd player switches itself onto protect!
hi,i can't connect my audio tv to cinema theater dvd
Apr 02, 2010 | Televison & Video
I have a samsung DVD Home Theater System HT-WX70. My son put a cd copy in the DVD player and PROTECTION flashed on the player and it turned off. I turned the player back on and took the cd out. ...
If it is, the protection message usually meant either a speaker had blown, or more commonly a wire to a speaker had come disconnected or broken/shorted.
Try unplugging the speakers one at a time, and if you have a set of speakers of the same rating to try, try plugging them in as you remove the originals (obviously doesn't need to be done in the setup positions in the room, just have them beside the player to check it works.)
This might then identify which speaker or cable is the problem one for you to replace or repair.
If this is the speaker overload/short mesaage as I think it is and the above doesn't cure it, it would appear the amplifier board has a short somewhere and that's an electronics engineer job time
Hope it helps!
Nov 18, 2008 | Samsung Televison & Video
Panasonic home theater sound system SC-HT720 won't read or play dvds or cds
mine does the same.the display flashes "prog" and --:-- on cd's,dvd's and even the cleaning disk it almost sounds like it isn't getting enough power to spin the disk.
Jun 23, 2008 | Panasonic Home Theater System System
SC-DK20
That home theater system is not decoded to play those copied disc try using maybe a different brand name CD-R/DVD-R when you make your copies.
Nov 20, 2007 | Panasonic SC-DK20 System
Cd player.....toshiba se-r0094
I have been having the same problemm, how can i solve this?,,thanks, Reg!
Nov 07, 2007 | Audio Players & Recorders
Samsung HT-P38 System Logo
442 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
