Question about Canon Pixma MP500 All-In-One InkJet Printer
Only prints 25% of page
When I print (or even copy), the printed page only shows about 1/4 of the image.  I've reset all of the settings, thinking that it may have been set to print a 4x6 photo or something like that, but that didn't work.  Any ideas?
  • mp500sing Aug 14, 2008
    Yes.  it is set to letter, but seems to only print  the upper left corner of whatever is sent.  And it doesn't shrink the entire image to fit in that space.  It just prints whatever would have been in that corner if the entire letter size image or document had printed.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Are you sure it's set to Letter? and not A4 or a diferent size?
Posted on Aug 12, 2008
  • CheckitRight
    CheckitRight Aug 14, 2008
    1-do an internal test print -------does print the entire page or the corner? If entire page the problem is with the application
    2-If corner as well, then the problem is within the printer---most likely the data cable that connects to the printhead. It may be broken and only makes contact at that point, or loose
Only printing 1/2 the image of the selected photo, I have tried changing the printer cartridge but still only prints 1/2 the selected image, any ideas why this is happening?
I am not familiar with that particular printer, but it could be as simple as making sure you have the entire picture selected..but it sounds more like the cartridge is either clogged or there is a setting that needs changed...try aligning the cartridge(s) and printing a test page. (that part is usually under a maintenance or troubleshooting type section) if that turns out fine, then there may be a setting thats off...look at your print settings...you may have a separate section just for printing photos...even if you don't, look at your page setup.. look specifically at the margin settings...that might be where the problem lies..you can always play with the margin settings- i would recommend saving them under a custom setting if you want to keep them, instead of default though...that way you have your regular settings for general printing... and do a "print preview"...that might be a good idea anyway, so you wont have to waste ink and paper trying to get your stuff to turn out how you want it (plus that will show you if margins are set right)...for that, there should be a checkmark box you can select to always do print previews...
also, look to see if you have a selection or checkmark box that says "fit to page" or where you can select how many copies you can print per page..this can be used for everyday printing, as well as for photos...
you may even see a spot where you can select the size of photo to print...usually you can pick to print "wallet size or 4x6, ete." and how many to print on a single page...maybe even multiple sizes per page...these are several options for you to look at...hope it helps :)
Jul 30, 2015 | Samsung SPP-2040 Digital Photo Printer...
Printer will not print entire document. If I have a 46 page doc, the printer only prints half. I enter the rest of the doc, and it prints maybe four pages then stops again.
Try printing pages 1 through 25, let printer cool down, print pages 26-46. I'm, thinking it's a print head overtemp problem. If the second printing will not do the complete 26 to end, let the printer set for a longer time to cool off and try again.
Sep 21, 2009 | Office Equipment & Supplies
I have a Samsung CLP-510 and I want to print 500 copies of the exact same document, which is 2 pages color. When I do this from MS Word, the printer takes about 25 seconds thinking between each copy. It...
CHeck your settings. If they are ok, then try printing the job from open office or wordpad. Are you using 2 sided printing? I have the same printer and it blazes thru stuff like this printing 2 sided and all. Just have problems with using cheap paper (jams).
Feb 04, 2009 | Office Equipment & Supplies
Print source code of an Access Database
Hello cbw@netzero.com,
The source code request would be for a program code, appropriate if you actually wrote the code for the Excel program, but if you are copywriting a set of formulas or an excel execution sequence, then you want to print your formula view for copywriting.Excel has a Formula View that shows the formulas on your worksheet rather than the results of those formulas. You toggle between Formula View and Normal View by pressing CTRL ~ on your keyboard. Just toggle to formula view and print your worksheet to see all of your formulas.
Good luck with your copywrite!
Oct 06, 2008 | Microsoft Office Professional 2007 Full...
Double sided printing Pixma MP520
here's how:
print double sided pages
1. Set your computer software for double sided printing if you have a printer that is compatible. Double sided printers are generally professional style machines, and most offices, schools and libraries will have them. On a PC, go to the drop down "File" menu and select "Double Sided Printing" under the "Preferences" or "Properties" window and print. If you have a MAC, click "Copies and Pages" under the "File" menu, select "Layout" and then click on "Long-Edged Binding" and print.
2.Print double sided with your standard home printer, again, by setting your PC writing software. When you are ready to print, click on the drop down "File" menu and select "Print." From the "Print" window select "odd pages only," or "even pages only."
3.Set your odd and even pages a bit differently if you are working with MAC writing software. Select "Print" from the drop down "File" menu and click on the arrow to drop the "Copies & Pages" menu. Under the "Copies & Pages" menu, select "Paper Handling" and then click on "Odd Numbered Pages" or "Even Numbered Pages."
4.Select "Odd Pages Only" or "Odd Numbered Pages" and then print as usual. It is a good idea to mark the top of your first page with a pencil so that you know the direction and side of the page your printer prints. Use the mark to determine how to turn your pages and place them back in the printer. Select "Even Pages Only" or "Even Numbered Pages" and print again. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Sep 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Printing steps for 4x6 size photo paper
Try this :
1) Within your application click on FILE and PRINT
2) Depending on the application in use, you may see either "Printer" or "Format for". Ensure your printer name is selected here instead of "Any Printer".
3) Click the up/down arrows next to COPIES and PAGES to see all the available setting options:
A) COPIES AND PAGES
Allows you to select how many copies you want and if you want to print all pages, selected pages or a specific page.
B) LAYOUT
Adjust the way the image is displayed on the media for multiple page printing.
C) SCHEDULER
Allows options for when to print a job, such as specific time or to hold the jobs, and the priority of the job to be printed for networked machines.
D) PAPER HANDLING
More page options, such as even or odd pages only, and reverse print order.
E)COLORSYNC
Connects to color options managed by the ColorSync Utility.
F) COVER PAGE
Provides the option of including a cover page or not with your prints.
G) PRINT SETTINGS
Select your MEDIA TYPE and INK. You can also create and save CUSTOM SETTINGS through this area.
H) COLOR MANAGEMENT
Adjusts BRIGHTNESS, CONTRAST, SATURATION, and INK balance. Also gives ability to allow COLORSYNC to control all printer colors.
I) EXTENSION SETTINGS
Provides the option for printing on thick paper and envelopes * This option may not be present with all models.
K) SUMMARY
Details settings chosen in other options.
After making the changes appropriate to your set up and print job, click on PRINT.
Aug 19, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
63 people viewed this question
old marine
old marine
