I have installed the printer and tried installing with the software but for some reason it is not finding the connection from the printer to the computer
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Try
Start
Settings
printers and faxes
is it there? right click and set as default the runtest page
if not try to download from the manufacturer's site or at
driver .com
Posted on Aug 12, 2008
My printer has eror red light indicator on top of my printer what should i do to connect my printer
Dear
The red light blinks for many reasons. You may try to know exact problem with the use of SMART PANEL a software that can downloaded from samsung web site and install in the PC.
After installing the software get a test print. or open the smart panel from the program.
thanks.
Jan 20, 2015 | Samsung ML 1610 Laser Printer
Installing HP4795 printers in Windows XP. During install XP cannot find print drivers. Can you tell me how to point install to the print drivers?
Click on the link below to download the Printer Drivers and later install them.
Download Link
After you download the file, run the file to start installation and complete the installation.
Disconnect the Printer cable before the installation starts and connect it when asked to.
If for any reasons, it does not recognize the printer connected, complete the installation by clicking on the option ( I will connect the printer later ) and complete the installation.
Then Click on the Diagnostic download option below to run the diagnostic tool to diagnose the issue.
HP Print Diagnostic Tool
My Suggestion would be to completely uninstall the software and reinstall it using the Download Drivers option above in this solution.
Thank you for contacting FixYa
Regards,
Ron
Dec 23, 2010 | HP C4795 AllInOne InkJet Printer
No scan options
Try installing all the software from CD that came with the printer, or download it from HP website (choose complete solution). Also, install the software first and after that connect the printer. If you previously connected printer prior to software installation, you have to use scrubber.exe (find it on the CD) to "clean" and remove any wrongly installed HP files.
Nov 05, 2010 | HP J3680 Officejet All In One Printer
Computer can not find bluetooth device printer HP Photosmart C
Step one: Install the softwareRe-install the software so that the appropriate choices can be made during the installation to resolve the issue.
  1. Insert the printer software CD in the CD-ROM drive of the computer. The software installation starts automatically.
    NOTE: If the software installation does not start automatically, click theStart (c00845897.gif ) icon. In the Start Search text box located above theStart (c00845897.gif ) icon, type D:\setup.exe , where D is the letter of the CD-ROM drive, and then press Enter .
  2. On the User Account Control window, click Continue .
  3. Follow the instructions that display on the screen to install the software.
    NOTE: If the User Account Control window displays during the installation, click Continue .
  4. When prompted to choose the connection type, select Directly to this computer using a USB cable and then click Next .
  5. On the Connect Your Device Now window, select If you are unable to connect your device now, click this box and then click Next to finish installing the software. You can connect your device later.
  6. Click Next .
  7. Follow the instructions that display on the screen to complete the software installation.
Step two
AND STEP THREE
GO TO URL
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00845953&lc=en&dlc=en&cc=us&product=447858
Dec 13, 2008 | HP Photosmart C5180 All-In-One InkJet...
Scanner says usb not connected
Ok - the reason this error pops up is because there is a software issue going on. If the software is correctly installed you will see options for where the scan will go in the computer.
Having said that there are several things that can cause a problem between the printer and the software;
1) You are connecting the printer by USB to router - you may print but will never be able to scan as this is not a networkable printer. Connect it directly to your computer and recomplete the setup portion to configure the scanner.
2) You have not finished the setup. At the end of the installer you can setup the scanner but if you skipped this step you will have to redo it in order for it to connect. Click on the device manager in your dock and then next to information and settings there will be a little wheel. Click on the wheel and go to setup assistant. Complete the assistant and try to scan.
3) The printer is not grabbing the new software options - leave the printer turned on but unplug the power cord and wait for 30 seconds. Plug printer back in - when you do this it should initialize and will look to the mac for changes and the options should load.
4) Software missing - You MUST have the software for the printer installed for scanning function. Adobe and other programs cannot replace it - it has to be installed.
5) Software is corrupted. Uninstall the software (uninstaller is under applications in the HP folder) and then download (www.hp.com) and install the most recent full feature software and drivers for your operating system.
6) If all these steps fail you may have an issue with your computer and it's TWAIN drivers.
Oct 05, 2008 | HP PhotoSmart C4280 Laser Printer
J5780 Installation Problem on Windows 2000 PC
hi this is due to improper Software Installation stapes below
  • Un install all printer driver & software u install
  • disconnect printer from computer
  • restart u r computer
  • insert Software cd in to cd rom
  • install software ,follow instruction & fill up Information.
  • when notify you to please connect printer thorgh USB please connected Usb cable to your Printer.
  • printer shuld be ditected then follow instruction
  • complite Installation & cheak it out..
If this information is useful for u please rate me....
Jun 09, 2008 | HP Officejet J5780 All-In-One InkJet...
Printer does not respond when trying to print documents and have to keep installing the program
open the printer folder and right click on it then cilck on use printer online n ur done.
if u r using windows, click on start then on printers and faxes u'll see list of printers there. right click on the printer u r using then click on use printer online
thank u
May 26, 2008 | HP Computers & Internet
My hp psc 1100 series 1200 series will not be reinstalled onto my machine. It was already installed but for some reason it uninstalled itself. When I went to put it back in it is not recognised printer...
First make sure the power supply (if it has one) is plugged in and receiving power.
Try a different USB cable - maybe the cable is bad, it happens.
If not, try plugging into a different USB port on the same machine. If it still isn't recognized, try plugging it into a different machine.
If it isn't recognized on a different machine, then there's probably something wrong with the printer itself and it's time to contact HP support.
May 09, 2008 | Office Equipment & Supplies
Printer wont instal ><
Did you just install windows Vista?? If you did, disconnect the printer from the computer and reload the lexmark driver. Windows will pop up a message saying that it doesn't recognize the software being loaded. Click to load anyway. The instructions will tell you when it is ok to connect the printer.
Vista tries to install istall its own driver for anything you connect to you computer. Always install the products driver before installing the device.
Apr 12, 2008 | Lexmark X83 All-In-One InkJet Printer
Dell All-In-One 810 Printer installation problems
From what you describe the printer is not installed correctly. I would try uninstalling everything associated with this device, unplugging it and then retry the installation process again. I don't know if the instructions are clear but you should not connect the USB cable to the printer until after the software is installed or when prompted by the software wizard.
Jan 01, 2007 | Dell 810 All-In-One InkJet Printer
18 people viewed this question
jasbo
jasbo
