Sony sub problem
Did you ever get that figured out? i just got one myself. does it say wg990 on the back of the sub? thanks for any help
Eventually I got curious and plugged it into an amp. Turns out it's passive after all, and will run off an amp. Doesn't have a built in crossover etc though, so you'll need to find some way to filter the signal first.
As far as I can tell, the extra cable is just attached to the switch on the front. So it's only really a circuit breaker, so make it look like a powered sub. very sneaky!
oh, and I'm pretty sure that's the label on the back. I'm not at home right now, so I can't check.
hope that helps man. Good luck!!
Posted on Aug 16, 2008
Im getting sound through my wired speakers but no bass through the woofer itself, does this mean i have a blown fuse or something more serious?
1. Check audio wiring.
2. Check subwoofer power cable.
3. If you have any way to substitute for the subwoofer this can confirm wiring.
4. The crossover in the amp may not be working, sending no low range to the subwoofer.
Jul 22, 2014 | Sony SA-W10 Subwoofer
Ok i just got the sub from a sony sswg450 i want to know is there some way to hook it up to my Pioneer home Receiver
Did you get a manual with it? According to the Sony site this speaker originates in Sony MHC-GX450.
"This product bundle includes the following models:
HCD-GX450 - STEREO MINI SYSTEM
RM-SC3 - REMOTE CONTROL for Shelf Mini Systems
SSRG444 - FRONT SPEAKER FOR MHCGX450
SS-WG450 - SUBWOOFER FOR MHCGX450"
Find the manual here and learn a bit about your seprated sub...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX450
See page 7.
As can be seen, the subwoofer has two connections to the mothership, very unlike the standard speaker level (+/-) speaker wire or RCA-Line-Level subwoofer out that 'normal passive or active subwoofers use, respectively.
Not knowing which of those your unspecified Pioneer receiver supports, it is impossible to say. Does your Pioneer have that control jack?
Mini-systems are generally not designed to be pieced out and used with grown-up gear. The absence of standardized connections is the clue.
Apr 17, 2011 | Sony MHC-GX450 CD Shelf System
I have a sony str de 325 receiver....what sub woofer will go with it and where do you plug it into the receiver?? Thanks
You will need a powered sub, one that has a built in amp. It will also need speaker terminal type inputs. Use the B channel to send signal to the woofer. Since the audio from the B channel is full range, use the crossover on the sub to determine which frequencies you want to hear. I would start at 100Hz and go up and down from there. Use the gain to adjust the volume in relation to the other speakers. The sub volume will be affected by the master volume.
Please rate if this helpful
Apr 05, 2011 | Sony STR-DE325 Receiver
How to open a Sony Vaio PCVA-SB1 Subwoofer
call an assistance or technician to help you open your Sony Vaio
Jun 18, 2009 | Sony 182556522 1-825-565-22 SUB WOOFER...
Is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Sub not working with amp
Connect a sub cable to the amps sub OUTPUT then to the sub input turn the volume up half way on the sub then go to the amp setup menu and make sure the sub is switched on then set the cross over to suit your speakers,if your not sure set to 80hrtz.
Hope this helps.
CABLE GUY.
Feb 24, 2009 | Sony STR-DE475 Receiver
Sony xplode cd player sub problems
Switch your blue wires around.
You have put the remote antenna wire to the remote turn on of the amplifier. The radio cuts off the power to the "power antenna" when you switch to a different mode... so your amplifier is now losing the turn on signal it requires to stay on.
Simple 2 minute fix.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 19, 2009 | Sony XPlod CD Player w/MP3 Playback...
Support Question about RMS
you are going to need an amp that can supply the right amount of rms power to make it sound good. these sony subs are rated for 380 watts rms. so in order to find an amp that will supply two, you must multiply that figure by two. so you will need an amp that can supply around 500 to 750 watts continuously (or rms). also you are going to want an amp that is either class d or class ab rated. these amps are built to push subwoofers exclusively and will give you the best efficiency and sound out of your subs. you will also want to get an amplifier is a monoblock amp, and not a stereo amplifier. make sure the amp can put out that rms rating at 2 ohms as two 4 ohm speakers equal 2 ohms wired in parallel. i have a kenwood kac9152d that puts out about 2000 watts max at 2 or 1 ohms (900 watts rms) that i used with my two sony xplod 10's for about 2 years. it was kick ***! now i dont know if you need that much power but they will handle it as long as you dont push them too hard for long periods of time, otherwise you might end up blowing them up! (depending on the box size that is, and the quality of it as well...)
i have years of car audio installation experience and can help with setting up and wiring any mobile entertainment system you can imagine. may i ask what kind of music you listen to and what kind of box do you have for these subwoofers?
if you have any questions email me at thadoggma420@hotmail.com
Jan 22, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
What voltage required to power a sony subwoofer
Hey,
I just got one of these units, the SONY SS-WG990.
The RCA cable is direct conection to the speaker.
It requires external AMP.
The other cable is just for the system switch and LED.
If you just have this unit, all you need is an AMP to
feed it.
Apr 12, 2008 | Audio Players & Recorders
101 people viewed this question
 Grubhead
Grubhead
