Question about Intel Motherboard
Enable raid in GCNL board - Intel Motherboard
  • 162 Answers
Try looking in the bios for the enable feature.
Posted on Nov 14, 2008
Lkmjl;mjd
Posted on Sep 10, 2008
2 Suggested Answers
tonybudz
  • 162 Answers
SOURCE: RAID AND GCNL BOARD
jumper configurations not correct?
Posted on Aug 12, 2008
Moter board n1996 raid mode how can i reset?
By reset I guess you mean you want to enable or disable raid. The BIOS might have the option or right after you start the PC watch for a key combo to access the software and modify some parameters.
Jul 13, 2014 | Acer Veriton 7600GT PC Desktop
Having trouble booting two Raid-0 discs on Asrock Z77 Ex4 UEFI
RAID implementations will vary from controller to controller, and even from bios to bios revision or version for the same controllers.
You should "image" the raid on the old board, then delete the raid on the old system.
In the new system, you need to treat these drives like they are new, blank hard disks. Any partitions will need to be removed, and the RAID created on the new board. Once this is done, you can use your partition imaging software to drop the data back onto the new RAID partition. Seagate I believe has imaging software available in Seatools, or you can use something like Acronis True Image or GHOST.
May 16, 2012 | Computers & Internet
How do you turn on the SATA controllers for this board? By this I mean how can you put the SATA connections and their drives into the boot order? I can't see this option in the BIOS only to enable the...
SATA Controllers are always on. you can't disable or enable it.
RAID and SATA are two different subjects and they are not dependent each other.
so if you got a problem with your motherboard explain it clearly.
Jan 12, 2011 | MSI K8N NEO2-Platinum (MS7025) Motherboard
I have Dell PowerEdge 2550 Server. I want to configure RAID, but I can't reach RAID MENU! I have DELL 2550 Server BOOT CD and Dell OpenMenage Server Assistant V7.2. All of them are running, but I...
RAID menu will either be CTRL-A (if you are using the onboard PERC 3/Di) or CTRL-M (if you are using an addin PERC 3/4). If you are not seeing either of these options, then you may not have it enabled in the BIOS. In the BIOS (F2), go to Integrated Devices and make sure that RAID is Enabled. In order to enable RAID, your server MUST have a RAID key, RAID memory DIMM (different from system memory), and a RAID battery.
Aug 12, 2010 | Dell PowerEdge 2550 Server
May i use graphics card wid my 945 gcnl mother board plz help me
yes you can use graphic card such as (AGP) if your motherboard has AGP slot on the motherboard, before installing the graphic card, goto CMOS setup by pressing F2 or Del key while your system bootups and disable the onboard display in the setup and save it, then switch off your computer, then install the graphic card and start your computer hope your computer will works fine.
Jun 20, 2009 | Samsung (SC-152) Internal 52x CD-ROM Drive
I have a asus K8S-MX i want to connect SATA HDD
To enable sata port press Delete Key when computer Starts. U will get BIOS menu. On there the Main settings window the second last option is to enable sata option. If u want to install widows OS (XP,2000, Server edition) **** Driver CD and go to RAID folder there u get a driver ( shown as Floppy drive Image). Incerte Floppy in drive and click that icon. And click Extract. Then incert the OS CD. On starting of instalition u will get a option press F6 to install Raid Disk. Press F6. On Bitween instalition u will get a option to install this Raid. ( With out this RAID u cant install XP or Other vartions of windows in ur sata hard drive)
Mar 31, 2009 | ASUS K8S-MX Motherboard
May i use graphics card wid intel 945 gcnl mother bord
no u can not use as intel comes with its integrated accelerator...i.e intel GMA
pls rate...cheerrsss...
Nov 23, 2008 | Samsung (SC-152) Internal 52x CD-ROM Drive
RAID AND GCNL BOARD
Aug 12, 2008 | Intel Motherboard
Sata raid config
first check your bios & see what raid chips are enabled,usually there's 2. Your main raid is on the first 4 sata connectors, the other chipset probably controlls the remaining sata ports. So if there's an option to disable one raid chip,disable one,just not the one that you're using. I don't know what your bios screen looks like,so this is just a general view based on my experences with various boards,mainly asus.
Jul 13, 2008 | Abit AW9D-MAX Motherboard
Raid JMB363 RAID BIOS UTILITY
The P5K motherboard has a four port vanilla ICH9. There
Is no RAID on the Intel, when the chip has only four ports?
So S1, S2, S3, S4 are not RAID.
In the P5K manual, the RAID function exists on the Jmicron
Controller. One drive connector is internal (SATA_E2, on the
Left of the motherboard picture in the manual), and one
Drive connector is external (F_ESATA on the back I/O area).
This is not convenient for building a RAID0. (The intent is
To allow making RAID1 backup disks.) You'll have to snake
The SATA cable back into the computer, if you hope to use
It with two internal SATA disks.
The manual has full instructions for setting up RAID on the
Jmicron JMB363. The manual says to set the Jmicron to RAID
Mode in the BIOS. Two disks must be connected, in order to
Be able to press <control-J> at the start of the BIOS, to
Enter the Jmicron RAID setup in the BIOS. At that point, you
Can declare an array in the BIOS setup.
Then, when Windows is installing from the Microsoft install CD,
You’ll need to press F6 and offer the Jmicron RAID driver.
Section 5.5 of the Asus manual, describes how to make
A RAID driver floppy. The application in the mother board cd is available for make drivers disk
Dec 07, 2007 | Intel D101GGC Motherboard
Intel Motherboard Logo
21 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
