SOURCE: Power Cord assembly in Sears Kenmore air condtioner
there should be a diagram on the side of the case that will help clarify
SOURCE: We have a kenmore humidifier
Noodles, it sounds like the float valve inside the water reservoir is stuck in the down position. Turn the water line ON/OFF valve to the humidifier OFF. Open the top of the reservoir and you will see the float valve. Gently, lift it up, to see if it will remain at the top of the water level, which left in the reservoir. It it doesn't, then the float needs to be replaced. In the mean time, leave the water line ON/OFF Valve OFF.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
SOURCE: my kenmore electric dryer turns
that would be a broken belt, or the motor, I say belt. You will need to open the top of the dryer and look in the middle of the drum for a belt, which is not there I am sure, here are some websites,Tim:
how to change belt:
http://www.ehow.com/how_4814455_change-kenmore-dryer-belt.html
belt routing Kenmore is same as Whirlpool:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.htm
SOURCE: kenmore window air conditioner model
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
