Question about Maytag MMV5165 Microwave Oven
Maytag - MMV5165AAS
Its smells like burning plastic and its lauder.
  • 1 more comment
  • hnino12 Nov 02, 2008
    The microwave was working fine we had it set up for 7 minutes then at about 3 minutes left started the laud noise and it did not finish heating the meal.
  • Anonymous Nov 13, 2008
    Mine will make the loud noise rather sporadic. The smell is there also. It will not heat while this is going on. It does'nt matter what you are cooking or for how long. Some days it will work fine. I have had this problem since I installed the microwave. I should have had it looked at under warranty but did not. I don't know if I will ever purchase another Maytag anything because of it.
  • William Miller
    William Miller May 11, 2010
    Is there any burned-looking spots inside the cooking cavity at the sides or in the ceiling?
    I'm first suspecting grease and arcing on the waveguide cover...
If it is under warranty, call service. I experienced similar odors, sounds, and failure to heat meals. The magnetron/emitter and the transformer are replaced on two separate failures. Now the third time just happened. I am afraid mine is out of warranty and I will not purchase Maytag again.
Posted on Dec 21, 2008
SOURCE:
I have a maytag model mmv1164ws when you turn it on makes a buzzing and smells like something burning!
Something is burning, there are high voltage parts in a microwave oven and they wear out. You probably need a new diode. Part number WPW10492276 google it
Aug 30, 2016 | Maytag MMV1164WS Microwave Oven
What to do when oven smells like burning plastic
new ovens do have a certian amount of "burn in" to do when there new best to heat up and cool off oven several times before actuall food use to remove any construction solvents and "cure" all the materials inside
also ck to make sure you removed all the shipping packing sometimes this gets left inside by accedent and smells something horrible when heated ( caution :: Foam degrades to cyanide deadly gas when heated!!!!)
Sep 08, 2014 | Microwave Ovens
Smoke and burning plastic smell in microwave oven
Burning plastic, not food? A component has overheated badly then, with a plastic case. The main suspect would be the high voltage capacitor in the magnetron supply. This is cheap and easily replaced ONLY IF you know what you are doing and can diagnose the fault. If you don't then DO NOT take the case off the unit as fatal voltages can be present inside even if the unit is unplugged.
I'd just buy another, as they are generally uneconomical to have repaired by a service tech.
Dec 31, 2013 | Sharp R-1610 Microwave Oven
Does not heat, hot or burning wire/plastic smell. Louder noise than noise than normal.
Sounds like you have a bad magnetron. Not much worth replacing in these over-the-range microwaves except the fuse. Repair will cost as much as a new one and the high voltage circuit of a m/w is not somewhere I would recommend a DIYer to mess around in.
Dec 28, 2010 | Maytag MMV1153A Microwave Oven
Microwave not heating and giving burnt plastic smell
STOP USING IT!! UNPLUG IT!! Microwaves are inexpensive now. It will cost you more than a new one costs, to get it fixed.
Apr 02, 2010 | Microwave Ovens
Maytag micro shot smoke. Left burnt smell
That would be my guess t possibly has shorted out.
Dave
Feb 05, 2010 | Maytag Appliances Over-the-Range Microwave...
We brought a Tesco microwave at CULLOMPTON Tesco, Devon last week. It cost £29.00 on its first major use - cooking potatoes for ten minutes - smoke seems to be coming from beneath the machine - it has...
This is almost certainly some of the protective oils and varnishes which were applied during manufacture flashing off.
All new products of this type do this to some degree but your description seems to indicate that it's much worse than normal with your machine.
Ordinarily, you can expect this to cease after a few uses and if the level of smoke and odour you've described is to be expected then the instruction booklet should say so. But as yours has visible smoke and a burning plastic smell I'd recommend that you exercise your rights under the Sale of Goods Act and return it to Tesco for a full refund or replacement. The smell of burnt lubricant is one thing, but a burning plastic smell means you can never trust the oven to be safe: none of the many microwave ovens which I've dealt with have ever smelled of burning plastic unless there was a fault.
You won't find any objection from Tesco as they do have good customer service; and when I lived in Cullompton briefly earlier this year the local branch was even better than usual at keeping customers happy.
I hope that you have found my reply to be of assistance and ask in return only that you return the favour by rating my answer.
Nov 05, 2009 | Microwave Ovens
Microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jan 25, 2009 | Kenmore 64663 Microwave Oven
I bought a used maytag model mmv5165aas over the range microwave oven and need the mounting templates and manual for it. and suggestions on where to find the or who is selling them other than...
You can download the owner's manual and installation instructions here.
You can usually find helpful exploded view diagrams and order needed parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 07, 2008 | Whirlpool Microwave Ovens
Maytag MMV5165 Microwave Oven Logo
297 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
