SOURCE: LG CH08LS10 (Blu-ray Drive)
Hey - sorry to hear you're having problems.
First go here - -please I know it is a pain - but READ a lot - do the test and if you do not glean the fix - keep the results and come back here -
http://www.cyberlink.com/prog/bd-support/diagnosis.do
Thanks
RICESKI
SOURCE: I bought an LG external
install an LG burner on a MAC
if the burner shows as connected or mounted on your screen you just have
to install or use your burning utility i.e. nero, sonic, or whatever you have installed on your mac.
when you open the program and have your files already processed and ready to burn, it will ask you what unit you want to use for the task, open the menu and select your burner, click next or continue, the encoding will start, when it finishes the encoding the burner will start.
if you are using a USB connection it should work with your software
Testimonial: "Thanks! It works! I bought Toast Titanium and it recognizes the drive fine. Of course it does not work with protected videos - Thanks again! Bruce."
SOURCE: need a windows 7 driver for the Panasonic UJ-240
go to pannasonic support and drivers you should find what you need.
SOURCE: HI - i get an error code 0x80020020 from my
Probably the driver don't compatible with Mac but for windows, search another driver for Mac
SOURCE: xp does not recognize lg blu ray burner wh12ls30
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver Click on Start, Run, and type regedit and press Enter HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on the plus signs (+) next to the following folders
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
